DC Metro MINIs (Archive) The old DC Metro MINIs club forum, now closed. Visit their new forums at www.dcmetrominis.org/forums
Defrost and XM radio
Old Dec 8, 2006 | 01:28 PM
whataricky's Avatar
whataricky
Does anyone know how to turn down the fan on defrost w/o turning it off?
and.....
I have the H/K radio and my wife gave me XM last Christmas and I have yet to put it in b/c I don't want the stupid Skyfi thing in my car, I want to use the factory stereo... I know I need something I think is called a BLITZ box? Any ideas guys / gals??
Old Dec 8, 2006 | 01:32 PM
MaxN's Avatar
MaxN
Reverse Gear
The Defrost is designed to clear the screen as fast as possible, hence high heat, high speed etc. Look at is like a special mode to help you out by setting eevrything to maximum. If you want to control the airflow seperately, do not use that button !
As for the XM installation - you need the XM direct and Blitz-safe adapter, they install in the back where behind one of the access panels (right)
Old Dec 8, 2006 | 01:41 PM
Edge's Avatar
Edge
AdMINIstrator
To expand on MaxN's comments, don't use the defrost button... but you CAN hit the button on the right hand side that will force airflow to the windscreen... then control the airflow yourself.
Old Dec 8, 2006 | 02:04 PM
whataricky's Avatar
whataricky
Thank You and where do I get this adapter?
Old Dec 8, 2006 | 02:07 PM
MaxN's Avatar
MaxN
Reverse Gear
Start in the audio section, I bought mine over a year ago - fitting took me nearly five minutes
https://www.northamericanmotoring.co...ad.php?t=31985
Should help a lot......
Old Dec 9, 2006 | 04:18 AM
Jen's Avatar
Jen
I hate this about my MINI too. If you hit the button and hold it for a few seconds, you will be able to turn down the air speed but still have defrost on. I will say, on very frosty mornings, I do leave it on the high-but-annoying setting because it does clear the windscreen very fast. Then I turn it down.
Old Dec 9, 2006 | 08:08 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
You know, people have said that, but it has never worked in my 05. I've tried it many a times too.
Old Dec 9, 2006 | 09:06 AM
mbabischkin's Avatar
mbabischkin
Believe it or not that's a trick that was removed in the '05s and newer, but actually does work in older MINIs.
Old Dec 9, 2006 | 12:52 PM
Krut's Avatar
Krut
you can get the XM Direct box from www.myradiostore.com - Ziggy is awesome to deal with - and you can listen to Opie and Anthony from 6 am until 11 am every day (the entire show). If you are in DC and want to see this set up - I'm more than happy to help you in getting the right pieces as well as installing it.
Old Dec 10, 2006 | 07:48 AM
Jen's Avatar
Jen
I guess this is another reason to keep my 03.
bahman
Feb 14, 2016 10:29 AM
pglgp1292
Oct 5, 2015 06:47 PM
ahorvath
Oct 3, 2015 01:13 AM
simo711
Oct 1, 2015 05:36 AM
