Drivetrain Ireland Engineering exhaust
Old Nov 2, 2007 | 08:22 PM
  #26
rwkeating's Avatar
rwkeating
Any ideas why this is so inexpensive compared to let's say the Alta? I wonder what the inside of the resonator and muffler are like. Everything else has been reported on, so where is the cost cutting? I guess some comes from not having tips but just that can't make up the difference.
Old Nov 3, 2007 | 08:39 AM
  #27
sprp85's Avatar
sprp85
the mufflers are flowmasters if i remember correctly, so no cheapos.. its just... thats how much it SHOULD COST originally...700, 800 for an exhaust? uh huh sure... its not that ireland is way too cheap, its just that all the other exhausts for mini are overpriced.
Old Nov 3, 2007 | 09:00 AM
  #28
ED955S's Avatar
ED955S
That's true. Mini exhaust is overpriced.
Old Nov 3, 2007 | 10:41 AM
  #29
verveAbsolut's Avatar
verveAbsolut
Haha just a little...I could not understand, for the life of me, why SS piping (cheap as all hell) & a muffer (80+) are going for north of 600 regularly for the Mini.
The only reason I have not sourced my own as of yet is that I would have no idea what it would sound like before installed/complete. I'll take the plunge eventually though and do a dual-outlet with the PU valence.
Back on Topic: Anyone have a sound clip?
Old Nov 3, 2007 | 04:43 PM
  #30
Aeromax's Avatar
Aeromax
This is true. On my last car, a new gen saab 900, I was able to buy a full factory Saab stainless catback sport exhaust for $350. This is OEM-aftermarket stuff we're talking about too.
Old Nov 3, 2007 | 05:30 PM
  #31
cpayne's Avatar
cpayne
Just installed my Ireland
Ok gents..here are my initial impressions:
Installation and Fitament:
-1) Installing this exhaust is truely a piece of cake with 2 people. In fact with 2 people and if you had done it once before..I bet you could install it in about 30 minutes with pneumatic tools where applicable.
-2) Hangers ALL line up perfectly...no bending no tweaking.
-3) The stock exhaust is easily over 50 lbs..no doubt. This exhaust weighs 27 lbs from Ireland
-4) Install the mid section hangers/bracket OFF the car..much easier then trying to do while under the car. Also be careful not to install it upside down, you will know if you are "forcing" the exhaust mount 10mm screws and the mid-section is rubbing on the bracket.
-5) Get yourself a couple of bolts that are 2.5" long bolts and a couple of nuts and washers as the stock bolts are not workable, nor included in the kit, as is a stud pressed in the stock flange
-6) Center resonator does NOT hang low..not even more the 1/4" lower then mid-section brace/exhaust bracket.
-7) Only complaint other then the rough T-in on the exhaust tip, are the tips (IMHO) are a bit long. I might cut off 1/2 to 3/4" w/ the bandsaw
The exhaust truely fits amazing! Again I am going to have to do some tip adjustments (length)..but man for the price..I dont think you can beat it.
Sound:
Dont have a exhaust sound clip..but it is really nice and deep. (exhaust clip to come) Edit: http://www.youtube.com/watch?v=Cwzeug_DsQo (Sound Clip)
More exhaust comes out of the T'ed in 2nd tip then you think..at least feel of the hand at idle
Pics:
Old Nov 6, 2007 | 05:26 AM
  #32
cpayne's Avatar
cpayne
Here is my video...
Old Nov 11, 2007 | 10:47 AM
  #33
cpayne's Avatar
cpayne
Ok..just cut off about 1/2" on the tips to make them shorter and symetrical
Old Jan 31, 2008 | 02:07 PM
  #34
PGT's Avatar
PGT
how are you liking this after living with it for a bit?
Old Feb 1, 2008 | 10:37 AM
  #35
Aeromax's Avatar
Aeromax
I saw this exhaust go on ebay once for like $200...
Old Feb 4, 2008 | 10:36 AM
  #36
SPDinNY's Avatar
SPDinNY
I cant find this exhaust on ebay =(
Old Feb 4, 2008 | 04:00 PM
  #37
IamSMC's Avatar
IamSMC
I was wondering if this exhaust would fit a MCS convertible?
Old Feb 4, 2008 | 04:04 PM
  #38
PGT's Avatar
PGT
it should. the only difference is the bend....it needs to be a bit steeper to clear the cabrio's bracing. worst case, you can have a shop add some more angle to it to clear.
problem area (Milltek in the pic):
Old Jun 21, 2008 | 02:39 PM
  #39
cpayne's Avatar
cpayne
I like it...a 'bit' louder then then I like...but other then that perfect. Does not resonate at all on highway.
Old Jun 22, 2008 | 07:23 PM
  #40
ED955S's Avatar
ED955S
Originally Posted by CooperSKart
Actually I just had one that I won on Ebay for $275 shipped installed about a week ago.
I had it installed by Meineke & they did a pretty good job, but they said that they had a bear of a time with the hangers and had to bend some of them around, so I suspect I may have had one for an 02-04 sent by mistake.
For me, the jury's still a bit out if I really like it or not (it is growing on me more & more though). It's fairly loud (I had the one ball before, and it's a bit louder than that for sure), but doesn't drone much on the highway except above about 75 mph. The burble is still there, but it actually seems to be a tiny bit more muted than w/ the one ball. The weird thing is when I first took it for a spin it seemed like there was more low end torque from the butt dyno, but it seemed to take a tiny bit longer to spool.
