Cooper (non S) Modifications specific to the MINI Cooper (R50).
motor swaps
Old Jan 11, 2007 | 03:57 PM
justintime's Avatar
justintime
motor swaps
now, before I ask this.. I want to say I have no intention or money to actually go through with it. But I was thinking alot about it today, and how cool it would be to put a bigger motor in the cooper. Now, I know i'm not the only one who has thought of this.. but has anyone done it? and any ideas what would fit??
Old Jan 11, 2007 | 04:02 PM
vano's Avatar
vano
I wonder if anything other than the 1.6 liter motor would fit. The engine compartment seems so tight as it is. It seems one would have to remove something from the engine bay to make room for a larger engine, but what do I know.
Old Jan 11, 2007 | 04:05 PM
justintime's Avatar
justintime
I was thinking that too, but.. im thinking the performance gain would outway comfor though
Old Jan 11, 2007 | 04:12 PM
vano's Avatar
vano
Weight is a consideration too - a heavier engine could unbalance the car. Although, it probably wouldn't be hard to find a larger motor that weighs the same as the pentagon.
Old Jan 11, 2007 | 05:54 PM
in the flesh's Avatar
in the flesh
Well what I would do is take everything out from under the hood, and stick the 2.5 litre boxer engine from the STI, I dont know if it could fit, but it would be my engine of choice, of course this is all just a pipe dream
Old Jan 11, 2007 | 06:00 PM
justintime's Avatar
justintime
would you have to run awd or rwd if you did that? it would be alot harder atleast I was thinking more on the lines of a motor from a front wheel drive car. like the new si motor, or mabye the srt4?
now a small block chevy would be fun too
AliceCooperWA's Avatar
AliceCooperWA
Nothing would be better than an STI engine with a nasty turbo...and an AWD conversion
Old Jan 11, 2007 | 06:40 PM
justintime's Avatar
justintime
haha, well.. I was thinking something alittle more simple/do-able but sti performance in the light mini would be a track monster
Old Jan 11, 2007 | 07:52 PM
UKSUV's Avatar
UKSUV
T-REX MOTORSPORTS PRODUCT HIGHLIGHT:
We at T-REX MOTORSPORTS are proud to announce the Availability of Cosworth Crate Engines and Individual Components.
Custom Built Cosworth Crate Engine Build Specifications:
Built Exclusively For T-REX MOTORSPORTS
All New from Subaru Stock Long-Block (2005 2.5 STI MOTOR)
Darton Sleeves/Liners For 100mm Pistons
79mm Billet Cosworth Crankshaft
High performance Main and Big End Bearing
Cometic Head Gasket
Xtra Heavy Duty Forged Connecting Rods (Cosworth Spec) With ARP Heavy Duty Bolts Cosworth Spec EJ25 Light Weight Forged 100mm Pistons
Cosworth Spec H.P. Rings
Cosworth CNC Ported Big Valve-Max Flow Race Cylinder Heads
ARP Heavy Duty 11mm Head Studs
272/262 June Cams and June Adj. Cam Sprockets
Power Enterprise heavy duty cam/timing belt
1mm oversized Stainless Steel intake valves
1mm oversized Inconel-high temp exhaust valves
Hi Rev (Max 10,500rpm) Valve Spring Package
Billet timing belt tensioner
8.25 to 1 Compression
Balanced and Blue Printed
THIS MOTOR CAN BE SHORT SHIFTED AT 8,600RPM’S!!!
AS A ONE TIME ONLY DEAL WE ARE WAIVING THE NEW CORE CHARGE OF $4,800.00!!!!!!!!
PLEASE NOTE THAT WITH PROPER TURBO SIZING AND TUNING THIS ENGINE IS EASILY CAPABLE OF 750+ ALL-WHEEL DRIVE HORESPOWER!!!!!!!!
WELCOME TO THE 9-SECOND QUARTER MILE E.T. BRACKET!!!!
REGULAR RETAIL $20,240.00
1-UNIT PRICE SPECIAL ($14,399.00) - IN STOCK READY FOR DELIVERY
Old Jan 11, 2007 | 07:53 PM
UKSUV's Avatar
UKSUV
I WAS TOLD IT WOULD FIT
Old Jan 11, 2007 | 08:18 PM
goin440's Avatar
goin440
See link.
