Cooper (non S) Modifications specific to the MINI Cooper (R50).
Wheels and tires from 2012 on 2003
Old Aug 16, 2012 | 07:40 PM
donamor's Avatar
donamor
Hi, anyone know if I can use 2012 wheels and tires on older 2003?
This is what I have:
My current Tires: Goodyear 195/55r16 - 87H - (Overall diameter is 24.444)
I want to know if I could replace with this:
2012 OEM wheels and tires: 175/65r15 - 84H (Overall diameter is 23.956)
I believe both are run flat. But the 15" - would this work? is it recommended? i guess the overall diameter is a bit smaller. thanks for info
Omar
Old Aug 17, 2012 | 09:38 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I don't know about it being recommended, but the 15" wheels should work.
More info here:
https://www.northamericanmotoring.co...15-wheels.html
888.280.7799 | 6am - 5pm PST
Old Aug 17, 2012 | 10:42 AM
donamor's Avatar
donamor
Thanks Pelican. So much to consider. I'm just in need of new tires and a friend bought a new 2012 and would sell set to me because he put on different set. I gues I'm reading that I'd get softer ride and better handling but worse mpg? I'm still confused as to mileage on speedometer ..would I be adding more mileage than actually traveled? I did diameter calculations to see how much overall difference I'd get. Or should I just get new tires with same rima? I live in los Angeles so not really needing to have to switch to winter tires. I guess I can still keep the 16 but not sure about advantage to this. It seems like they may have some advantage. Any recomendations would help thanks. I'm not too knowledgeable about wheels and tires . Thank you.
Old Aug 17, 2012 | 11:29 AM
donamor's Avatar
donamor
Details on tires and wheels
I just found a great website that compared for me the tires I have with what I'd be getting. Also showed pictures so the ones I have look a bit wider- and the revs would have to go up and i'd see a 2% speed increase in my speedometer. anything to worry about?
First is my current ones. so it looks like
Stock Tire - 195/55R16 Tire 1 - 175/65R15
Section Width: 7.67 in
Section Width: 6.88 in
Rim Diameter: 16 in
Rim Diameter: 15 in
Rim Width Range: 5.5 - 7 in
Rim Width Range: 5 - 6 in
Overall Diameter: 24.44 in
Overall Diameter: 23.95 in
Sidewall Height: 4.22 in
Sidewall Height: 4.47 in
Radius: 12.22 in
Radius: 11.97 in
Circumference: 76.78 in
Circumference: 75.24 in
Revs per Mile: 851.0
Revs per Mile: 868.4
Actual Speed: 60 mph
Speedometer1: 61.2 mph
Speedometer Difference: - Speedometer Difference: 2.044% too fast
Diameter Difference: - Diameter Difference: 2.01%
Old Aug 17, 2012 | 11:50 AM
donamor's Avatar
donamor
I called the dealer and they were no real help. They just said I'd have to have them put on and tested because even wheels from same year might interfere with break system, or other issues.. that they couldn't tell me anything unless they were put on. :(
Old Aug 17, 2012 | 11:55 AM
Eric_Rowland's Avatar
Eric_Rowland
With a smaller diameter, your wheel is turning more revolutions to go the same distance, thus more miles on the odo, and lower effective gas mileage. On the other hand, the narrower width should have slightly less rolling resistance. 2% is not that big of a difference. Can't see how they'd give you better handling.
I don't believe the 15" are runflats. If you get them, get a plug kit (like dynaplug) and a small compressor.
Generally rim size is a personal choice. Lower aspect ratio (more rim, less tire) gives a different look, and more precise handling. They also tend to be more expensive. If you don't mind the look, and you're getting a good deal, it's not a bad idea.
Old Aug 17, 2012 | 01:10 PM
Blackbomber's Avatar
Blackbomber
Assuming the OP didn't post in the wrong thread, he has an R50, which does have a spare - no plug kit needed...
Old Aug 17, 2012 | 02:01 PM
donamor's Avatar
donamor
Eric, thanks so much for the reply. I guess if it was more tire and less rim i'm reading that it might give you a softer ride. That would be great but I don't think that is much the case with these that I am looking at. Yes, I'd be getting a good deal and apparently they are run flats. Just the stock ones. I thinkt hey are Continental? not good on ending up with more mileage on the odo but I guess that's just the way it is. I'd be getting the tires and wheels for less than just run flats on my wheels. that's why i'm enticed to do it.
Old Aug 20, 2012 | 09:56 AM
PelicanParts.com
Vendor
If you don't mind me asking, how much are the 175/65r15s you're looking at? I would personally stick the 16s and just get new tires, imo.
-Jorge
Old Dec 22, 2012 | 10:25 AM
trev0006's Avatar
trev0006
Awesome info, Thanks
Stock cheap tires - 195/55R16 Tire 1 - 175/65R15
Rim Diameter: 16 in
Rim Diameter: 15 in
wheels Width Range: 5.5 - 7 in
Radius: 12.22 in
Radius: 11.97 in
Speedometer Difference: - RC cars Speedometer Difference: 2.044% too fast
pre shrunk
Aug 18, 2015 11:09 AM
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
nomar116
Aug 9, 2015 09:42 AM