Now it feels like its a bit more torquey around 4 - 6 K and spools up more quickly (about the same as the one ball). It also make a distinct whooshing or turbine sound that I've heard described regarding some of the one-sided exhausts after about 5500 rpm.
The fit & finish are pretty good, but definitely not the greatest. The two tips aren't perfectly aligned (since the driver side tip carries 99% of the exhaust and it is not perfectly parallel to the other welded on tip), but it is centered pretty well & looks good from about 5+ feet away. I also masked & spray painted the inside of the other (welded on) tip before the install with flat black high temp BBQ paint since I knew that it wouldn't get black with exhaust soot like the other tip that carries most of the exhaust & you really can't tell the difference except if you're a foot away.
Other than E-bay where can I get a good deal of this IE exhaust.
Old Jun 23, 2008 | 04:11 PM
  #41
yellowmini66's Avatar
yellowmini66
ireland engineering exhausts
Originally Posted by fullcollapse40
I tried a quick search in the exhaust thread, but could not find anything on this system. For less than $500 I am curious what you get performance and sound wise.
got my ireland engineering exhaust installed today and after an hour (plus) of bending and welding and not to mention 150.00 dollar labor from the muffler shop, it was done. mix feelings! the hangers did not fit and the clamp to the mufler connecting the tip was way too small...finally had to welded on. was it worth 340.00 dollars, i guess. customer service stinks but the shipping was fast (4 days, from ca to fl). the system it self looks home-made but it was well polished and it sounded great on my r53.... get what you paid for!
Old Jun 23, 2008 | 07:04 PM
  #42
AutoXCooper.com's Avatar
AutoXCooper.com
The real issue is shipping it to Canada. Just had a customer that wanted the system, but shipping it cost as much as the system to Canada. If you have a US address PM me and we can work out a deal.
Old Jun 24, 2008 | 10:06 PM
  #43
Bang110's Avatar
Bang110
I just got mine in the mail... Want to install it SO bad but this sunday some lamer side swipped my mini so it's in the shop getting fixed up.. So I will need 2 1/2 bolts to mate it to the factory header?
Old Jun 25, 2008 | 03:10 PM
  #44
AutoXCooper.com
Bummer Bang,
You have all those parts laying around and nothing to install them on.
Just set them up around the house she won't mind.
You "shouldn't" need anything special to install the IE system.
Old Jun 25, 2008 | 04:09 PM
  #45
Bang110's Avatar
Bang110
I have all my parts in the livening room floor. Just looking at me. Damm I want my car back. Still need the SC pulley and CG lock.
Old Jun 25, 2008 | 05:47 PM
  #46
Fatherdeth's Avatar
Fatherdeth
Bang, try to get 2.5 inch stainless bolts, nuts, and washers. You can find them at Lowes. Here is another thing I would suggest. The Ireland is a beautiful piece of artwork, but since it has no flanges on the hangers, here's what I did. Once you put the hanger into the rubber holder, place a vacuum cap over the end of the hanger, and then use a small hose clamp around the vacuum cap. If the hanger sticks out from the rubber holder too far, you can cut the end of the vacuum cap off and push it all the way onto the metal hanger until it sits right against the rubber piece, then put the hose clamp on.
I've had mine on since February. The exhaust won't move around a lot while driving, even the spirited type, but you can almost move it by hand, and on occassion, I had to kick the tips to center them. With vacuum caps, it is eliminated. I'm going downtown tomorrow though and see what the local muffler shop can do about the tips. I'm just not happy with them.
Old Jun 26, 2008 | 06:02 AM
  #47
AutoXCooper.com
Bang, check email, sent tracking info.
Fatherdeth, Thanks for the feedback, I have sent it to IE and hope they will review and adjust. Thanks for posting the helpful tips.
10:45am update, IE will make adjustments to fix the issues Fatherdeth addressed above on all new orders. Thanks again for the feedback we do see it and take any and all action we can to make our products better for you.
Old Jun 26, 2008 | 01:00 PM
  #48
Fatherdeth's Avatar
Fatherdeth
No problem Auto X. I appreciate you guys considering the feedback and getting back with the companies. I really like this exhaust, and would recommend it to anyone who can't or doesn't want to shell out big bucks on some of the more mainstream exhausts.
Old Jun 26, 2008 | 05:56 PM
  #49
rwkeating's Avatar
rwkeating
Fatherdeth, what is a "vacuum cap"? I've been trying to read everything I could find on this exhaust and I never heard of the issue you described so I'd like to learn more about them. Please keep us posted. Thanks.
Old Jun 26, 2008 | 07:18 PM
  #50
Fatherdeth's Avatar
Fatherdeth
A vacuum cap is a little rubber cap that comes in different sizes. You use it to cap off vacuum lines that aren't being used, or vacuum inlets/outlets that aren't being used.
You probably haven't heard much about the issue I posted because in all honesty, it's not really that much of an issue. What you will notice is that on the tips of the exhaust hangers, there are no flanges that keep the hanger from coming out of the rubber holder. The Ireland will not come out of the rubber holder, however, there is some play and this can cause the exhaust to slightly slide around. What I posted is just a suggestion on how to keep the exhaust steady and still. Hope this helps.
