Drivetrain Pulley Install Question
Old Aug 15, 2007 | 07:56 PM
EDM's Avatar
EDM
Hey guys, official Pulley Instal post number 12,358,214 here! I've searched and searched but i had just a couple quick specific questions regarding the install (the instructions are quite broad).
I purchased the Minimania -15% ,3 peice pulley (im sure your familiar).
Edit: I dont think its the self aligning pulley. (which i think is what's pictured) The center hole is the same thickness all the way through
1. When installing the pulley it instructs to gap it .185" , this measurement is taken from the back of the black outer pulley surface, correct? Meaning the rear collar is to be pressed fully to the hub?
2. It also says tighten each bolt to 70 inch pounds, should i really get a torque wrench and be specific or hand tighten it as well as possible without really pushing it?
Sorry to ask a million questions, but everyone seems to know their stuff.
Pic for ref.
Old Aug 15, 2007 | 07:59 PM
El_Griton's Avatar
El_Griton
not sure about #1, but #2 you should mos def get a torque wrench. its a specific # for a reason.
Old Aug 15, 2007 | 08:47 PM
EDM's Avatar
EDM
NAPA rents em. ill be sure to get one
Old Aug 16, 2007 | 07:12 AM
EDM's Avatar
EDM
ttt
Old Aug 16, 2007 | 07:31 AM
ignote's Avatar
ignote
I purchased the Minimania -15% self-aligning, 3 peice pulley (im sure your familiar).
Pic for ref.
1. I'm pretty sure that in the Minimania install instructions it says that you are suppose to measure the distance between the stock pulley and the supercharger casing prior to removal and set the new pulley on the shaft based on this measurement.
2. You should use a torque wrench.
Old Aug 16, 2007 | 09:47 AM
Mini Works's Avatar
Mini Works
1) This is a picture of the New Mini Mania pulley, these are self aligning, no need to measure, just make sure you run the inner piece all the way onto the shaft before you start tightenning the bolts.
2) the torque specs are a recommendation, based on the size of the bolts, you do not want these loose or too tight.
Do not forget to tighten the bolts in sequence.
hope this helps
Old Aug 16, 2007 | 10:07 AM
UKSUV's Avatar
UKSUV
Hey EDM...so you did get it! As I recall... there is a gap measurement in the instructions. I really didn't read it though so I don't know what it was referring to. Good luck and hope you like it!
Old Aug 17, 2007 | 08:21 PM
EDM's Avatar
EDM
ttt, i dont think its the self aligning now that i look at it, the center hole is the same all the way through
Old Aug 17, 2007 | 09:12 PM
Mini Works's Avatar
Mini Works
If you have the first generation pulley,
you really need be careful with the gap,
make sure you measure the gap of the old pulley,
then compare to the Mini Mania recommendation.
The goal is to align the pulley, so there is no issues with the belt.
Good luck
Victor
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
