Drivetrain 237 HP
Old Oct 9, 2007 | 02:44 PM
ca$per's Avatar
ca$per
237 HP
I found this Video on YouTube and didn't know where it would fit better... here or the video threads, but it is more about modifications so I will post it here. The guy claims 237 hp with the mods listed at the end of the video..
Any thoughts about the the stock market like chart?
http://www.youtube.com/watch?v=CGVhMAKhFUM
I know it's not very clear, but is worth looking at... have fun
Old Oct 9, 2007 | 03:15 PM
luckydoggarage's Avatar
luckydoggarage
This is a common result with the listed mods and a good tune.
Old Oct 9, 2007 | 04:50 PM
MarioKart's Avatar
MarioKart
Vendor
wheel or crank hp? I cant see the video on my cell phone. I will have to watch later.
Old Oct 9, 2007 | 05:03 PM
skillet's Avatar
skillet
Sounds like the RPM is higher than stock...maybe not, but the pitch sounds pretty high. Aren't we also supposed to dyno in 4th gear? I thought 4th was closer to a 1:1 ratio...
Old Oct 9, 2007 | 05:31 PM
ca$per's Avatar
ca$per
I think it's on the wheels and done on a Mustang Dyno too
Old Oct 9, 2007 | 05:37 PM
MarioKart's Avatar
MarioKart
Vendor
I got to watch the video, looks like wheel hp. Wow, 237whp on a Mustang must be 250whp on a dynojet. The numbers seem a little high. I have only been able to get 234whp on a dyno jet with smiliar mods, but my car is able to dyno the near same numbers over and over again with very little heat soak. The air/water intercooler really helps with that. With an air/air intercooler I was losing 20whp with each pull.
Old Oct 9, 2007 | 05:47 PM
ca$per's Avatar
ca$per
I got to watch the video, looks like wheel hp. Wow, 237whp on a Mustang must be 250whp on a dynojet. The numbers seem a little high. I has only able to get 234whp on a dyno jet with smiliar mods, but my car is able to dyno the near same numbers over and over again with very little heat soak. The air/water intercooler really helps with that. With an air/air intercooler was making me lose 20whp each pull.
FYI (since you can't watch the vid now) the car is an 05 and mods as listed are:
- Alta 15% pulley
- GTT IC
- Alta CAI
- OBX manifold
- Scorpion catback
-dbilas dynamic camshaft
- Original Rectifie Head and TB
- Mini Speed ECU program
too good to be true? I will try to contact the submitter to see the deal behind it...
cheers
Old Oct 9, 2007 | 06:32 PM
El_Griton's Avatar
El_Griton
my 05 is STRONG also............
Old Oct 10, 2007 | 01:51 AM
Bazer's Avatar
Bazer
Looking at the license plate I think this was done in Greece or Spain (not 100% sure). But isn't there a difference between Europe / US on how horsepower is measured?
edit: maybe I'm not awake yet
Old Oct 10, 2007 | 03:43 AM
Paul Webster's Avatar
Paul Webster
Its Greece, there is some top 4 pot tuners out there, espically in Malta
Old Oct 10, 2007 | 07:22 AM
skillet's Avatar
skillet
Wasn't he in 3rd gear?
Old Oct 11, 2007 | 03:02 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Promissing to say the least, I want to get a valve job and new cam plus a dyno tune (all in the next few years). I can only hope to put down such power.
Old Oct 12, 2007 | 02:45 PM
DiGiTaLBee's Avatar
DiGiTaLBee
Hi,
My Name is Costas and I am from Greece. The car at the above video is mine. I had a second dyno run this summer and got 233 Whp @ 7950 rpm but with higher temps. I also had a variable cam sprocket installed and had a custom program made. I am going now to add a metallic sport catalytic converter and remove the larger TB to check the difference it makes.
PS. Malta is not in Greece
Old Oct 12, 2007 | 04:02 PM
ca$per's Avatar
ca$per
Originally Posted by DiGiTaLBee
Hi,
First of all let me say welcome to NAM, DiGiTaLBee.
Second, that is a nice number you got there, I think alot of minis now are reaching this limit, and past it . We are all HP junkies here and would love to see the dyno graph... what was the temperatures when you got 237hp?
I think your car is about the same with MarioKart and you are very close in HP... also check with Revolution Mini Works (231hp with 15% pulley, Alta CAI and RMW Big Valve Head) as you might find that there is good info there.
Keep us posted on the progress and updates...
cheers
Old Oct 12, 2007 | 04:47 PM
MarioKart's Avatar
MarioKart
Vendor
Hi,
Welcome Coatas,
I would love to see what numbers you get after you remove the larger TB. Sometimes I think about removing my TB. What software are you using?
BTW nice numbers!
Mario
Old Oct 12, 2007 | 04:58 PM
Paul Webster
Hi,
Welcome Costas, I should have said you are from Greece.
Also there are some top 4 pot tuners in Malta as well
Old Oct 13, 2007 | 04:09 AM
DiGiTaLBee's Avatar
DiGiTaLBee
The software was made on the dyno by the owner of the dynamometer. I had to remove MiniSpeed's one as I found that tha A/F ratio was not as good as I wanted. As for the high numbers bare in mind that the maximum power is at almost 8000rpm that is higher than most have as a limit.
Karbair
Jun 23, 2015 04:43 PM
idimension
Jun 21, 2014 10:25 AM
