Cleaning Wheels
Old Nov 15, 2006 | 01:09 PM
MaxN's Avatar
MaxN
Reverse Gear
Cleaning Wheels
My Wife has a BMW 325i.
Her wheels are 5-spoke 'Sports Pack' ones, and until recently they looked like new.
Last weekend I cleaned her car and found that I simply could not get the wheels clean, no mater what I tried.
She took it to a car wash a couple of weeks ago, and whatever they use on the tires has combined with the brake dust kickde up in her normal (ie fast) driving to coat the wheels in a random black/grey mess.
I have tried
Car Shampoo and a sponge
Dawn and another sponge
Dawn and a wheel brush
Dawn and a cloth (neat)
Honda Motorcycle cleaner
Purple-Power de-greaser
Clay (partly successful but tedious)
plus various paint scrubs and cleaners.
I am really looking for a spray-on, wash off solution.....
Any ideas ?
Oh - I called the carwash and they said that they use a silicone based spray on the tires and they had never heard of any issues, then went on to blame my wife for using her brakes excessively ?????
Old Nov 15, 2006 | 01:16 PM
oldtrojan66's Avatar
oldtrojan66
Try this link http://www.carcareonline.com/detail....oduct_id=10404 Might be useful
Old Nov 15, 2006 | 01:27 PM
sandtoast500's Avatar
sandtoast500
Thats the stuff I used and I got it from Detailer's Paradise. I took my wheels off and cleaned front AND back, and it took some work to get everything off them. I have 20k mi and two years on them and with a bit of scrubbing with a no-scratch dish sponge, it all came off. I then applied a coat of Epic wax and now everything slides off. Prob do it again in the spring.
Good luck!
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Try this
http://www.detailersparadise.com/Vie...-122521261408#
It may take a little scrubbing from the sound if it. But this is usually a spary on spray off type cleaner.
after your done coat it with a good protectant like Rejex
http://www.corrosionx.com/rejex.html
Old Nov 15, 2006 | 02:48 PM
kenchan's Avatar
kenchan
doesn't every body have a ScratchX in their detailer cart?
try that if you cant get it off with detergents.
Old Nov 15, 2006 | 03:19 PM
MaxN's Avatar
MaxN
Reverse Gear
Sctrach-X does not touch it - I tried that too
Going to try goof-off when I get home tonight (reccomened by an OCD car nut in the office), if that fails I will start buying from the above links.....
Old Nov 15, 2006 | 03:33 PM
CooperSS's Avatar
CooperSS
I had that problem with my original white S-Lites.
A friend that had a car detailing business stopped by and spent a little time trying to remove those pesky black spots.
Tried a lot of different products from his professional detailing supplies and ended up using Meguiar's #83 I believe. It is slightly more abrasive than Scratch X. It takes some elbow grease, but the stuff finally came off.
Bill
Old Nov 15, 2006 | 04:18 PM
El_Jefe's Avatar
El_Jefe
I recommend 100% getting a natural boar's bristle brush for weekly cleaning (or wheenver you wash, I wash weekly it seems) Griot's has a fantastic short handled one that is verty soft and the bristles are long. It cleans off my wheels with mild griot's wheel cleaner really well. You should do what octaneguy recommends and use quick detailer after you use your car on the rims. It made my wheels look day 1 from day 1. Theres not a bit of anything on them normally, they gleam.
bling.
Old Nov 15, 2006 | 05:46 PM
kenchan's Avatar
kenchan
long handle is better. the short handle sprays your face & arms & legs
with the brake dust contaminated soapy water.
Old Nov 15, 2006 | 06:05 PM
El_Jefe's Avatar
El_Jefe
for me, that's a turn on.
Old Nov 15, 2006 | 06:11 PM
justintime's Avatar
justintime
hahaah
Old Nov 15, 2006 | 07:00 PM
kenchan's Avatar
kenchan
lol! ...ok like your gf sneezing in your face? yuk
Old Nov 15, 2006 | 07:48 PM
Mark C.'s Avatar
Mark C.
LMAO!
Old Nov 16, 2006 | 06:20 AM
lotsie's Avatar
lotsie
Have you tried Simple Green? I've used it to get some very bad crud off my wheels.
Mark
Old Nov 16, 2006 | 09:31 AM
kenchan's Avatar
kenchan
^^ lotsie send that pict to SimpleGreen for them to use in their ads!
Old Nov 16, 2006 | 09:41 AM
lotsie's Avatar
lotsie
The stuff really does work
Mark
Old Nov 16, 2006 | 09:59 AM
kenchan's Avatar
kenchan
^^ yah, during my last oil change on the Legacy i accidentally dripped
some oil when i was transferring old oil into my recycle container.
I wetted down the driveway and sprayed SG liberally... waited about 2min
agitated with a deck brush, and hosed off.
Old Nov 16, 2006 | 10:50 AM
jwardell's Avatar
jwardell
It all depends on what you have. But I'm guessing whatever you have is baked in, which may not be possible to remove.
Simple green will get off anything grease-based (tar for example).
P21S/a good wheel cleaner will remove brake dust.
Both should be allowed to soak for 5 minutes and then need some scrubbing.
But baked in brake dust and paint stains are going nowhere.
At that point you might want to try a Mr. Clean Magic Sponge. It is abrasive, so not a good idea to use regularly. But perfect for that end-of-season cleanup.
But it may be in the paint, and you have nothing you can do but a repaint. This is why it is important to clean the wheels with P21S/a good wheel cleaner regularly, so nothing is there long enough to bake in.
Old Nov 16, 2006 | 11:03 AM
rivet's Avatar
rivet
I have used P21S for a few years now and swear by the stuff. It works wonders on your wheels and saves the knees and back.
Old Nov 16, 2006 | 11:49 AM
MiniMaybee's Avatar
MiniMaybee
I think the P21S is good stuff too, but expensive. In my mind an ounce of prevention beats a pound of cure. Get them clean, put a good synthetic wax on them and then keep them clean. There's my $0.02!
phrza81
Oct 10, 2015 11:37 PM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
jrezzo
Aug 9, 2015 10:32 PM
IstanBucket
Aug 8, 2015 02:25 PM
