Cooper (non S) Modifications specific to the MINI Cooper (R56).
DDMWorks Intake
Old Aug 9, 2012 | 05:13 PM
lyz77's Avatar
lyz77
DDMWorks Intake
Anyone manage to install the DDMWorks R55/56/57 Cooper (Non S) Intake and JCW strut bar without any issue?
I intend to order DDMWorks but I got mix answers as some supplier mention the JCW strut bar will obstruct it and some doesn't.
I use to be on the K&N Typhoon intake and was able to install the JCW strut without any issue.
Old Aug 9, 2012 | 05:16 PM
DChase's Avatar
DChase
Have you bought the strut bar? There is much debate whether or not the bar is even necessary or does much at all to improve the car's performance.
Then again, there's a similar argument about CAIs as well
Old Aug 20, 2012 | 01:02 PM
sean5294's Avatar
sean5294
i have, no issues at all
Old Oct 13, 2012 | 11:48 PM
lyz77's Avatar
lyz77
Just got my DDMworks intake and plan to install it on my own. Apparently, I did not expect that the installation require the removal of the entire stock intake. (Previously was on K&N and it only require the removal of the top intake cover.)
While trying to remove the base of the stock intake, there are 2 nut which is not the usual screw/ nut we see securing the intake. Wasn't able to remove it as I do not seem to have any tools to remove them. Does anyone have any idea what kind of screw or nuts are those and how to remove them?
Thanks in advance!
Old Oct 14, 2012 | 01:01 AM
MinMin2010's Avatar
MinMin2010
This is on an S, but you can see there is no clearance issue with the JCW strut bar.
Old Oct 17, 2012 | 11:07 PM
lyz77's Avatar
lyz77
Anyone manage to install it own Mini Cooper Non S LCI model? I am starting to wonder if this is compatible as the installation guide seem to be different on the stock intake that I am having.
Old Oct 26, 2012 | 09:04 AM
sean5294's Avatar
sean5294
I have, no problems at all
Old Oct 28, 2012 | 05:11 PM
lyz77's Avatar
lyz77
Hi, do you mind posting some pics of the installation? From the installation guide, it seem like it only require the removal of the top stock intake. However, it seem that I need to remove the entire stock intake in order to install the DDM intake.
Any idea how to remove this bolt?
Old Dec 21, 2012 | 04:50 AM
Gdizzle's Avatar
Gdizzle
I got mine installed and love it!!
The housing just pulls off of those screws. Then when you attach the new box the new supplied screws just screw into those!
Attached Thumbnails DDMWorks Intake-img_1245.jpg   DDMWorks Intake-img_1244.jpg   DDMWorks Intake-img_1250.jpg
Old Dec 21, 2012 | 08:24 AM
lyz77's Avatar
lyz77
Thanks!
rtk90
Aug 29, 2019 09:08 AM
67morris
May 7, 2016 11:52 AM
Sep 22, 2015 02:05 PM
knbond1
Sep 22, 2015 06:20 AM
Sep 11, 2015 11:09 AM
