Driver's School Discuss tips, techniques, and schools for enhancing the driver portion of the performance driving equation.
SCDA HPDE Schedule
Old Nov 9, 2017 | 05:57 AM
  #2601
gkp's Avatar
gkp
Originally Posted by veggivet
I bet Eddie07 can swap out for the dual mass flywheel in between track sessions with his tool kit...
Old Nov 16, 2017 | 06:01 PM
  #2602
Eddie07S's Avatar
Eddie07S
Hmmmm, I might need a few more jack stands than I usually bring if I am going to change a clutch.
Old Nov 17, 2017 | 04:23 AM
  #2603
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
any of you running wilwood dynalite? WHat pads do you like?
I tried 7816 BP-40 last weekend and they felt great but I destroyed a set, they still had 2mm of pad but that is cutting it close for just one weekend.
I'm thinking about trying one of the ST pads, like the ST43, I do not like gloc/carbotech as they do not last for me either, and DTC60 make that horrible rusting brake dust
Old Nov 17, 2017 | 10:13 AM
  #2604
veggivet's Avatar
veggivet
More than welcome to borrow mine for the hour or so this will take you...
Old Nov 17, 2017 | 05:27 PM
  #2605
Eddie07S's Avatar
Eddie07S
Yup, me, I am.
And yes, wear is an issue with these because they are a relatively low volume pad size. I have never used the BP-40 pad. Right now I have been using the DTC60. They are hard on rotors; hence the rusty brake dust. The Wilwood Poly H worked well for me too. A little less aggressive on the rotors than the Hawks. I went away from them because I thought I might be getting deposits from them. However with the added cooling I have I may try them again or the Poly B pads.
This brake setup seems to be sensitive to having enough cooling. The pads will last longer with more cooling. I have done 3 days at WGI on one set of pads with no issues with thickness. WGI is hard on brakes with a lot of heat, but there are only 11 turns in 3.4 miles so wear isn’t too bad. I did 2 days at Palmer and saw quite a bit of rotor wear with the Hawks, but the pads did well, which I attribute to the added cooling.
I typically have at least one set of new pads as spares, plus 1 or 2 sets of used pads and one full set of front rotor assemblies when I go to a track event. I have worn out, cracked and/or warped rotors and worn out a set of pads at track events. I have had too many brake issues to not bring this stuff.
All of that said, I would recommend the Wilwood Poly H pads.
One last thing. While you and I seem to have a big difference in getting heat into our rear brakes, you might want to see if you can move some more of your braking moved to the rear brakes to take some of the load off the front brakes. I know that has helped me with front pad wear. I would think that the Gen 2 JCW rotors and caliper brackets would fit your car. That larger rotor in the rear would do that for you. Just a thought
Old Nov 18, 2017 | 06:12 AM
  #2606
gkp's Avatar
gkp
I've been running Carbotech pads for years and like them. More recently I tried G-Loc pads, the brand started a few years ago by the founders of Carbotech. They are virtually identical to Carbotech. I did go with Wilwood pads (I forget the model #) for a day or two, after I installed the Wilwood brakes, but they seemed to wear out quickly.
Old Nov 19, 2017 | 04:39 AM
  #2607
zre's Avatar
zre
It is with great regret that I have sold my Mini to my cousin. After chasing a lean code for a month I just could not seem to determine the cause. Since this is my DD I needed to replace a dependable vehicle. I bought a 2104 328IX BMW with MSport package. Paddle shifts, M brakes. I still keep a eye on this thread since I hope to meet up you guys at the track.
Even though the car is not gone I already miss the fun of driving it. It will be in good hands since he will be able to store fro winter and determine the reason for the code.
Old Nov 19, 2017 | 05:19 AM
  #2608
Eddie07S's Avatar
Eddie07S
Oh noooooo!
Say it isn’t so.
A very sad day in the MINI world.
Just when this little group was expanding we lose one to their fickleness.
I still hope to do the roll bar in mine.
A 328IX on the track?
Old Nov 19, 2017 | 07:53 AM
  #2609
S-Driver's Avatar
S-Driver
I definitely know how ZRE feels whe he says he’ll miss driving his MINI...., much less attending all the HPDE events with all of you. Life goes on.....we can stil stay in touch.
Old Nov 20, 2017 | 03:01 AM
  #2610
zre's Avatar
zre
Eddie07S, let me when you want to do the roll bar. The Mini is where the roll bar was made so we still have it as a template.
