Aesthetic Creations black trim restoration
Old Apr 13, 2015 | 12:59 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
About 8 years ago there was a shop in Arizona called Aesthetic Creations and they offered black plastic trim covers for MINI door handles, fuel filler caps and F/R MINI badges. They closed up shop few years back but many folks purchased those covers as I did.
They came with a black satin finish which looked great as was or could be painted. I left mine black but over the years they have become a PITA to keep looking nice, much like the roof gutter trim.
Today I decided I was going to paint these pieces using Duplicolor products. Grease/wax Remover, Adhesion promoter and then Black Bumper Paint.
But since I couldn't remove the pieces from the car, I never got past the first step of prep and saved $$$$$.
I folded blue shop towel into small 2" square and decided to prep the handles while in the car using the Duplicolor Wax / Grease remover, then immediately wiped the area down with a dry blue shop towel. What I discovered was that the Grease/Wax remover restored the finish even better than new making these parts shine. I ended up doing the roof trim and the side view mirror bodies as well....everything shined up beautifully.
Use rubber gloves, it's strong stuff.
Can was less than $8 dolllars from Advance Auto Parts.
Here are some photos....
Mirror Body Before.
Mirror Body After.
Door handle done.
This is how the plastic looks now even before wiping down with Back to Black ect.
Worked just as well as on the gutter trim. With that trim after one wipe down and buff with paper towel, I wet another clean square area of a blue shop towel with the remover and then gave it one long even swipe from end to end without stopping. Then a quick buff with a clean blue towel to finish off. Shined right up.
Old Apr 13, 2015 | 02:34 PM
bavmotors's Avatar
bavmotors
Nice and shiny, how well do the handle covers stay on? I've been looking to get a set but don't want a cheap feel to my handles.
Old Apr 13, 2015 | 04:54 PM
-=gRaY rAvEn=-
Moderator
Couldn't get these off and been on for years...hahahah.
These Aesthetic Creations covers came with 3m glue strips....I purchased some of this glue strip on the internet because I was impressed with how well it worked and I had some uses for it from time to time....expensive stuff so only got a few feet. Costly and very sticky. Feel is good as these strips are all 100% glue so no foam as a medium in between.
These days I only see covers made in china, not sure what they use for adhesive but could be they only use the foam style 3m double backed type of tape...
Old Apr 13, 2015 | 07:21 PM
ZippyNH's Avatar
ZippyNH
Very nice trick....
Guess wax, etc must buildup on the surface giving stuff a bit of the grubby look!
Might need to try it on my roof trim....
Old Apr 14, 2015 | 02:20 AM
-=gRaY rAvEn=-
Moderator
Originally Posted by ZippyNH
Very nice trick....
You'd think but I never use wax, just ZIANO. I think it just removes all the weathered oxidation, towels gunked up black. I went back over roof trim with a trim sample from goodie bag at last Toys for Tots run, trim looks better than new. Nice rich look finish, took 3 coats.
Old Apr 14, 2015 | 06:31 AM
Helix13mini's Avatar
Helix13mini
Dave.O just turned me on to this stuff from Home Depot. It's pretty amazing.
Old Apr 14, 2015 | 03:09 PM
Capt_bj's Avatar
Capt_bj
remember that these products strip EVERYTHING ...
all that old crud gone is GOOD
BUT you'd better cover it FAST ...... a good wax immediately is important.
just like sanding down a rusted part .... getting good metal is fine .... but you better get some primer down FAST
exposed metal corrodes FAST ... not hours ... MINUTES allow the seeds to plant
Old Apr 14, 2015 | 03:20 PM
ZippyNH's Avatar
ZippyNH
Yeah....everyone he mentions it makes me think the commercial for "wipe-new" is that exact same stuff, just at a 500% markup....
Seen pics of it...does an amazing job...keep meaning to give it (penetrol) a try...
Old Apr 14, 2015 | 03:40 PM
-=gRaY rAvEn=-
Moderator
But......its plastic.....
Old May 29, 2015 | 02:17 PM
crazy4trains's Avatar
crazy4trains
So, on what exactly are you proposing to use the penetrol? I have quite a bit of oxidized plastic on several vehicles and that would definitely be an economical alternative if that is the recommended use.
Old May 29, 2015 | 02:42 PM
ZippyNH's Avatar
ZippyNH
Penotrol on the plastic...wash, dry, apply lightly in a dust free area...
Dave-o here, now on the other sites loves it...his car looks great...it works!!
Shane Wendel
Aug 21, 2015 01:04 PM
mini-medic
Aug 18, 2015 09:13 AM
WayMotorWorks
Aug 4, 2015 01:47 PM
