First Wash, Not Rich
Old Mar 2, 2005 | 09:11 AM
E1Designs's Avatar
E1Designs
Ok, new MINI, first wash...not a wealthy guy, so keep that in mind. :smile:
Should this suffice for now?
http://www.nacarcare.com/son-psbase-kit.html
Doing each step in that kit, then later on grab a top coat kit? The above kit shoujl dprovide a pretty sassy looking ride correct? the top coat kit's are to create an even richer/glossy look if I have read things correctly.
Thanks As Always...
Old Mar 2, 2005 | 11:31 AM
BradB's Avatar
BradB
Thanks As Always...
There are some great products here but some you can do without.
The Sonus shampoo is fine. I like it.
The Sonus Clay is good too, but get the Clay Kit. It's the same clay, better deal and comes with lube.
You don't need the Clay lube. It comes in kit above and when that is gone use shampoo. I like that better anyway. And that's cheaper.
Scratch X is "ok" but I much prefer Sonus Restore. More expensive but WAY better. Skip this if you have no scratches to deal with.
Klasse is good stuff. Durable and relatively inexpensive.
Skip the Wunder Applicators. Overpriced. Get pure foam. Even cheaper at AutoZone or WalMart. These are nice ones also. Made by Viking.
Wunder Polishing Towels are nice. I would get them. I like them. Or get these towels. Not quite as high quality or durable but are ok.
I would also get at LEAST one wafflweave drying towel. This is REALLY important to avoid scratching while drying.
And be sure you have a quality mitt. Avoid cheap ones that scratch.
Hope this helps!
Old Mar 2, 2005 | 12:44 PM
E1Designs's Avatar
E1Designs
TY so much!!!
I have a chamois...aside form the "drying power" that is the waffle towel, my chamois should suffice for now yes?
Old Mar 2, 2005 | 01:19 PM
BradB's Avatar
BradB
TY so much!!!
Chamois are really a bad idea. The problem is two-fold. The chamois texture is very flat and has no "weave". When a foreign object or debris gets in the chamois it lays right on top and gets scraped right up against your paint. These are microscopic (and sometimes not!) and cause the dreaded scratches and swirls you see on most non-detailed cars. Chamois are also not very soft. The texture itself is not resiliant and will mar and scratch. It was ok 30 years ago...but times have changed! Mine have been trashed long ago!
Please don't use it!
Read this. Some info on Microfiber
Old Mar 2, 2005 | 01:44 PM
E1Designs's Avatar
E1Designs
Thanks Again...just ordered everything mentioned above except the sonus restore, waffle towel included. I have been usin gthat chamois on my wife's Honda Element, I don't notice any scratching, but I feel guilty.
$86.41 with shipping included, not bad.
Old Mar 2, 2005 | 01:49 PM
BradB's Avatar
BradB
You will be pleased with the products. And you will love the towels!
Old Mar 2, 2005 | 02:26 PM
gokartride's Avatar
gokartride
I know its a lot to process at first, but you're going about it the right way E1Designs. I know several owners (including myself to some extent) that suffered through a bit of a learning curve on this stuff.....and the results weren't pretty, if ya know what I'm sayin'!!! Good for you for getting started off on the right foot and using the advise of the experts.
Old Mar 8, 2005 | 12:37 PM
E1Designs's Avatar
E1Designs
Just dia a wash, clay, wax this past weekend using my newly acquired products. My question is this...as I have begun to research more and more...is Klasse inferior to Zaino? If so is it for durability or shine reasons?
Thanks Again...
Old Mar 8, 2005 | 02:25 PM
BradB's Avatar
BradB
Thanks Again...
Ultimately, Zaino is a more durable polymer. Also, the acrylic in Klasse will yellow after a time due to the degrading by the UV rays. This gives Klasse a slight tint where Zaino remains optically clear.
Also, Zaino you can layer almost without limit, changing the look as you go. Klasse has such high solvent content that it does not layer well.
Having said all that, Klasse is still an excellent product, it just comes in #2, IMO.
USNAE2
16
Jun 17, 2022 07:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
MiniChick82
Detailing 101
Nov 18, 2015 12:03 PM
vulkandino
Oct 31, 2015 08:29 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
