Keep brake dust of rims
Old Jun 3, 2004 | 12:45 PM
Nando's Avatar
Nando
Hi All,
I read a post about this a while back, but I cannot seem to find it. There is a product that you can use on your rims so that brake dust is eithere repelled, or easily cleaned. Can anyone tell me what this product is? My frind's rims look totally black, as he drives around very hilly parts.
Thanks,
Nando
Old Jun 3, 2004 | 12:48 PM
Nick_T.'s Avatar
Nick_T.
Either Zaino or Klasse is excellent for ease of cleaning. Neither one softens with wheel heat, so they don’t trap the brake dust like the carnaubas.
911Fan's Avatar
911Fan
Any polymer "wax" will do the trick.
Old Jun 3, 2004 | 12:49 PM
countrym's Avatar
countrym
Here's a related thread that might give you a place to start.
You'll have to get the wheels clean, and then apply a coat of wax, zaino, rejex or a similar product to keep the dust off.
Old Jun 3, 2004 | 12:56 PM
cdconsor's Avatar
cdconsor
I've been using rejex and I really cant say that it works miracles or anything. Does it make it easier to clean? probably. but you still have to get every nook and cranny with a cloth (or whatever). It definitely does not just rinse away.
ok maybe I was expecting too much but hey, I'm a sucker for advertising
Old Jun 3, 2004 | 12:58 PM
OctaneGuy's Avatar
OctaneGuy
Use Meguiars NXT. Then maintain daily or every few days depending on amount of Brake Dust with Meguiars Quik Detail. That's how I do it. I've developed a technique using a small wheel brush and a blue paper towel to make wheel cleaning a simple 10 second procedure (for each wheel)--works with any wheel with large spokes--like the 5 stars. Just spray on Quik Detail, wrap wheel brush with paper towel, and wipe off the dust. It comes off with a single pass--the soft brush conforms to the wheel surface. Take the paper towel off, and clean off any missed areas. Flip it over and use on second wheel. One towel is good for 2 wheels--sometimes more depending on how dirty they are. Before I discovered this technique, I used between 2 and 4 paper towels for cleaning, my hands were black, and it took several minutes per wheel, and multiple passes.
Old Jun 3, 2004 | 07:04 PM
Jimbo's Avatar
Jimbo
Once I get a good coat of wax on the wheels I just dust daily with an old cotton ribbed t-shirt, I use the same shirt for months, shake it out after each wheel, kind of like a cali-duster. The dirter the shirt gets the better it works, just make sure the wheel is dry, because if it is wet the brake dust smears and you will have to wash to get it clean. You may want to get a pair of gloves just for dusting too, because once the t-shirt gets black the mositure in your skin will transfer the dust to your hands.
Old Jun 3, 2004 | 07:10 PM
lotsie's Avatar
lotsie
My next MINI may be dirty coloured and have
brake dust toned wheels
Old Jun 3, 2004 | 08:14 PM
indygomini's Avatar
indygomini
Aack! It's been over 2 weeks since I cleaned my wheels. I'm due to rotate tires also- maybe instead of cleaning, I should just swap fronts and rears, wait another week, and tell anyone who asks that I have special, anthracite "powder-coated" R85's.
Old Jun 3, 2004 | 08:16 PM
MGear's Avatar
MGear
I wax my wheels a few times a season and recently started using a product that seems to make a big difference improving even on the low dust brake pads. The product is from Cragar, the wheel people, the product is called Brake Dust Barrier. Just spray on and wipe off once every two weeks. I have had it on the wheels now for two weeks and it really does a great job.
Check them out at: http://cragarcarcare.com/item/Wheel_Surface_Protection
indygomini's Avatar
indygomini
Brake dust is easier to clean off than cicadas...
Old Jun 3, 2004 | 08:35 PM
pezhead444's Avatar
pezhead444
Just a little tidbit. The guys in NASCAR spray their wheels with PAM so the brake dust doesn't go everywhere. :smile:
Old Jun 3, 2004 | 08:41 PM
W3IWI
I find that EBC's Green Stuff pads just about eliminated brake dust for me. A good wax on the wheels makes it so the residue rinses off with a spray of water.
