Drivetrain TURBO BOOST GAUGE INSTALLATION R56-S
Old Sep 9, 2007 | 05:29 AM
mini07's Avatar
mini07
Hi there,
Have anybody installed a turbo gauge in one of our jewels. I am about to
order the new flex pod for my R56-S but will like to know before I buy, where or how to hook the boost gauge to the system.
mini07
Old Sep 9, 2007 | 08:53 AM
Candyman's Avatar
Candyman
Having the same problem. The options are to tap the manifold, or (for less accuracy) take out the noisemaker and put a plug w/ a vacuum fitting in there.
I haven't looked under the manifold, but this is where I'm at @ this point.
Old Sep 9, 2007 | 11:05 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Guys: ALTA2 and I should be completing the R56 ALTA Gauge System installation either today or early this week in Howard. It will show clearly how to connect boost, EGT, and potentially, water temp, oil temp etc. Hate to say be patient, but be patient and I will get you the info you need.
Sidenote: These new gauge kits are going to really be a hit. Amber back light, white during the day, opening ceremony, peak hold, FULLY electronic (so no tubes or oil lines traversing the firewall) and with pods, less than $269.99 (final pricing TBD)
Thanks guys and gals!
Old Sep 9, 2007 | 11:08 AM
Maverick's Avatar
Maverick
Very good!!! I will wait for them
Old Sep 9, 2007 | 01:31 PM
tommy_zito's Avatar
tommy_zito
id like to know the same thing
Old Sep 9, 2007 | 05:37 PM
MrB's Avatar
MrB
looking forward to see
Old Sep 9, 2007 | 05:49 PM
a96bimmerm3's Avatar
a96bimmerm3
Adam, I'm going to go broke because of you guys.
Old Sep 9, 2007 | 06:51 PM
thlaxx's Avatar
thlaxx
^ditto
Old Sep 10, 2007 | 08:24 AM
scabpicker's Avatar
scabpicker
Excellent, my only real gripe with this car is the lack of gauges.
Old Sep 10, 2007 | 10:55 AM
tommy_zito's Avatar
tommy_zito
im having the same problem on the R53 any one have any ideas?
Old Sep 10, 2007 | 02:32 PM
ltjpunk7's Avatar
ltjpunk7
Anybody know a good reference where I could learn the importance of all of the different guages? I mean, I know what most of them do, I've just never had a car where I could monitor the boost, water/oil temp, etc. I'm curious as to the importance of such instruments. For example, what is the function of being able to know what level boost you are running at a certain instance? Thanks from a forced induction n00b.
Old Sep 10, 2007 | 03:56 PM
ADAMSALTAMINI
We have NEW pods with gauges coming out on both the R53 and R56. I thought we would have the website updated today, but there was a lack of proper photos that were being finished up when I left. Sorry for the delay folks!
ltjpunk7: Good questions. My vote is first to monitor things not covered by the OEM idiot lights and gauges. So boost, oil temp, water temp in the case of the R56, exhaust gas temps etc. But the choice is yours. On my car the first two are going to be Boost and Exhaust Temp up on the column on our new pods. I might also add one more up there for water temp. If not I will mount those (oil AND water temp) under the switches. My personal opinion is the oil pressure is not really needed as the idiot light will come on for that, boost is great to monitor all the connections are holding etc. and or that i didn't ingest a bird into the turbo or something. EGT is good for monitoring proper tune etc.
Hope that helps. If not let me know!
Old Sep 10, 2007 | 05:07 PM
scott48's Avatar
scott48
so can you just get a boost gauge?
Old Sep 10, 2007 | 05:15 PM
ltjpunk7's Avatar
ltjpunk7
So correct me if I'm wrong, but the majority of these add-on guages are simply make-sure-nothing-has-effed-up-guages...correct? So are they really that necessary, as most of our cars won't ever have problems necessitating these early warnings? It's just that if this is something that will help me monitor/tune my performance, I would love to add them, but for a man on a budget, I might rather spend a few hundred bones upgrading my intake or springs. Thanks for any enlightenment.
Old Sep 10, 2007 | 08:54 PM
MrB's Avatar
MrB
gauges is not only for tune up need, but also it is a fashion of interior
Old Sep 10, 2007 | 09:44 PM
Minidrivr's Avatar
Minidrivr
The only gauge I really would like is water temp/engine temp. Never owned a car that didn't have this.
Old Sep 10, 2007 | 10:21 PM
kreative's Avatar
kreative
I'd really like the water temp & oil temp gauges to make sure the car isn't overheating and that the oil has come up to temp before driving.
Old Sep 10, 2007 | 11:01 PM
aus's Avatar
aus
I think the oil temp would be very nice to have in a Turbo car since it take sa while for the oil the warm up, even after the idiot temp gauge shows the car as warmed up.
Old Sep 10, 2007 | 11:12 PM
Minidrivr's Avatar
Minidrivr
Is there an idiot light to tell you the car is warmed up or do you mean the temp light that tells you the car is too hot?
Old Sep 10, 2007 | 11:27 PM
R56-S's Avatar
R56-S
Adam,
I respectfully disagree on the oil pressure. if anything is going to tell you and forewarn you of impending doom, it's oil pressure. If your driving along at 60 mph and your pressure is 50 lbs and suddenly drops to 15lbs, thats enough to keep the idiot light off, but you would look into the oil pressure problem be fore it got ugly. IMHO
Carl
Old Sep 11, 2007 | 09:05 PM
aus's Avatar
aus
Just the regular "temp" gauge. That thing is so inaccurate it's almost worthless. In the M-cars, they have the yellow LED's that suggests the max revs until the oil's warm. Thos lights stay on a long time after the idiot gauge shows the temp to be warm.
Old Sep 12, 2007 | 05:40 AM
Maverick's Avatar
Maverick
I'd like to know infos about the engine,especially cause it's turbocharged... On the airplane I fly we have a lot of infos from the sensors; one of the most important is the EGT since where there is a turbine you need to know the EGT cause if it gets too high you can burn the inside blades ...
Old Sep 12, 2007 | 11:24 AM
ALTAPerformance's Avatar
ALTAPerformance
Hey Guys,
This is the reason why we are offering a multitude of choices. At the current setup the gauges and pods are sold in pairs. But we can certainly do just one pod/gauge too. They are working very hard to get this on the web ASAP.
Thanks again folks!
Adam
Old Sep 12, 2007 | 11:38 AM
Minidrivr's Avatar
Minidrivr
Adam. Do you sell complete kits, with pods, gauges, wiring, etc?
Old Sep 13, 2007 | 02:57 PM
ALTAPerformance
Minidrivr: The simple answer is yes. They will be set up to make installation as easy as possible. You will get wiring, but will need to tap into the harness using supplied connectors etc. More info ASAP sorry for the delay!
Adam
