Drivetrain hissing sound after instaling megan header
Old Jul 15, 2007 | 09:53 AM
ducho99's Avatar
ducho99
I installed a Megan header with a stock and I have a hissing sound after 3000 rpms. I have a one ball exhast and the there is no exhast leaks
I think it"s the cat
It's driving me crazy becase it sounds like a street sweeper driving down the the block
Old Jul 15, 2007 | 03:28 PM
JSWMCS's Avatar
JSWMCS
you have an exhaust leak! if there aren't any leaks from the cat back. then the header is leaking at the block. did you use a new stock gasket?
and evenly torque the bolts??
maybe the header flange is warped??
Old Jul 15, 2007 | 04:01 PM
jibeho's Avatar
jibeho
I have to thoughts you have an exhaust leak or there is a cat stuck under your ride
Old Jul 16, 2007 | 05:48 AM
ducho99's Avatar
ducho99
There are no leaks from the cat back.
I took the header off and looked at the gasket and it was fine
The thing is when a check for leaks the car is at idle I don't have anyone to rev the engine
So you guys don't think it's the cat?
I have off this week so I going to take the whole system apart and check everything
Old Jul 17, 2007 | 08:11 PM
ducho99's Avatar
ducho99
bump
Old Jul 17, 2007 | 08:43 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I'll repeat: you have a leak. The only way to check is to go to an exhaust place, they will lift your car on a hoist while it is running, and then check all parts with a special stethiscope (sp?). I guarantee it's a leak, and not the cat.
Oh, yeh, btw I have a Megan header, and both of them leaked (the first one, and the one I have now for 8k miles)
Old Jul 17, 2007 | 10:27 PM
ChrisW's Avatar
ChrisW
Its a leak, everyone i know who has the megans header has a leak. Don't ask for help if your not willing to use it.
Old Jul 18, 2007 | 12:12 AM
draggonmann's Avatar
draggonmann
I just started having the same problem with mine. I found the leak in mine was in the expantion joint.
Old Jul 18, 2007 | 05:14 AM
ducho99's Avatar
ducho99
I'v taken the header off twice
took the car to the muffer shop to fix all the leaks on the exhaust
Draggonmann what did sound like?(the leak)
I think when they welded the cat the exhaust is to long there is very little play
I am willing to use the help but like I said I fix all the leaks and the car still sounds like v Bug
Old Jul 18, 2007 | 05:45 AM
sprp85's Avatar
sprp85
Check the car while its fully warmed up.....
fixed bunch of exhaust , header noises by doing that..
Old Jul 18, 2007 | 05:52 AM
DrPhilGandini
OK, so it's a leak. But where... The Megan flex joint is particularly low quality and very short for our system. Both my Megans leaked there. Best bet is to get a different header, but that's costly. In the mean time you could wrap the flex joint with header wrap. It will reduce the noise a little. How many miles on your header? My second one stopped leaking badly after 1000 miles--it sort of "bedded in." Still leaks a little.
Also, as the exhaust heats up it expands--a lot. Mine gets almost 1" longer when excited--ah, I mean hot. (I know I'm revealing way too much here...) This can put a lot of stress on the flex joint causing it to leak even more. It also causes other joints/flanges to leak when they would not when colder.
good luck finding the problem.
Old Jul 18, 2007 | 06:10 AM
JCL_06MCS's Avatar
JCL_06MCS
Hey Tony, I just had the same problem on my Megan header, It winds up its the flex joint thats leaking on mine, Since i only got the header 3 months ago i called Megan and they are glad to send me a replacement in 2 to 3 weeks, the reason for the wait is that they are coming out with a new design that flows better and they arent in stock yet.
Charlie
Old Jul 24, 2007 | 03:28 PM
ducho99's Avatar
ducho99
Thanks guys like you said it was the flex joint
The thing is that is was leaking from when I installed it, thats what I couldn't under stand'so I thought it was the cat
I did three track days this week at pocono for a total of 15 sessons and the flex joint is done
My car sounds like and old beat up truck
I wish I never installed it
live and learn
squawSkiBum
Oct 2, 2015 09:21 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
quickquest88
Aug 8, 2015 08:45 PM
