Minidrivr: The simple answer is yes. They will be set up to make installation as easy as possible. You will get wiring, but will need to tap into the harness using supplied connectors etc. More info ASAP sorry for the delay!
Adam
Sounds good. It will make it easy for us gauge adding newbies.
I need to talk to Jeff when he gets back. I know we have vacuum on the mule R56, but I don't know exactly where it is tapped. I might dig around again later today. I will let you guys know.
Is there any room to use an aluminum Throttle body spacer, too use a source for vacuum taps, for anything that also needs vac? So one does not have to tap the mani...
This is the first car I will own with a turbo. If you are not planning to mod the engine, why is the boost gauge important? I understand how water temp and oil pressure are important (even on a stock engine), but why boost?
Minidrivr: The boost gauge is great to see what is going on with the motor. You can gauge if you have a problem with boost loss over time (worn boots, failed clamps etc.) as well as if you have a spike (plugged cat, etc.). Also, Oil Temp is an excellent gauge as well. The turbo likes warm oil and as a result it is best to wait to put your foot in it (building boost) until the oil is warm. So the boost gauge combined with oil temp is a great idea. Or if you want something combo'd differently, let us know.
Ok, are there any double gauges? I like the look of the 2 gauge pod with the tach. But would like boost/water temp in one gauge and oil temp/oil pressure in the second gauge. Is that possible?
