Cooper (non S) Modifications specific to the MINI Cooper (R50).
M7 Strut Bar
Old Apr 8, 2007 | 05:41 PM
FL_blue_MINI's Avatar
FL_blue_MINI
M7 Strut Bar
I know this is out there, but here it goes. Has anyone ever put this on an MC (non-S)? I so what did you have to do to it (or the car) to make it fit?
Thanks in advance
Addison
Old Apr 8, 2007 | 05:46 PM
ChrisW's Avatar
ChrisW
I don't know if anyone has but you have to Mod the battery boxs to make it fit.
Old Apr 8, 2007 | 05:48 PM
FL_blue_MINI
I know for a while Helix sold, with thier strut bar, a moded battery box. I wonder if that would work ?!
Old Apr 8, 2007 | 05:57 PM
ChrisW's Avatar
ChrisW
Not sure I know I tried to put one on my wifes car and ended up just going with the SRP plates.
Old Apr 8, 2007 | 08:46 PM
maxmini's Avatar
maxmini
I've mounted them on two MC's in the past and did not have any contact with the covers as I recall. The last one i did was at the Dragon last year and there were no issues. As with some bars there may be a bit of a lift in the rear of the hood but that will vary according to the thickness of the insulation. There are several fixes for that should it be a problem.
Randy
M7 Tuning
Old Apr 8, 2007 | 08:55 PM
goaljnky's Avatar
goaljnky
I had it mounted on my MC once. It cleared the battery cover, but was lifting the hood too much for my taste. Didn't want to find what the long term effect would be on the hinges, etc. so now I don't have it anymore.
Old Apr 9, 2007 | 03:56 AM
FL_blue_MINI
thanks! im not sure i want to deal with the hood lifting problem, at least until my warrenty is up.
Old Apr 9, 2007 | 10:40 AM
R50 Paul's Avatar
R50 Paul
But I've seen then fit perfectly before, with no hood lift......
Old Apr 9, 2007 | 11:07 AM
goaljnky's Avatar
goaljnky
Yeah, seems to be a crapshoot.
Old Apr 9, 2007 | 09:25 PM
maxmini's Avatar
maxmini
The " bulge " that many have experienced has been around since 02 . It was just not talked about in polite company I have had a " bulge" issue since nov of 02 but no one noticed. This was due to my BMP Pro/ Mini brace which I used for years. I also had a bit of a " bulge " when i used a Forge Motorsports brace as another test. The " bulge " has been with us for a long time with a variety of braces and a number of ways to minimize it have been developed. In my personal case I did not see any difference in my " bulge " as it was already up a bit from my former braces. As to how noticeable this is to others that remains to be seen as a row of 5 foot garish HIN trophy's in my garage( wife won't let them in the house ) attest to the judges never noticing anything amiss As for a warranty problems I guess if your hood blew off they might have a case but except for that it is a non issue. It really comes down to if you have a need to perform better then the POSSIBILITY of a " bulge " should not keep you from making the correct choice. To each his own of course .
Randy
M7 Tuning
Old Apr 10, 2007 | 04:42 AM
FL_blue_MINI
I'm very interested, I think when I have some $$$ I will get the M7 and do the little mod to the insulation. thanks guys!!
Old Apr 10, 2007 | 06:20 AM
goaljnky's Avatar
goaljnky
Warranty? Who said anything about that? Correct choice? It might be a choice, but that's about it.
Edit: And if you knew since '02 that a modification might be required to make it fit, how come neither your brochures, or your web site mention it? I little deceiving, don't you think?
Old Apr 10, 2007 | 07:25 AM
maxmini's Avatar
maxmini
I was addressing this comment by the original poster :
I really am only concerned with helping him make a decision as it seems as if he is looking to better the performance of his car . The modification of which you speak would require thinner materials and lessen the effect of the bar or the protection value to the strut towers. As had been stated by others this problem does not exist on every car and most people feel that the possibility of a slight bulge, unnoticed by most, is worth the gains . You apparently have other goals which is of course your choice. Thanks for the bump.
Randy
M7 Tuning
Old Apr 10, 2007 | 07:33 AM
goaljnky's Avatar
goaljnky
Originally Posted by maxmini
As had been stated by others this problem does not exist on every car and most people feel that the possibility of a slight bulge, unnoticed by most, is worth the gains.
Maybe, maybe not. It would still be nice if you were as upfront about it as you are nonchalant. Truth in advertising, so to speak.
Old Apr 10, 2007 | 07:35 AM
dwjj's Avatar
dwjj
I agree-might be nice to know if there are additional issues specifc to MC about a product for instance. Does the battery box cause extra interference? I hadn't seen that mentioned anywhere before.
Old Apr 10, 2007 | 10:29 AM
R50 Paul's Avatar
R50 Paul
I have a friend with a 06 Cooper (Non S, Non Convert) and the M7 bar fits with the battery cover in place.....there is no hood bulge either.....
Old Apr 10, 2007 | 02:12 PM
maxmini's Avatar
maxmini
As is the case with most net issues you mostly hear of problems not the success stories.The vast majority fit with little or no problems as all or they would be easier to keep in stock Thanks for the post.
Randy
M7 Tuning
Old Apr 10, 2007 | 03:03 PM
R50 Paul's Avatar
R50 Paul
Just telling it how it is...after seeing what I've seen.....
Old May 6, 2007 | 08:44 PM
calypson's Avatar
calypson
I have one on my MC and installed it myself so I can say with certainty: Out of the box it will raise your hood, it clears the battery no problem. The allen head bolts will hit the hood so I changed them to 'shorter' ARP 12 points. I had to grind/file a very small amout of the front of the plates. To avoid the hood lift I cut a section of the sound insulation pad the same size as the bar...now it fits without issues.
Old May 7, 2007 | 08:13 PM
ayyado's Avatar
ayyado
Last edited by ayyado; May 7, 2007 at 08:59 PM. Reason: double post slow connection
Old May 7, 2007 | 08:56 PM
ayyado's Avatar
ayyado
are there any drawbacks with this? in long run specially....
my knowledge is not very high about many of performance mods....i mean do you need diff suspension, shock or something or will it affect if you get diff suspension in future...how much difference do you feel in handling? and have to have the rear as well?
and it would fit 03 mc without any problem?
Old May 8, 2007 | 04:21 PM
maxmini's Avatar
maxmini
This is a stand alone piece with no long term negative issues as far as we have seen . There are many that have gone over 100k miles with no problems. It will not affect future suspension mods in a negative way. If you have any reservations give the shop a call and we will be happy to talk to you about it .
Randy
M7 Tuning
Old May 13, 2007 | 01:24 PM
ayyado's Avatar
ayyado
Randy
M7 Tuning
one more question....if i order would i get a sticker of m7 logo in red...for the side fender....haha....i may be asking for much...but i really love the logo.....
Old May 13, 2007 | 03:55 PM
maxmini's Avatar
maxmini
Unfortunatly the only " official " color we have is the silver . I would think that you could take our logo to any Sign A Rama type location and get one scanned and duplicated easily for a few bucks .
Randy
M7 Tuning
ericbryant24
55
Sep 30, 2024 02:10 PM
ej
Nov 17, 2015 09:21 PM
MINI-Madness
Sep 11, 2015 11:31 AM
cdemarco4
Sep 10, 2015 10:14 AM
Suspension Products
Sep 3, 2015 09:41 AM
