Tips for removing wax on plastic molding?
Old Aug 14, 2013 | 03:22 PM
NintenTom's Avatar
NintenTom
Anyone have some tips to remove wax marks on the arches or similar material of the car? Everytime I wash the car it will go away for a while but then come back. Thanks.
Old Aug 14, 2013 | 03:59 PM
MKIR53's Avatar
MKIR53
The first thing you should try is Dawn dish washing liquid. It is good for stripping wax and won't leave any residue. Typical car wash soaps are designed to leave the wax and remove the dirt. In fact, I wash my car with Dawn once a year. The rest of the time I use a car wash soap.
That should work. If it still won't come off, I think I have read that denatured alcohol will do the trick. But that I would test on an inconspicuous spot first.
Old Aug 14, 2013 | 04:20 PM
thulchatt's Avatar
thulchatt
Get some Pre-Wow, and also some Black-Wow
Both products made by Richard Linn, MINI detailer extraordinary.
Pre-Wow will clean up your balck plastic trim and Black-wow will treat it better than anything else on the maket.
Old Aug 14, 2013 | 05:24 PM
TREX's Avatar
TREX
I read somewhere on here that peanut butter works pretty good for removeing the wax residue and getting it back to black.
Old Aug 14, 2013 | 05:28 PM
danjreed's Avatar
danjreed
In for answers. The dealer got a small patch on the plastic roof drip trim... drives me nuts.
Old Aug 14, 2013 | 07:29 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Like he said this is your best bet
Old Aug 15, 2013 | 05:07 AM
Gil-galad's Avatar
Gil-galad
+2
Old Aug 26, 2013 | 04:29 PM
mgrant's Avatar
mgrant
I heard you can just use a typical eraser
Tried it last week and it seemed to work very well. I applied Mothers Back-to-Black afterwards and the results are great so far
Old Aug 26, 2013 | 06:34 PM
Mr. T's Avatar
Mr. T
There is only one product you need for this problem:
http://www.adamspolishes.com/p-121-a...e-cleaner.aspx
It works every time without fail and no laborious rubbing.
Old Aug 26, 2013 | 08:31 PM
KeyPlayaJim's Avatar
KeyPlayaJim
I've found that one of those big, flat, pink erasers does a great job. You can buy one cheaply anywhere that school supplies are sold.
Old Aug 26, 2013 | 08:35 PM
mini on's Avatar
mini on
Just get some.
Old Aug 29, 2013 | 07:38 PM
DVS1's Avatar
DVS1
Mr Clean Magic Eraser works as well, got some spots from my random orbital that i missed with tape.
Old Aug 29, 2013 | 07:47 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by TREX
...peanut butter works pretty good for removeing the wax residue...
It does. Smooth not chunky. But it won’t make your arches black.
But Pre-WOW and Black WOW are great together and worth the investment as you use very little.
Rich
Old Aug 30, 2013 | 03:48 PM
mini6spd's Avatar
mini6spd
+1 for eraser, thats what i used and it worked great
Old Aug 30, 2013 | 05:26 PM
DailyDrivenMini's Avatar
DailyDrivenMini
If you are serious about removing residue stuck on plastic..
WD40.
Hands down. Put it on a paper towel and go to work. At crevices, spray it on and watch wax residue melt away.
Old Sep 27, 2013 | 09:50 PM
navybsn's Avatar
navybsn
I've used Barkeepers Friend for years with good success.
Old Oct 11, 2013 | 01:46 PM
drewthat's Avatar
drewthat
Even an Armor All Cleaning wipe will get it off.
Old Oct 11, 2013 | 02:40 PM
Platty's Avatar
Platty
Pencil eraser works fantastic for removing white marks from plastic trim.
Old Nov 2, 2013 | 08:15 PM
Bob Saget's Avatar
Bob Saget
Just tried the peanut butter method. Other than it being hard to get out of tight spaces, it worked amazing.
There will now be a jar of it in my detailing kit.
Old Dec 26, 2013 | 08:26 AM
Purpleoctopus's Avatar
Purpleoctopus
This actually does work great! I could not believe it when I first read it but then I tried it! You can remove the wax from the trim and have a snack at the same time!
Old Dec 31, 2013 | 10:31 AM
StrikeZ's Avatar
StrikeZ
I tried Black Wow on my last MINI, it looked good, but came off the next wash. Meguiar's lasted three times as long and came close to the look of Black Wow, but cost 1/3 the price.
Old Jan 24, 2014 | 12:02 PM
Joe_K's Avatar
Joe_K
The problem with Black Wow is that it's tricky. IMO Richard should have marketed it to the professional detailer versus the weekend warrior. You have to think of it like lotion and the plastic as skin. You have to rub the Black Wow into the plastic and then potentially come back for more depending on how far gone the plastic is. Also, it's not really that expensive when you think about it because you're only using a tiny, sesame sized amount each time. I've had the same bottle for at least 3 years.
Joe
Old Jan 27, 2014 | 01:10 AM
Himesed's Avatar
Himesed
I tried orange hand cleaner with pumice for cheaper and less work. After scrubbing the hand soap, I let it dry and rinced it our after a day. This leaves the plastic clean and oil free for Armorall or plastic wax application. Try orange pumice citrus hand cleaner! It works best in my opinion.
Old Jan 27, 2014 | 03:10 AM
whaap's Avatar
whaap
Wd 40
Old Feb 14, 2014 | 08:05 AM
TorchMINI's Avatar
TorchMINI
Another zone of wax contamination is the subtle white line around the belt line of my Clubman, which should be a thin black rubber line around the car, but keeps some wax and has the off-white line peeking out all around. It's been a while since I've addressed it, so I gotten used to the 'contamination'.
I used Pre-Wow sprayed on a 'car tooth brush', and I went around the car lightly scrubbing the boundary of paint and rubber and chrome trim.
It is impressive to get the good black contrast back! The car looks all better. :-)
flyers47
Jul 27, 2020 02:38 PM
greekzilla
Aug 23, 2015 03:44 PM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
minipopkart
Aug 13, 2015 05:22 AM