With the M Sport package, which includes the M brakes and X drive this should be fun on the track. Already considering mod setup to make it better.
Old Nov 20, 2017 | 05:00 AM
  #2611
MrBlah's Avatar
MrBlah
with the wilwoods I"m now getting a LOT more heat in the rear, I suspect the added piston surface area on the wilwoods means less pressure on the front pads in relation to the rear. I'm not changing rear pads though I do not get the unsettling in the rear anymore it feels a lot better.
Still tons of heat up front, I have 2 sets of ducts for the front wheel now. I'm going to try the ST pads, but I'm not sure if I should go 43 or 45
Old Nov 20, 2017 | 05:09 AM
  #2612
MrBlah's Avatar
MrBlah
I used a set of g-loc pads, I wont get into the details but they stepped up and covered the pads. I have a set of 12's for R56/R53 jcw fronts for sale
Old Nov 20, 2017 | 05:41 AM
  #2613
gkp's Avatar
gkp
Old Nov 20, 2017 | 06:58 PM
  #2614
Eddie07S's Avatar
Eddie07S
Ha, I knew it. Can’t stay away from the track or from “fixing” the car.
The car needs camber in the front. Even my cousin’s M2 needs camber up front. That is a problem with most street cars.
I’ll let you know when I can do the roll bar.
Old Nov 20, 2017 | 07:01 PM
  #2615
Eddie07S's Avatar
Eddie07S
I wish I could get ducts to my front brakes. I am lucky to have the cooling that I have been able to get.
Old Nov 21, 2017 | 04:57 AM
  #2616
zre's Avatar
zre
It is in the blood, so I guess I need to learn BMW's. Already have design fro front splitter. Need to determine best compromise for the suspension to lower and stiffener but keep some type of ride quality. Have the winter to work on it.
Happy Thanksgiving to ALL!
Old Nov 21, 2017 | 05:02 AM
  #2617
MrBlah's Avatar
MrBlah
I went from bmw to mini, still own a bunch of bmws, the coding side it the same, and working on them is damn near the same especially the r56 and newer vs bmw.
I switched to mini, more fun 99 % of the time, even though they are not as fast on the track than my previous bmw's (M3, 135i) I bet my z4 3.0 is faster than the mini on the track but it's just not the same
Old Nov 21, 2017 | 05:10 AM
  #2618
zre's Avatar
zre
First impressions is the the feel is heavier and do not have the same response. Seat is too soft. I miss my Mini and the quickness, but will have to work on learning to drive this one at speed. Have read a couple of reviews which said this is a decent car on track.
Old Nov 21, 2017 | 05:59 AM
  #2619
MrBlah's Avatar
MrBlah
my 135i was ok, but they go into limp mode if you know how to drive. when I get sick of the mini I'm going back to either a gutted e46 m3 or 135i with lots of cooling & brakes.
The newer bmw's have a lot of code that limits things, like the rear brakes issue, they do not have LSD so they use the brakes to fake it. They knew the brakes would overheat so the car limits engine output after a while. It took years for tuners to figure out all the stuff they have to code out of the 135i to get all of that stuff disabled.
Old Nov 21, 2017 | 06:13 AM
  #2620
zre's Avatar
zre
The car has the M brake package. Also there is a Independent BMW service group locally which runs various models. Will have to spend some time with them to figure out the idiosyncrasy of the car.
Any other information will be appreciated.
Old Nov 21, 2017 | 08:51 AM
  #2621
MrBlah's Avatar
MrBlah
if the m brake package still uses ceramic pistons they cannot handle track use if you are fast. They make stainless piston kits for them
Old Nov 21, 2017 | 08:58 AM
  #2622
zre's Avatar
zre
Old Dec 2, 2017 | 11:24 AM
  #2623
S-Driver's Avatar
S-Driver
Anybody need a Wilwood braided hose and/or Wilwood bleeder valves? Hose is for the fronts.....and I’d imagine the hose is pretty standard.
Old Dec 2, 2017 | 11:31 AM
  #2624
S-Driver's Avatar
S-Driver
Also have some Wilwood Polymatrix pads in nice shape and backing plates that can be placed behind pads that may being wearing uneven or “beveling”.
Old Dec 3, 2017 | 07:03 AM
  #2625
gkp's Avatar
gkp
I'll check if my hose is the same. It's always a good idea to have spare parts around.
