Cooper (non S) Modifications specific to the MINI Cooper (R56).
Need help
Old Dec 30, 2012 | 11:51 PM
Ninopr's Avatar
Ninopr
Need help
How can I tell if the power steering pump just went bad or if its something else. What i know is that its not leaking, When I turn my car on it would steer just fine for about 2 minutes and that is when it start feeling like the pump stops pumping fluid and just stops working.
Also i don't know if it has anything to do with the pump but when i come to a stop light my car feels like its going to cut off?
Old Dec 31, 2012 | 05:25 AM
Braminator's Avatar
Braminator
It may or may not be the pump. Sometimes when your battery is starting to go that can happen. Do a search on failed ps pump and you will see lots of possibilties. Keep us posted.
Old Dec 31, 2012 | 09:31 AM
ammodave's Avatar
ammodave
Don't bother searching for a power steering "pump"; there is no pump on the R56. The steering 100% electromechanical; no hydraulics involved. Search "power steering" instead.
Old Dec 31, 2012 | 09:44 AM
Braminator's Avatar
Braminator
Did I miss where he said it was a R56? If I did, it was my bad. I did notice in his garage it said 2004 Base MINI
Old Dec 31, 2012 | 10:41 AM
ammodave's Avatar
ammodave
You may be right! I just assumed it was an R56 because it was posted in this forum.
Old Jan 1, 2013 | 05:01 PM
Ninopr's Avatar
Ninopr
I own a 2004 mini cooper R50 and about a week ago my steering stopped working, checked for leaks and nothing what I noticed was that when i turn my car on and the steering would work for about 2 minutes and then it would just stop working???
Old Jan 1, 2013 | 07:41 PM
Braminator's Avatar
Braminator
Read this and then do a search on the power steering pump.
https://www.northamericanmotoring.co...p-failure.html
