Drivetrain Aircon will not kick in.
Old Jul 9, 2007 | 12:59 PM
fozworth's Avatar
fozworth
I have climate controle on my mini and the air con isnt comeing on.Ive emptied the system when we took the motor out,but have had it profeshionaly refilled .There is power going to the pump and a aircon specialist basicaly hooked my car up to his fault find computor and said that when he press'es the aircon button in the car his computor shows the signal being sent to the ECU to switch the aircon on but the ECU is saying no it wont do it.I had new JCW software flashed onto my ECU to go with the replacment engine but i cant see why its not working.The only thing i havent yet checked which he has told me to ,is the presure switch.Other than that does the aircon need to be recoded in by a main dealer .
Old Jul 9, 2007 | 03:11 PM
Longboard Mini's Avatar
Longboard Mini
Man you are having a bad week. I can't help but good luck.
Longboard
Old Jul 10, 2007 | 02:34 PM
ChocolateAZ's Avatar
ChocolateAZ
I just burned my main radiator fan out(got some debris stuck so it couldn't turn.) I noticed that the AC wouldn't work. When I looked it up in the Bentley manual they said that there are two relays for the fan, a low speed(located in the fuse box under the bonnet) and a high speed(located on the fan shroud). When you turn ont he AC there is a pressure switch that turns on the radiator fan via the relays. 8 bar for low speed and 18 bar for high speed. If that switch or the fan/relays don't work correctly the AC turns off.
Hope this helps!!
Old Jul 11, 2007 | 12:43 AM
fozworth's Avatar
fozworth
I must test the switch,going to need to remove my induction kit i think to get to it.
Filmy
15
Jun 6, 2023 06:27 AM
RobbyD
Jan 29, 2019 01:22 PM
Pker
Apr 11, 2017 12:14 AM
brads2002
Oct 14, 2015 06:53 AM
Redhotz
R55 :: Clubman Talk (2008+)
Sep 22, 2015 09:41 PM
