Drivetrain Boost Guage or Vac/Boost Guage...
Old May 22, 2003 | 08:08 AM
Super_MINI's Avatar
Super_MINI
With the supercharged engine is there ever Vacuum or is it always pressurized? I want to install a Boost guage but they also sell a Vac/boost guage that will show vac in the system if their is any and then boost when it's pressurized. Where can you tap in and get boost pressure?
Old May 22, 2003 | 08:36 AM
Eric_Rowland's Avatar
Eric_Rowland
Go for the Vac/Boost gauge - you normally will run 18-22 vacuum, and only boost when you're into the throttle. On my supercharged miata I'm amazed at how little I actually get into boost. Sure fun when you do, though. :smile:
There should be several places to tap into - cruise, or any convenient vacuum port. Don't know for sure 'cause I'm still a MINI wanna-be. But someday soon...
Old May 22, 2003 | 08:45 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Definitely vacuum/boost. I used the vacuum line between the intake manifold and the fuel pressure regulator. I didn't need to cut anything, just removed the line from the manifold nipple, put the line onto a tee, and ran one piece of hose back to the nipple, and another hose to my boost gauge.
Old May 22, 2003 | 10:08 AM
red03miniS's Avatar
red03miniS
you can get the promini gauges and do plug and play :smile:
Old May 22, 2003 | 10:25 AM
Super_MINI's Avatar
Super_MINI
Yea, but for $475? The guages they use are the Autometer Ultra-lite guages, they cost less than $50 each from jegs.com and I can buy the Alta Guage holder for $160. That's what I plan to do. I may even fabricate my own guage holder and save myself $150. More money for ECU upgrade!
Old May 22, 2003 | 01:01 PM
itsthesize's Avatar
itsthesize
Does anyone know if any of the gauges used by ricers work on the MCS? Especially the ones on the drivers side windshield frame.
Peter
Old May 22, 2003 | 05:23 PM
caddman's Avatar
caddman
ctually the guages are moe expenisive than that you looked at the mechanical guages, the promini comes with electrical guages, check again!!
Old May 23, 2003 | 06:31 AM
Super_MINI's Avatar
Super_MINI
Dooooh, guess I should have paid more attention when I was reading the catalog. You are correct. Electric Oil pressure guage is about $56 but the electric boost guage is about $187. That makes a big difference! Makes me wonder though, is the electronic boost guage that much better? I know it has some nice features on it but should the mechanical one work just as well?
Old May 23, 2003 | 06:42 AM
andy@ross-tech.com
Electronic boost gauges have two advantages, in my experience:
1) They do not buzz as mechanical gauges do. The supercharger creayes pulses that cause the mechanical gauge's needle to vibrate and make noise. I spliced in a fuel filter in-line with the gauge line to alleviate this condition.
2) Electronic gauges usually have peak-hold or "telltale" to let you know how much peak boost you had. Some gauges like Defi have a 40-second playback so you can watch exactly what happened when your engine blew up. Again and again.
Old May 23, 2003 | 08:04 AM
jlm's Avatar
jlm
supermini:
I have a perfectly good -15,+15psi autometer 2-1/16: electronic gauge, complete, I can make you a deal on. Same gauge as in the Promini kit.
Old May 23, 2003 | 08:13 AM
Super_MINI's Avatar
Super_MINI
>>supermini:
Ok, have you used it and why you getting rid of it?
Old May 23, 2003 | 12:23 PM
jlm's Avatar
jlm
my car exceeds 16 psi. the gauge is used and i want $125
Old May 23, 2003 | 01:48 PM
Super_MINI's Avatar
Super_MINI
Ummmm, will I have the same problem if I've replaced the pulley?
Old Oct 25, 2003 | 10:22 PM
Yuri's Avatar
Yuri
Just installed the autometer Boost/Vacuum gauge and the needle only stay in Vac side. When Idle is 18 in.Hg and when full throttle the needle back to Zero. Never goes to boost side. Why?
I got the defective gauge or I hook up the tube to the wrong place?
Please help.
Thank.
Yuri
Old Oct 26, 2003 | 03:56 AM
InfoSec's Avatar
InfoSec
Question .... If you are going to install a Vac/Boost gauge on a MCS with a 15% Reduction Pulley how much psi does the gauge have to capable of reading. From the postings I think that 15psi boost gauge will fall short.
Cheers
Old Oct 26, 2003 | 04:04 AM
jlm's Avatar
jlm
righto; you need the 30psi (also an Autometer electric) gauge if you have the pulley...my car has indicated 18psi max. 20 would have been sufficient, but that max range is not available from Autometer.
Old Oct 26, 2003 | 06:15 PM
BlueThunder's Avatar
BlueThunder
All of the Pro mini guage kits now include the 30PSI guages. They are all Electric with high boost memory, and programable over boost warning light. The kit is pre assembled and fairly easy to install. Wires are all plug & play.
With cars now getting into the 20 psi boost range, a 30psi guage is the best choice.
If you want to see the guage in action, watch the video! Note cameraman was having a little trouble holding on.See the boost!!!
Old Mar 1, 2004 | 01:41 PM
MSFITOY's Avatar
MSFITOY
Andy, do you have a schematic showing where these lines are?
Thanks,
Sid
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
mbatech
Sep 10, 2015 03:40 PM
