Drivetrain Borla Exhaust installed on the Mach V MINI
Old Dec 19, 2007 | 10:36 AM
Mach V Dan's Avatar
Mach V Dan
Borla makes two cat-backs for the R56, the "Touring" with a single muffler and the "Aggressive" with two smaller mufflers. Otherwise the systems are the same, with dual 4" tips. We installed the Touring on our shop car.
I love the look, and it sounds nice. Very discreet, not at all loud at idle or steady cruise. A little more bass sound. And on acceleration, there's a more raspy tone, but nothing that's in any way obnoxious. I don't think I'm going to be worried about attention from the law.
Pics:
And, we took a little video!
Edit: Here's the twin-muffler "S-Type" system. Same except for there are two smaller mufflers in the rear, instead of one larger one. More aggressive sound.
--Dan
Mach V
Old Dec 19, 2007 | 10:59 AM
rattmobbins's Avatar
rattmobbins
Nice!!! How does it compare to the ALTA system you had on before? At least I thought you had the ALTA system...
Old Dec 19, 2007 | 11:20 AM
RUKnight's Avatar
RUKnight
So which one did you end up installing? Sounds really nice by the way.
How was the install? Where is the stock exhaust cut in order to install this? Would it fit with Alta's downpipe?
Mike
Old Dec 19, 2007 | 12:25 PM
Mach V Dan's Avatar
Mach V Dan
Nope.
Old Dec 19, 2007 | 12:27 PM
Mach V Dan's Avatar
Mach V Dan
The "Touring" system.
Really easy. Cutting the pipe is probably the hardest part. We used a Sawzall, which made short work of it.
Between the stock rear cat and the front muffler.
I assume not, since it's designed to slip-fit over the stock pipe, which is smaller than the aftermarket downpipe.
--Dan
Mach V
Old Dec 19, 2007 | 02:01 PM
spfdhed's Avatar
spfdhed
Very nice. I assume there is little, if any, performance gain (??). The sound is very mature and appropriate for the car.
Old Dec 19, 2007 | 05:22 PM
Mach V Dan's Avatar
Mach V Dan
I'd guess not, but we'll find out for sure some time soon when we put the car back on the dyno.
--Dan
Mach V
Old Dec 19, 2007 | 07:22 PM
spfdhed's Avatar
spfdhed
BTW, what wheels do you have? I really like the look with anthracite + polished lip.
Old Dec 19, 2007 | 08:01 PM
Mach V Dan's Avatar
Mach V Dan
Thanks. They're Rota RB's. Read all about them here.
--Dan
Mach V
Old Dec 19, 2007 | 08:20 PM
Revolution Mini Works's Avatar
Dan,
great looking R56... one of the best I have seen
Old Dec 19, 2007 | 11:35 PM
danielo's Avatar
danielo
it sounds GREAT!
but i do not liek the idea that to mount it, there needs to be cutting.
Old Dec 19, 2007 | 11:40 PM
justintime's Avatar
justintime
that video makes whoever is filming look really tall
Old Dec 20, 2007 | 03:18 AM
ThumperMCS's Avatar
ThumperMCS
That is such a hot R56. Great job with it! Borla sounds good...would love to hear the louder version though, the tips look great as well .
Old Dec 20, 2007 | 07:11 AM
Mach V Dan's Avatar
Mach V Dan
There's really no way around that. Almost the entire MCS exhaust, INCLUDING the second catalytic converter, is one solid welded piece. That means to have a street-legal cat-back system, you're going to have to cut the factory system.
--Dan
Mach V
Old Dec 20, 2007 | 07:33 AM
PGT's Avatar
PGT
not to mention it's easy to reweld the stock system should one ever need to put it back on. heck, I just cut a system I sold in half and shipped it to Australia - the new owner had it tacked back together and installed. :tu:
Old Dec 20, 2007 | 09:18 AM
rattmobbins
it sounds GREAT!
Good luck finding an aftermarket exhaust the doesn't require cutting out the factory system.
Car sounds great BTW, and those tips are hawt!!!
Old Dec 20, 2007 | 09:20 AM
chili_red07's Avatar
chili_red07
the more I look at the Borla, the more I'm loving the 4" tips
Old Dec 20, 2007 | 10:21 AM
ice877's Avatar
ice877
mmmhm after i get my goliath back this might be a late christmas present!!!! *goliath found a deer one day headed to see some friends *
Old Dec 20, 2007 | 12:02 PM
PGT's Avatar
PGT
just got back from Mach V....I heard this in person. For you former R53 people, this system is to the R56 what the Milltek is to the R53.....not stock, but not a fart can either....just right.
Old Dec 20, 2007 | 06:43 PM
Mach V Dan's Avatar
Mach V Dan
I added a second video of the (not much) more aggressive two-muffler system.
--Dan
Mach V
Old Dec 20, 2007 | 07:06 PM
PGT's Avatar
PGT
did I hear the quiet one today?
Old Dec 20, 2007 | 07:14 PM
Msteadman's Avatar
Msteadman
Wow, I never listed to the clip before but that sounds amazing.
Old Dec 20, 2007 | 07:36 PM
danielo's Avatar
danielo
Is this the same for those downpipes from Alta and Milltek?
Old Dec 20, 2007 | 08:04 PM
Mach V Dan's Avatar
Mach V Dan
Yes.
--Dan
Mach V
Old Dec 20, 2007 | 10:43 PM
n1tr0's Avatar
n1tr0
I think that's the first video/clip of the Borla S system, it's really hard to tell the difference, how would you rate/compare them side by side ?
I love the Alta downpipe, but their muffler's just too quiet, it'd be great if there was a way to combine the two. I want to be able to remove & keep my stock exhaust un-modified (un-chopped) in case I ever need to take the car in for warranty purposes.
