Drivetrain Found 2psi of boost today and it was cheap?
Old Aug 8, 2007 | 10:35 PM
MarioKart's Avatar
MarioKart
Vendor
Today I just installed my new blue Alta intercooler "boots" from John at www.t-rexmotorsports.com. They took some time to fit them on because they fit so tight. About a month a go I added an air to water intercooler but was bothered because I had lost 3psi of boost in 3rd gear even though the car ran stronger and didn't become heat soaked because of the lower intake temps. After installing the Alta boots I nocticed I was hitting 16psi again still one psi less than when I had the stock intercooler. The boots really seem to make a tight seal letting no air out and they add some flair to the motor. I thought it was a cool and cheap mod that helped in many ways including recovering some lost HP's
Mario
Old Aug 8, 2007 | 11:22 PM
YakiMini's Avatar
YakiMini
I'm glad to hear that you got some back!
Old Aug 9, 2007 | 12:45 AM
JSWMCS's Avatar
JSWMCS
i'm glad you got the little beast back in order!!
did emile tune it again? for the new intercooler.
-john
Old Aug 9, 2007 | 05:02 AM
Aeromax's Avatar
Aeromax
3 psi is quite a bit. I'd think the MINI would throw a CEL if it was losing air somewhere between the engine and the map sensor, but I guess not...
Old Aug 9, 2007 | 07:48 AM
MarioKart's Avatar
MarioKart
Vendor
It was 2psi not 3, but I didn't even through a code when the whole intercooler pulled off and made a horrible sound. I'm just happy to get some power.
Old Aug 9, 2007 | 09:19 AM
Nitrominis's Avatar
Nitrominis
Very COOL. I have had my share of customers that do there own mods and then show a power loss. A simple task of re checking ALL the hoses usually reveals a snug but not tight under pressure hose. Good Tech Tip for Everyone. Now you a have a Tuner Trick !!!
Old Aug 9, 2007 | 10:44 AM
MINIdave's Avatar
MINIdave
So, you lost 2 psi adding the new intercooler because of loose hoses?
Wouldn't tightening them up have brought you back to where you were? I guess I'm a little confused...............
Old Aug 9, 2007 | 09:07 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Hey glad those worked out! WOW 2 psi for less than $40! Can't beat that! Keep us posted on other magic mods!
Thanks for the post!
Old Aug 9, 2007 | 09:48 PM
MarioKart's Avatar
MarioKart
Vendor
I lost 3 psi because the new air/water intercooler. The a/w intercooler has a denser charge and I guess it is normal to loose some boost because of the colder air going into the motor. I gained back 1.5psi to 2psi because the Alta boost are a MUCH tighter fit than the OEM ones. One of the reason the OEM were leaking was because the intercooler has a slick powder coated finish causing the OEM ones to start moving around.
Because of the colder air going into the motor now I still lost 1psi but the car pulls harder and doesn't heat soak at all, at least for my driving style, location, mods and ocean cool weather.
M
Old Aug 9, 2007 | 10:30 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
That sounds like an easy fix to your problem Mario. Glad it worked that well.
Old Aug 10, 2007 | 06:58 AM
Bahamabart's Avatar
Bahamabart
a good reminder for all of us that the smallest part can work against us.
Old Aug 14, 2007 | 10:19 PM
motonikki812's Avatar
motonikki812
You know you want to put that damn 17% pulley back on to get that 1psi back..... Or maybe your 2%......
Come on do it... do it...do it....
Call me. JC
Old Aug 15, 2007 | 10:38 AM
MarioKart's Avatar
MarioKart
Vendor
Call me. JC
Where have you been??? No calls or love lately :-( I still have the 17% on there, sometimes I think about doing the Alta 1% or 2% but I had horrible luck with crank pulleys.
Anything new on your car?
Old Aug 17, 2007 | 11:44 AM
otisg5's Avatar
otisg5
MAX PSI
What is the MAX boost/psi you can get out on stock internals? I have the '03 MCS with JCW intake.
Old Aug 17, 2007 | 11:48 AM
jymontoya's Avatar
jymontoya
So you hit 16psi in third gear with this a/w intercooler and 17% pulley?
Old Aug 17, 2007 | 11:54 AM
MarioKart's Avatar
MarioKart
Vendor
Some guys are hitting 22 to 25 psi of boost on a stock motor with turbo only or twincharge kits.
I have heard 280whp is the max on stock pistons
Old Aug 17, 2007 | 12:00 PM
MarioKart's Avatar
MarioKart
Vendor
Yes I do, with the stock intercooler I was hitting 17 to 17.5 psi. I think I have a fairly strong superchrger. I know some are only hitting 14 psi with a 17%
Old Aug 18, 2007 | 11:41 PM
silver arrow's Avatar
silver arrow
Alot goes into what boost you see on the gauge. Some guys may only see 14 psi due to the location that they tapped for the boost gauge or the altitude they live at.
When you switched to the A/W intercooler, you may have lost boost, but were probably making more hp. If you had a boost leak loosing 2-3 psi you would hear it.
I you needed in to fit better, it is much cheaper to just flare the connections.
bneer
Jul 15, 2019 04:41 PM
SunnySideUp
11
Aug 26, 2015 06:42 AM
HaveATank
Aug 24, 2015 10:26 AM
tylewis
Aug 18, 2015 06:53 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
