OctaneGuy: Complete 2008 Jet Black BMW 335I Restore
Last week during our rains here in SoCal, this 2008 BMW 335i was dropped off at my shop. Although the paint was dirty, I could see the poor condition of the paint. After it was cleaned up and the restoration process began, I discovered that the paint was ultra soft, softer than Jet Black typically is, and then I discovered the hood and passenger side had been repainted.
I used a variety of tools including my Makita rotary buffer, a 7424XP polisher, and a Flex VRG3401 DA.
Chemicals:
Clay: Megiuar's C2000 Clay and Prima Glide for lube
Exterior Polish/Wax: Prima Finish, Prima Epic, Prima Banana Gloss, Prima CosmoNot, Prima Clarity, Prima Slick.
Interior: Meguiar's Quik Interior Detailer, Prima Nero, Prima Nourish
Let's get started.
The drivers side window had some old decal on it
I brought it to the shop and began with a thorough Dawn Wash
The HRE's were pretty filthy
Using Meguiar's Tire Foam, I foamed the wheels and tires
I let the foam dwell for a bit
Using my EZ Brush, I cleaned the wheel spokes
And for the lips, used my soft flagged end brush
Rinse off, they looked much better
After the Dawn wash and ready to bring into the shop for claying
The interior needed work too
Claying the carbon fiber trunk
Lots of contamination pulled
Using my 3M Sun Gun to illuminate the swirls
I did a test spot
Pretty significant improvement
While I worked the exterior, my assistant Stephanie talked the interior by using our hot water extractor
Interior was looking much better
Two coats of Epic were applied, then two coats of Banana Gloss.
The rain subsided so I took it outside for some shots but due to the clouds, the pictures weren't spectacular
It started to rain again, so I brought the car back inside and proceeded to look at the wheels. I thought they could use some improvement too.
So I polished them using Prima Epic (yes the polymer wax) and my Metabo SXE400 3" orbital
Huge improvement, so I kept polishing
I polished the lips too
Finished up the face of the wheels
So two days have gone by, and the detailing began
Polished the exhaust tips
Couldn't forget the underside of the hood either
The yellow latch was cleaned with CosmoNot
The next day the sun came out!
All done!! But sadly it rained the day the customer picked up the car, so I told him to bring it back when the rain stops and I would wash the paint for free! It's part of my guarantee if it rains the week of or after a detail.
Chemicals:
Let's get started.
I did a test spot
That BMW Looks Spectacular........huge difference ! I was at a family function just lastnight where a black 07' 335i had the same exact paint condition. I clued owner in on a much needed claybar and PC work. He was "old school" in that regard needing some help.
BTW: I think your MINI is getting little fresh with your assistant
Thanks everybody for the kind words!!! I gave Scott a heads up, so he should reply.
Richard
Richard
Just curious, and I don't mean to be tacky, but how much does a company charge for something this good?
I just bought my used MINI about a month ago, and I am thinking about starting fresh with a good, professional, DEEP detail (like this job), by someone who is more OCD than me.
Prices depend on initial condition of the paint and some other factors, but in general for this car, an SCD Complete ranges from $400-$700. There are others that charge a lot more and others that charge a lot less. I position myself in the midrange though I do high end work. The quote for this car was on the lower side of that range, even though I did spend about 3 days on it mainly because I had the time...it was raining.
My special MINI prices for a Complete are $300 and $225 for an Express. They both feature the same services and results are similar but the Complete strives for paint perfection and takes more time. I can do an Express in one day in about 6 hours with my helper and a Complete takes about 10-12 hours and is recommended to be picked up the following day while the sun is shining bright.
If you are not in the SoCal area, then this info is meaningless as it's specific to me and my shop.
Great! Good luck!
Well, I was just trying to get a general idea. But I'm in The Valley, so maybe I will stop by sometime.
Cool I understand. My point was that my prices may not be relevant to someone who is in New Jersey or Alaska, lol.
Plus I got more than just detailing...I carry the full line of Prima and can show you what it can do for your paint through a mini 1 on 1 clinic.
Richard
Richard
Dec 23, 2015 10:36 AM
