Cooper (non S) Modifications specific to the MINI Cooper (R50).
Alta vs K&N Panel Filters
Old Oct 13, 2005 | 09:43 AM
atl05mca's Avatar
atl05mca
NM Community;
Since it appears there are no CAIs for the newer 05 MC's (non S), will probably go panel filter route...
Anyone out there have any experience with the Alta foam ? Does the foam deteriorate over time ?
Anyone ever compare the Alta and K&N ??
Thanks in advance.....
Old Oct 13, 2005 | 03:21 PM
asodestrom's Avatar
asodestrom
I haven't tried either the Alta or K & N drop in filter, but I have tried a foam drop-in from Moss and a pipercross induction kit which is foam, and a green twister CAI system. I tested all three with multiple pocket dyno runs and the foam panel filter consistently turned better numbers that either cone type filter.
I stayed with he pipercross because even though the drop in showed better hp numbers, the pipercross didn't choke as much as the drop-in at higher rpm's.
I may go back to the drop in because my MTH upgrade took care of the high rpm airflow issues
Old Oct 25, 2005 | 07:16 AM
Torkor's Avatar
Torkor
Check out this link. It`s strictly a filter test which should be adequate for which panel filter to choose.
Tormod
Old Oct 25, 2005 | 08:22 PM
ultramini's Avatar
ultramini
K&N panel Filters
I have K&N panel filters that I did not notice any different with the performance. I first got the K&N panel for my honda accord that I felt the extra power from the car. I thought I may have similar result if I add the K&N to my MINI. But I could not feel any different.
BTW, I have 2003 CVT.
UltraMINI
Old Oct 30, 2005 | 10:35 AM
Thinker2112's Avatar
Thinker2112
[font='Times New Roman']I’ve had an Alta foam filter in my 04 MC for about 2 months. Alta claims 3hp gain, not something that you "seat of your pants" dyno can feel. The only thing that I can tell is a slight increase in throttle response. Was it worth the $45 with the cleaning kit? Kind of. I just want to get 115 hp on the street, so I guess I'm .6 hp closer to my goal[/font]!
Old Oct 30, 2005 | 11:35 AM
OldRick's Avatar
OldRick
It's an air filter, people. How much difference would you expect to see from a different brand of air filter? :impatient
If you get 1% more power at high RPM, you will be doing well from changing the air filter.
Oh, and BTW, you won't get as effective filtering of airborne particles...
Old Oct 30, 2005 | 12:04 PM
Stevie B's Avatar
Stevie B
UltraMINI
It totally depends on the car. I had an '02 Audi A4 that the stock airbox/fitler flowed more air than the car could use so going to a higher flow filter would do nothing. The MINI is the opposite. It isn't getting the flow it needs. A foam air filter such as the Alta will increase the flow, and it filters the air far better than stock, mainly due to the characteristics of the dense foam and oil suspension it carries. In my ex-Ducati I used a foam in-airbox filter over the two velocity stacks and after removal to clean, there was never any evidence of dirt. As with the Audi, my in-box JHP aftermarket foam airfilter for the Ducati added a zero net HP increase, but the cleaner air was worth it. BTW, the Ducati filter was $125. Isn't the MINI wonderful!
Old Oct 30, 2005 | 04:16 PM
OldRick's Avatar
OldRick
Read this link for a test of filtering effectiveness.
Old Nov 22, 2005 | 10:55 AM
Bradley99's Avatar
Bradley99
Thanks for posting that. As the author said, it is not as scientific as it could have been, nonetheless it doesn't refute what I had read and had suspected: for a street application the filter should be chosen for filtration ability rather than flow.
That being said, I'm still looking for a CAI because I want to hear some whine just for fun, but I will look for one with a fiber element rather than the oiled foam element.
Old Nov 23, 2005 | 06:44 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Now HERE's an air filter!
http://www.rpmsportscars.com/door26.htm
Old Nov 23, 2005 | 08:02 AM
erik99's Avatar
erik99
Or four . Damn, ITB's are sexy.
Old Nov 23, 2005 | 12:56 PM
Bahamabart's Avatar
Bahamabart
Originally Posted by atl05mca
NM Community;
www.MYMINIparts.com has a CAI for non-s
Old Nov 24, 2005 | 05:06 PM
jazmini's Avatar
jazmini
Those Myminiparts have some nice stuff!
Old Nov 25, 2005 | 07:31 AM
Bahamabart's Avatar
Bahamabart
From the board, I've learned there are a few good shops with really good people. I'm fortunate that the MYMINI shop is near me which has given me the opportunity to get to know Peter. Good guy, MINI enthustiast first and lots of fun to work with modding your MINI.
patsum
26
May 29, 2021 06:29 PM
rtk90
Aug 29, 2019 09:08 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
