Drivetrain 15% pulley, best belt?
Old Jun 1, 2007 | 04:21 AM
msjulie33's Avatar
msjulie33
My S has an Alta pulley and stock belt and all is well When ordering a replacement belt, it is better to get the stock size for a JCW kit or the regular old stock size for an S? I'm of the mind that the JCW belt is better since it is sized for a smaller diameter pulley but are there things I didn't consider?
thanks
Old Jun 1, 2007 | 05:26 AM
NMgokart's Avatar
NMgokart
Shorter belt for smaller pulley; makes perfect sense to me. Go with the JCW.
Old Jun 1, 2007 | 09:50 AM
polizei's Avatar
polizei
You can run either the JCW or a stock belt. I'm currently running a stock belt with my M7 16% pulley, and it hasn't slipped once. You can also go aftermarket, like a Gator belt.
-Cody
Old Jun 1, 2007 | 03:51 PM
BRGPA's Avatar
BRGPA
Detroittuned has a Gates belt that is a bit shorter than stock that will work perfectly with the 15% Alta. I changed mine earlier in the spring- kept the OEM for a spare. They also carry the gatorback.
Old Jun 1, 2007 | 04:27 PM
Bigcoyote's Avatar
Bigcoyote
You can run stock or JCW -- I got the JCW from the dealer when I changed to the 15% -- it was cheap
Old Jun 1, 2007 | 05:03 PM
msjulie33's Avatar
msjulie33
is there an advantage with the gatorbelt? Detroittuned suggests it's 'tougher'? thanks
Old Jun 1, 2007 | 05:57 PM
herbie hind's Avatar
herbie hind
go gator back by goodyear? i think . do a search ;there's tons of info on it here . auto zone's got um . i've had napas stretch but the gatorback didn't .
Old Jun 1, 2007 | 06:35 PM
polizei's Avatar
polizei
When I did research, I heard the Gatorback by Goodyear was the best belt to get, but I also heard it comes with a little sound....so if you want a quiet car, don't go with it (though I'm no sure exactly how loud it is). From my understanding, the Gatorback belt is suppose to be stronger and anti-slip, so a lot of people recommend them.
-Cody
Old Jun 1, 2007 | 06:49 PM
kapps's Avatar
kapps
Looks like we need a sound clip from someone who uses one...
Old Jun 1, 2007 | 07:01 PM
herbie hind
it is louder ;but it serves well to scare the 07s.
Old Jun 2, 2007 | 04:29 AM
msjulie33's Avatar
msjulie33
thanks, i'll look into it - the supercharger whine is pretty pronounced so unless this belt is really loud, it sounds worth it to have a stronger belt.
Old Jun 2, 2007 | 04:37 AM
msjulie33's Avatar
msjulie33
reading more about LOUD BMW's using the goodyear replacement timing belt makes me wish someone would post a sound clip of a MINI with a gatorback
Old Jun 2, 2007 | 07:44 AM
jibeho's Avatar
jibeho
I'll try to get one for you but we have company this weekend. Yes the Gatorback is much louder then stock. I'm using the 4060537 on my 17% setup. What you will get is a noticeable wine from the belt from idle to about 3000 then the wine shifts for the SC. I sort of like it. BTW my TDI NB has a GB timing belt and sounds similar.
Funny thing is the packaging says "The Quiet Belt"
Old Jun 3, 2007 | 10:21 AM
jibeho's Avatar
jibeho
Here you go. I used my cell phone and sat it on the passenger side strut tower.
This is the best I could do.
WAV Format File 500k
Old Jun 9, 2007 | 05:54 PM
msjulie33's Avatar
msjulie33
thanks, it's hard to tell but it doesn't seem all that scary
Old Jun 9, 2007 | 06:35 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Gatorback! Get one and you'll be problem-free for a long time with a 15%.
I've had a Gatorback on my 15% for more than one year, and it still looked like new.
I changed for a 19% 5 months ago and got the NAPA belt from Helix installed at the same time. It began to slip 2 weeks ago and was badly damaged. I got another Gatorback and I am sure it will be good for a lot longer than the NAPA... I did not take the car to a track or abused the NAPA belt. I rarely go above 6000rpm and only got it once to 7200rpm (for a dyno)...
Bottom line, get a Gatorback!
Old Jun 10, 2007 | 12:42 PM
vasmal's Avatar
vasmal
What is the Goodyear part number for the Gatorback for the 15% pulley?
Old Jun 10, 2007 | 04:44 PM
thebillsman's Avatar
thebillsman
yeah vasmal ive been looking for the same answer, i went with an Alta V2 15% and im looking for the best fit belt part number
Old Jun 11, 2007 | 02:58 PM
thebillsman
Goodyear Gatorback part number for a 15%..?
Old Jun 12, 2007 | 05:01 AM
jibeho's Avatar
jibeho
See post #8
https://www.northamericanmotoring.co...ight=GatorBack
Old Jun 12, 2007 | 05:15 AM
daflake's Avatar
daflake
I'll second that!
Old Aug 10, 2007 | 08:21 PM
ignote's Avatar
ignote
I just put on the 4060537 Gatorback belt with my 15% pulley. The tensioner thingy shows one full hole. The belt works good and is not that loud.
Old Aug 11, 2007 | 01:43 PM
trackster's Avatar
trackster
Many people have gotten better results withthe stock belt over the JCW. If you go 15% you can still use the stock belt with no issues.
Old Aug 11, 2007 | 04:57 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
If you do stick with the stock belt make sure the tension is still within spec.
Make sure that you can see at least half of the index hole like in this picture.
Old Aug 11, 2007 | 06:37 PM
Crashton's Avatar
Crashton
My stock belt has 25,000 miles on it. 20,000 of those with an Alta 15% pulley. No issues what so ever. I'm planning to replace the belt at 30,000 with the JCW belt.