I'll caution, my sources remain too quiet. IMHO, its been done. But who has it...? (I'll venture its tracked competitively somewhere as "stock", mum seems to be the word)
Useable 2.0l mopars are cheap, $400. Parts to rebuild are way cheap, theres millions of them in existance. The big things are the custom bell housing for the tranny (which shouldn't be too expensive to have fabbed considering the motors are nearly identical) and wiring harness, might be simple...? Next are the custom engine mounts; not a big deal. Oh, also you'll need a custom intake manifold (is a big deal).
Further, if the 2.0l fits, the 2.4l is also a possibility (literally a motormount away). SRT Cooper anyone... ?
Old Jan 11, 2007 | 11:16 PM
UKSUV's Avatar
UKSUV
Originally Posted by goin440
See link.
Did you toatlly miss my post? Re-read it....Im not talking a 300 HP SRT-4 upgrade from Dodge. This is a FULLY BUILT Cosworth STi motor that pushes 750 HP! I wanna do ^^^^^^^^^THAT!^^^^^^^^^^^
Old Jan 12, 2007 | 02:41 PM
goin440's Avatar
goin440
I saw it... but this is easier.
If you can afford that.... git-r-done did. (I love the throaty subbie boxer)
It'd be hilarious to put an STi badge next to a JCW.
Old Jan 14, 2007 | 12:13 PM
AliceCooperWA
It could be a STooper I
Old Jan 14, 2007 | 12:31 PM
mitchman's Avatar
mitchman
There's no way that STi motor would fit between the wheel well. Heck, even if you removed the wheel wheels, I'm not sure it would fit betwen the struts.
It would be interesting to know the measurement between the STi upper strut mounts (where they mount to the wheel wells) and the distance between the Mini's upper strut mounts.
I think you'd be better off putting a RWD setup in the car. But then you'd have to modify the firewall.
Fun to think about though.....
Old Jan 15, 2007 | 10:44 AM
flannelhippie's Avatar
flannelhippie
Originally Posted by justintime
or mabye the srt4?
NO!!! Bad justintime. SRT4's are sooo ugly, and lame. Theyre fast, but soooo ugly. Its a neon.
Old Jan 16, 2007 | 01:17 PM
justintime's Avatar
justintime
haha the motor isnt
Old Jan 17, 2007 | 08:26 PM
flannelhippie
haha the motor isnt
Yeah still. The turbo Mitsu, the motor is Dodge. Ya know when some 240sx guys pop the hood and say its a skyline engine? This isnt the same thing.
Old Jan 17, 2007 | 08:45 PM
Deviant's Avatar
Deviant
Well, the SRT4 motor may be a possibility but don't the S models have a similar transmission to the SVT Focus?
Another possibility is swapping in the chrysler internals into the stock block to bring the 1.6L to 2.4L. Although Chrysler claims the two engines are fairly different. http://www.allpar.com/mopar/rover.html
Old Jan 17, 2007 | 09:30 PM
Redbird06's Avatar
Redbird06
I was thinking the same thing the other day about the R56 motor and the 6-speed Getrag.
Best of both worlds...
Old Jan 17, 2007 | 09:56 PM
justintime's Avatar
justintime
will the svt focus motor fit? and I thout WRC standards required a 2.0? thats just a guess that I have nothing to back up with. AND wasn't the SVT created for rally?
Old Jan 22, 2007 | 02:07 PM
hemiheaded18's Avatar
hemiheaded18
If I had the $$$, and it would have to be a lot, I would front half one and put a blown SHO 3.0 in one. The turbo SHO's and even nastier but a lot more plumbing and hassle. The blower from a SC T-bird is a popular unit to use. A Mini turning 7500 RPM with 350-425 at the wheels would destroy a lot of things.
Old Jan 22, 2007 | 07:35 PM
justintime's Avatar
justintime
more like most things and thats what I want
Old Jan 23, 2007 | 08:10 AM
Dr. Pepper's Avatar
Dr. Pepper
I like this idea! Do it the American Way and bore and stoke that sucker.
BRracing
Oct 24, 2015 10:07 PM
gmonde
Sep 28, 2015 05:22 PM
Mb460
Sep 14, 2015 05:50 AM
offroadratfabricator
Sep 6, 2015 09:54 AM
Manny_cooper
Sep 3, 2015 05:48 AM