My wheels are polished Rota Slipstreams (pardon the mud and snow):
Tom
_________________
Tom Clark, Clarksville MD: CR '02 MCS
Old Jun 3, 2004 | 08:43 PM
lotsie's Avatar
lotsie
I'm thinking veg. based pam for the bonnet in heavy bug season
Old Jun 7, 2004 | 08:41 PM
fishey72's Avatar
fishey72
Keep dust off rims:
Step 1 Get rid of stock brake pads (1 hour sweat labor)
Step 2 Clean (after 5k this took the most time) and wax wheels (2 hours sweat labor)
Step 3 Enjoy NOT having to scrub your wheels every week.
Whoever at BMW came up with that brake compound should be forced to clean all our wheels one time.
Old Jun 7, 2004 | 08:48 PM
Ryephile's Avatar
Ryephile
Step 4; buy anthracite colored wheels!
Old Jun 7, 2004 | 09:03 PM
gokartride's Avatar
gokartride
Just a tidbit that is probably known to one and all (...except it was unknown to me), but when I started using Klasse products (including on my wheels) I stopped using Simple Green to clean brake dust. Apparently Simple Green will strip All-In-One so now I simply spritz my wheels with water and wipe them clean. Works super! I just thought it's interesting how different products interact for good or ill.
Old Jun 7, 2004 | 09:07 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Less brake dust-many options
So you are tired of brake dust on your rims?
Reduce the brake dust by changing to Mintex Redbox pads (lower cost) or EBC green pads.
If you have aftermarket wheels choose a design that is more open to allow the brake dust to not contact the wheel as much.
You can clean off brake dust easily with simple green.
You can wax with Wheelwax and that repells brake dust, you can pick it up from tirerack.com for about $15. It doesn't last forever but it is good (smells good too)
And you can brake less.
Old Jun 26, 2004 | 05:33 PM
Red's Avatar
Red
Dust can be removed, but having trouble with little black dots on my stock MCS wheels. I don't want to remove paint; how aggressive can I go? 000 steel wool?
Thanks.
regards,
Red
Old Jun 26, 2004 | 05:53 PM
Nick_T.'s Avatar
Nick_T.
That would be an improvement over BRG!
Old Jun 26, 2004 | 05:58 PM
Nick_T.'s Avatar
Nick_T.
I suggest that you strip everything off of one of your front wheels and apply WheelWax to half of the wheel and leave the other half naked. Check after a few days of heavy braking. I think that you may reformulate your opinion of WheelWax.
But as always, YMMV!
Old Jun 26, 2004 | 06:42 PM
Tomslick's Avatar
Tomslick
Get good low dust pads.
Clean wheels.
Wax with polymer (or whatever that stuff is) wax. Zaino, Zymol, etc. NOT Carnuba. Carnuba=brake dust glue.
Use Crager Brake Dust Barrier. (Yeah, I own the company.)
Depending on how dirty they are, use the dry wipe or quick detail spritz (like all them other guys said) touch up as required.
Don't buy white wheels!
Old Jun 26, 2004 | 07:49 PM
White_Knuckles's Avatar
White_Knuckles
First point; It's just a car. With that reasonable care applies. I can respect guys going over their car with a Microscope but is that for me? - nope.
I clean the brake dust off every wash. White wheels are an issue I don't have to deal with. People don't notice a little dust on gray wheels or a spec on the dash, they see and enjoy the car as a whole. I am tweaked about door dings and park in weird places. I keep the interior clean, wash her when needed and a couple coats of NXT a year is about right.
Find how to apply a balance of care for your car and avoid being a little too close to perfection with stupid stuff.
Old Jul 27, 2004 | 06:19 PM
MrsW's Avatar
MrsW
Try WHEEL WAX. I found out about it at BMW car show. It works really well. Just Google on WHEEL WAX.
Old Jul 27, 2004 | 06:50 PM
Bradley99's Avatar
Bradley99
This?
