Drivetrain ALTA's Intercooler
Old Sep 26, 2007 | 09:10 AM
  #76
Astro S's Avatar
Astro S
Hey guys, is there any concerns with the reduced air flow to the rad?
Scott, car looks nasty.
Old Sep 26, 2007 | 09:17 AM
  #77
diablito's Avatar
diablito
looks great Scott...yeah!!
Old Sep 26, 2007 | 09:24 AM
  #78
scott48's Avatar
scott48
Alta said no...the air still flows through the intercooler to the radiator...........and thanks for the compliments guys
Old Sep 26, 2007 | 11:01 AM
  #79
Gardus's Avatar
Gardus
What about turbo lag? Usually with bigger intercoolers...
Old Sep 26, 2007 | 11:04 AM
  #80
scott48's Avatar
scott48
nope....no increase.
Old Sep 26, 2007 | 01:47 PM
  #81
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Astro S: The air flow still continues to the radiator, and the water temps are un affected by the change! Good question though!
NO LAG!!!!!!!!
Thanks guys!
Old Sep 26, 2007 | 03:54 PM
  #82
TurboBlu's Avatar
TurboBlu
i have no lag what so ever. just got new wheels and tires, they will be here friday, cant wait to see what the car will do when it can hook up in 1st :-)
oops, this is frank, 07mcs, i was on the front desk pc at work, didnt see a co worker had signed on
Old Sep 26, 2007 | 11:03 PM
  #83
R56-S's Avatar
R56-S
I'm thinking that the new JCW tune kit and this Alta
intercooler could be the hot setup at the moment.
are we there yet? 200 whp
MHO,
Carl
Old Sep 27, 2007 | 07:32 AM
  #84
FugitiveAI's Avatar
FugitiveAI
MHO,
Carl
Don't forget the ALTA downpipe!
Old Sep 27, 2007 | 08:02 AM
  #85
ALTAPerformance's Avatar
ALTAPerformance
Good choices guys! "Howard" is anxious to get on our dyno with all of his pieces to get more runs for you guys, but we have just been slammed on all kinds of stuff around here. Another event this weekend for the local PDXMINI.org club. But I am trying to get those to you ASAP.
Also, 200WHP won't be an issue folks!
Adam@altaminiperformance.com
Old Sep 27, 2007 | 10:43 AM
  #86
byhsu's Avatar
byhsu
I have a question regarding your dyno test for the FMIC vs. Stock R56. The 20whp and 30 torque, was it achieved with the FMIC only? Or with other components? If other components, which ones?
Thank You
Old Sep 27, 2007 | 01:30 PM
  #87
eeterp's Avatar
eeterp
NO LAG!!!!!!!!
Thanks guys!
The upper grill should be more than sufficient to cool the rad in addition to the residual air that passes through the FMIC. However, Alta offers an air diverter http://www.altaminiperformance.com/p...r-Diverter-R56 that should help cooling even more.
Old Sep 27, 2007 | 01:33 PM
  #88
01CBR929's Avatar
01CBR929
Take a second look there guy... you can't use both the diverter and the fmic, unless I'm sorely mistaking(which is always possible).
Old Sep 27, 2007 | 01:39 PM
  #89
ALTAPerformance
um...true: Can't use both the diverter and the FMIC together. Excelletn point.
On the dyno results they are posted in the aforementioned thread. ALTA2 has published the mods, etc. there.
Let us know how we can help further fellas!
Old Sep 27, 2007 | 02:02 PM
  #90
eeterp's Avatar
eeterp
Originally Posted by 07 MCS
VIR!
Looks like that M3 conv. needs to point-pass.
Old Sep 27, 2007 | 03:47 PM
  #91
byhsu's Avatar
byhsu
Alta:
Your dyno results in your website says big gains from 3 simple parts, which parts is it talking about?
Old Sep 27, 2007 | 05:03 PM
  #92
SlowB00st's Avatar
SlowB00st
200, what about 250whp
Old Sep 27, 2007 | 08:40 PM
  #93
07 MCS's Avatar
07 MCS
well been a week and the car still runs good. only prob is im too lazy to re hook up the air tem sensor. Hey adam, this that will cut down on performance with the car thinking its -40 out? hehe and a cel on. when i put the wheels on tomorrow ill hook it up and clear the codes. cant wait to feel the car at 100%
detail and pics come tomorrow
Old Sep 27, 2007 | 08:54 PM
  #94
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Hey Alta, what is that intercooler rated for? HP? Cubic Ft/Min? Thanks.
Old Sep 27, 2007 | 09:03 PM
  #95
Minidrivr's Avatar
Minidrivr
Any plans to come out with a black one? Don't really care for the way it looks behind the grill.
Old Sep 27, 2007 | 11:26 PM
  #96
unxpectederror's Avatar
unxpectederror
spray paint is your friend lol
Old Sep 28, 2007 | 04:43 AM
  #97
Minidrivr's Avatar
Minidrivr
My favorite color, Krylon semi gloss black...
Old Sep 28, 2007 | 10:47 AM
  #98
eeterp's Avatar
eeterp
I'd recommend
Standard engine paints are too thick for radiator use because they can interfere with heat transfer and block air flow between the cooling fins. Also, standard paint tends to flake off radiator tanks. Radiator Black helps solve this problem. Durable Enamel formulation resists temperatures up to 250ºF, gas and chipping. One can covers 6 square feet (most radiators require 2 cans). Net wt. 12 oz.
http://www.eastwoodco.com/shopping/p...radiator+paint
Old Sep 28, 2007 | 12:01 PM
  #99
ALTAPerformance
byhsu: Turbo-Back Exhaust, Intake and FMIC. Thanks for asking!
SlowB00st: Check out our turbo kit for at least that! (not out yet, soon, blah, blah blah!)
ChrisMCS04: This core is large enough for more than 400WHP, and rated for even more. Also, less than 1/2 lb at 20 psi sustained across the core.
Regarding black: The powdercoat will work and may be available at sometime soon. The powder does hurt efficiency a bit. The rad paint above may be a better choice in the meantime.
Thanks again!
adam@altaminiperformance.com
Old Oct 3, 2007 | 01:30 PM
  #100
320d touring's Avatar
320d touring
quoted WHP gain for turbo back =20WHP
quoted WHP gain for CAI =10WHP
quoted WHP gain for intercooler =20WHP
How can the total gain only be 20WHP
