Drivetrain Post JCW CAI - Check Engine lights up
Old Jun 7, 2007 | 11:18 AM
Phurbahl's Avatar
Phurbahl
I installed a JCW CAI in my wife's '06 Cooper S Convertible the other day. It works fine and she is very happy with the performance boost.
Now, however, her check engine light comes on and I get a code of P0030 - HO2S Heater Control Circuit. Since I had to splice into a wire to do the install according to instructions does anyone know if that wire (white/red from pin 113) is specific to the error code or is the issue unrelated?
Old Jun 7, 2007 | 02:57 PM
Crashton's Avatar
Crashton
I believe that's something to do with the oxygen sensor. Since you have an 06 why not take it to the dealer for a bit of warranty repair.
Old Jun 7, 2007 | 04:08 PM
BFG9000's Avatar
BFG9000
That's the code for the heater in the first O2 sensor (in the header before the cats). If you unlatched the ECU connectors or installed the pin incorrectly, something may not have seated completely.
Old Jun 7, 2007 | 08:12 PM
littlecS's Avatar
littlecS
+1!
Those plugs for the ECU can be a real pain in the you know what if not done correctly. It took me 10 minutes of figuring it out how it works and I am usually pretty good at figuring out how things come apart and go back together.
Old Jun 8, 2007 | 06:52 AM
Phurbahl's Avatar
Phurbahl
Thanks much. The flap works so I know the pin to the fuse block and the vacuum tubes are seated OK but not sure about the ECU. I'll pull it back out, make sure the pins on it aren't damaged, reseat it, and hope it resolves. If not then off to the dealer we go.
Old Jun 8, 2007 | 09:20 AM
Crashton's Avatar
Crashton
I'd bet it just coincidence that the engine light came on just after the JCW CAI install. By all means check the ECU plugs, but my money says it's unrelated.
Old Jun 8, 2007 | 11:05 AM
Phurbahl's Avatar
Phurbahl
Hehe... Yeah, it's funny how something always happens after you have done manual work on anything...
Old Jun 8, 2007 | 01:01 PM
Crashton's Avatar
Crashton
Funny yes, but also frustrating as all get out. Hope the dealer fixes you up ASAP!
Old Jun 12, 2007 | 07:23 PM
Phurbahl's Avatar
Phurbahl
Well I rechecked all the connections and didn't see any issues so I took it in to the dealer who found the loose wire in the fuse area I missed. $135 lesson in "how to be thorough"...
Sexual Chocolate
Mar 31, 2019 08:02 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
