Drivetrain anything good about obx header
Old Aug 27, 2007 | 06:11 PM
mini22's Avatar
mini22
I'm looking at the obx header and noticed it was really cheap has anyone seen this product or have it on thier car does anyone recommend it thanks frank
Old Aug 27, 2007 | 06:14 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
They are actually very popular on NAM...if you use search just type in obx and you should find some great info....im sure some users will chime in....
Jack
Old Aug 27, 2007 | 06:59 PM
SharoSC02's Avatar
SharoSC02
I have it on mine as many others here on nam do and love it. The engine/exhaust sound becomes deeper and your low to mid range torq picks up which is what you want. The overall performance is 10 time worth the money.
Old Aug 27, 2007 | 07:13 PM
ThumperMCS's Avatar
ThumperMCS
Anything good about the OBX?
....Everything! Great gains. Great sound. Great price. Seemingly good quality.
Old Aug 27, 2007 | 07:18 PM
jeffc's Avatar
jeffc
7th Gear
Got mine a couple weeks ago and the OBX + Miltek = A hell of a nice exhaust sound with some bass but not to loud.
Old Aug 27, 2007 | 08:13 PM
jhiggs26's Avatar
jhiggs26
Anybody try Helix's new OBX Header w/300cell High Flow Cat option yet?
Jeremy
Old Aug 27, 2007 | 10:45 PM
MarioKart's Avatar
MarioKart
Vendor
The OBX header is great< almost too good to be true. I paid $1000 for a Larini and it looked like a piece of art but fell apart in 2 months. The OBX feels just as good and has lasted with zero problems for 8 months.
You do the math.
mario
Old Aug 28, 2007 | 08:36 AM
Bahamabart's Avatar
Bahamabart
sums things up nicely
Old Aug 28, 2007 | 09:27 AM
norm03s's Avatar
norm03s
+1 ditto that
Old Aug 28, 2007 | 12:13 PM
littlehandegan
How many of yall are rnning a cat or your stock cat on it? Hard to do,,,exspensive?
Old Aug 28, 2007 | 01:24 PM
Johan's Avatar
Johan
I had Eric weld my stock cat on. It's not that hard if you're handy with metal fabbing or not that expensive either.
Old Aug 28, 2007 | 01:41 PM
Bahamabart's Avatar
Bahamabart
Running stock cat - cost me 45 bucks to do a SS weld on the flange to the cat.
Some don't want to cut up the stock system but are you really going to drop the dime to remove yr header and put on the stock header when you sell the car? I say cut it and use it - when it goes buy aftermarket.
Old Aug 28, 2007 | 04:11 PM
jeffc's Avatar
jeffc
7th Gear
I came close but opted for the the stock CAT based on sound. I just didn't know how loud the high flow CAT would make my car.
Jeremy
Old Aug 28, 2007 | 04:50 PM
jhiggs26's Avatar
jhiggs26
Thanks for the exhaust note tip Jeffc.
Does anybody know if there might be an emission problem with running a higher flow cat?
Jeremy
Old Aug 28, 2007 | 09:02 PM
ThumperMCS's Avatar
ThumperMCS
Jeremy
There might be, depends on how "high flow" it is I spose. I'm pretty sure mine is gone though, it smells like its cat-less. I have no way to check though as I use an O2 simulator and I had the cat is welded in without a flange...stupid me.
Old Aug 29, 2007 | 07:22 AM
norm03s's Avatar
norm03s
I have both OEM 02 sensors in place with an after market CAT. The ECU and #2 02 sensor will tell on you if the CAT isn't doing it's job. Mine was tested in July and it passed. Check out my gallery pictures to see CAT setup.
Old Aug 29, 2007 | 04:58 PM
jhiggs26's Avatar
jhiggs26
I'll check out your gallery. Sorry to hear about your smelly exhaust ThumperMCS. I'll flange my cat in so I can swap it out when it runs its course.
Jeremy
Old Aug 29, 2007 | 05:16 PM
Diosdado's Avatar
Diosdado
Is there any problem with the header and stock cat with the M7 USS? My stock header precat rubs against one of the bars and I'm curious if anyone has had problems with the OBX.
Old Aug 30, 2007 | 09:20 PM
markldriskill's Avatar
markldriskill
I have the OBX w/stock cat and Milltek. I love it.
As far as the USS, I think I remember reading (a long time ago) both that the USS can rub on some headers (or catbacks) but also that it is fixable. Not sure. Call Peter at M7, and he can probably answer questions about the USS and various exhausts.
Old Aug 30, 2007 | 09:34 PM
jimz68's Avatar
jimz68
I'm running a ceramic coated OBX with the stock cat and the One-Ball exhaust.
Like others , I'm totally happy with the set-up.
I found a stock system on e-bay for $75.00!! with less than 5000 mles on it. Had the guys at Bay Bridge Motors in Oakland ,Ca do the cut and weld.
Jim
Old Sep 2, 2007 | 05:37 AM
norm03s's Avatar
norm03s
Jim
Looking good thats the way to do it jimz68
Only one thing I would add are a couple of flat washers, one between the bolt head to spring and spring to flange.
Old Sep 2, 2007 | 08:32 AM
jimz68's Avatar
jimz68
Thanks! Kind of hard to see in the photos, but there are flat washers in the spots you metioned. I replaced all of the OBX supplies hardware with stainless. And the bolts that came with the header were too short. System has been on for about 6 months with no rattles, leaks etc.
(now watch,because I said that, the whole bloddy thing will fall off on the freeway. )
Jim
Old Sep 13, 2007 | 06:02 PM
norm03s's Avatar
norm03s
Jim
Na you did it right
Old Sep 13, 2007 | 06:08 PM
jimz68's Avatar
jimz68
Na you did it right
Thanks, again! Still hangin on there.
Forgot to mention, when I did the install, I replaced the two end header flange bolts with Nissan studs (14065-V5004) and Nissan lock nuts (14039-W1500). Much easier to install with the header held up by the studs while you thread in the bolts.
Jim
(Nissan Parts Tech )
Old Sep 13, 2007 | 09:03 PM
scolburn79's Avatar
scolburn79
Hey guys, I might be a bit Stupid for asking this question, but what does the Ceramic coating that you guys get done on the Header actually do? Are the OBX Headers off E-Bay Ok to buy? Or are they a ripp off of the real thing? Thanks in advance
