Drivetrain strut bar
Old Oct 24, 2007 | 07:31 PM
ViVi^BoY's Avatar
ViVi^BoY
strut bar
hi guyz,
I currently fitted the Alta CAI version and looking for strut bar.
The previously strut bar i used cant used after i fit alta CAI because the CAI block the way of strut bar.
Anyone got any suggestion on that?
Old Oct 24, 2007 | 07:42 PM
ChrisW's Avatar
ChrisW
The M7 will work
Old Oct 24, 2007 | 07:45 PM
Some Guy's Avatar
Some Guy
+1 on the m7. It is a sweet piece of kit.
Old Oct 25, 2007 | 12:16 PM
sam_a156's Avatar
sam_a156
This is the mother of all strut bars (GTT Tuning, UK). Not sure how well it fits with Alta CAI though...and might cost an arm and leg to import:-)
Old Oct 25, 2007 | 03:56 PM
apexer's Avatar
apexer
M-7
Old Oct 25, 2007 | 04:11 PM
JustJAY's Avatar
JustJAY
I like the GTT unit, but the only downfall I see it that you have to remove it to change the filter and perhaps the plugs.
Old Oct 25, 2007 | 04:17 PM
Crashton's Avatar
Crashton
With an M7 I have to remove the center section to get the oil filter off. I don't think removing the GTT would be much of a problem. Six nuts & it's off in maybe 3 minutes.
Old Oct 25, 2007 | 06:56 PM
ViVi^BoY's Avatar
ViVi^BoY
From the picture, I dun think GTT can fit on it because I also fitted CAI top.
GTT looks nice.... :( (Thanks Sam)
Anyone has M-7 strut bar picture??
Old Oct 26, 2007 | 05:08 AM
Bahamabart's Avatar
Bahamabart
Originally Posted by ViVi^BoY
hi guyz,
If your using the open top Alta - some just cut the sides to allow the strut bar to pass thru. If your using the Alta CAI w/ top then put your old one up for sale and contact vendors to see if theirs will fit over the Alta.
Old Oct 26, 2007 | 11:53 AM
apexer's Avatar
apexer
You don't have to cut the sides of the Alta CAI box to fit the M-7, just notch the rubber seal on one side. I don't have the closed top Alta CAI but, I think I saw posted that the M-7 clears the closed top as well.
Old Oct 26, 2007 | 12:26 PM
gnatster's Avatar
gnatster
No mods required for the CravenSpeed CAI and M7 strut bar.
Old Oct 28, 2007 | 12:50 AM
ViVi^BoY's Avatar
ViVi^BoY
thanks apexer and bahamabart,
I will contact the person selling the m-7 strut bar and see how it goes.. :D
Thanks alot.
Old Oct 28, 2007 | 01:35 AM
roaduscarnivorous's Avatar
roaduscarnivorous
you'll like the m7 bar. it also prevents mushrooming. and removing the center section during oil change is super easy
Old Oct 28, 2007 | 06:49 AM
rosmakloma's Avatar
rosmakloma
Do you feel that the front strut bars really make a difference? I've heard more emphasis placed on getting a rear sway bar instead.
Thoughts....
Old Oct 28, 2007 | 06:57 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I'm on the side that feels the strut bar is simply bling. That being said, the rear sway bar will definately be more noticeable. About the M7 tower bar, stoping mushrooming is good, so I have their reinforcement plates.
Old Oct 28, 2007 | 09:19 AM
MiniMacPR's Avatar
MiniMacPR
I have the m7 with the Alta, no notch needed-it fit perfectly. I did, however, have to remove the box top. In my car there was no way it would fit, not even close.
+1 on it being mostly bling, but bling is not always a bad thing if done correctly. Many consider the bonnet stripes on the MINI as bling...
Old Oct 28, 2007 | 09:41 AM
ED955S's Avatar
ED955S
+1
Old Oct 28, 2007 | 10:09 AM
sam_a156's Avatar
sam_a156
Those who say that haven't tried the GTT one
Many at MINI2 - the undersigned included - can confirm that the difference is noticeable. Just reversing down a deep parking ramp and turning at the same time is enough to feel the difference. It is one solid piece of metal without any moving parts thus minimum flex - it makes many others look flimsy in comparison.
But, I partly agree with nabeshin: most of them are of cosmetic value only. I was originally not going to buy one for this very same reason.
As far as changing the filter: yup, it is necessary to remove the brace. But it is just 2 x 3 nuts and it is off. Even with my mechanical skills it won't take more than 3-4 minutes.
Old Oct 28, 2007 | 11:05 AM
Longboard Mini's Avatar
Longboard Mini
I went with the OMP upper and lower braces. The OMP upper uses the sides of the strut towers to brace against. Once it's on you can pre-load the bar before tightening down the strut bots.
The combo made a real difference you can feel. It also works with my Alta just fine.
Longboard
Old Oct 28, 2007 | 02:20 PM
apexer's Avatar
apexer
Thoughts....
For handling, the rear anti-sway bar much more beneficial than the strut bar.
Old Oct 28, 2007 | 05:56 PM
ViVi^BoY's Avatar
ViVi^BoY
really ?
then i most likely to get the sway bar instead of strut bar.
any recommendation on sway bar?
Alta? M-7? GTT?
Old Oct 28, 2007 | 06:23 PM
Crashton's Avatar
Crashton
I have a 19mm H-Sport that I'm very happy with.
Old Oct 28, 2007 | 07:19 PM
apexer's Avatar
apexer
I have the H-Sport 22MM Comp. Bar. Usually keep it in middle setting.
Old Nov 6, 2007 | 06:02 PM
lunlun's Avatar
lunlun
will the JCW strut bar ($225.00) fit the Alta CAI open top version?
ericbryant24
55
Sep 30, 2024 02:10 PM
ej
Nov 17, 2015 09:21 PM
MINI-Madness
Sep 11, 2015 11:31 AM
cdemarco4
Sep 10, 2015 10:14 AM
Suspension Products
Sep 3, 2015 09:41 AM
