Cooper (non S) Modifications specific to the MINI Cooper (R50).
True dual exhaust system??
Old Nov 27, 2010 | 08:16 PM
nigelthecooper's Avatar
nigelthecooper
Is it even remotely possible to install a true (2 cats, 2 mufflers, 2 pipes) dual exhaust system on a MINI? It would be hella expensive and possibly serve no purpose, but I want to know if it can be done.
Not planning on trying it; my mind just plays in strange places .
Old Nov 28, 2010 | 06:36 AM
Da_Ghost's Avatar
Da_Ghost
It's a 4 cylinder, so no! It would indeed serve no purpose and add a lot of weight! And there's really not any room under the car for this kind of setup!
Old Nov 28, 2010 | 06:52 AM
ZippyNH's Avatar
ZippyNH
Like said previously, a 4 cylindar only has one headder...so it never be a "true" 2 pipe set-up...
Plus the fact the computer only has inputs for one pre and one post cat O2 sensor means you would have a light, or need a simulator for the 02...
To keep the volume enough with 2 sets of pipes, you would need tiny pipes, mufflers, and cats...lots of wight, plumbing, and complexity, to gain nothing...
Just remember, one header, one pipe. That is why a v6 or v8 does best with 2 exhausts..(sometimes a x pipe too).
Old Nov 28, 2010 | 07:14 AM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Techniclaly it IS possible. Just not worth the time or money.
Can we say modifyed 4-2-1 header, just cut the final collector off and run 2 pipes. You would still need to solve the o2 sensor issue though.
Old Nov 28, 2010 | 07:53 AM
Da_Ghost's Avatar
Da_Ghost
And by splitting the final connector, it would mean that you have 2 cylinders per exhaust, you would probably loose a lot of efficiency since only 2 cylinders push the exhaust gas out!
Old Nov 28, 2010 | 08:27 AM
ZippyNH's Avatar
ZippyNH
And you would need 4 cats, not 2...
Mini's like most modern cars have a smaller "precat" and the regular cat to work right....
DICKS GARAGE R53
Yep. It might sound kinda cool if you did side pipes like this though, but still SUCK!
Old Nov 28, 2010 | 09:16 AM
nigelthecooper
Your replies have been most enlightening.
I had the feeling that, given the underbody space constraints and the architechture of the engine, such a setup would be difficult to produce and most likely serve only an aesthetic purpose. I wanted to know if it was even possible.
Thank you
Old Nov 28, 2010 | 09:19 AM
KC Jr 54's Avatar
KC Jr 54
The MINI doesnt need the pre-cat to work right....neither do most modern cars.
So just two would be needed really.
Silly idea though.
Old Nov 28, 2010 | 09:38 AM
ZippyNH's Avatar
ZippyNH
Silly idea though.
I guess you don't consider the Gen1 mini "modern"....
It has a pre-cat....
Old Nov 28, 2010 | 11:03 AM
laforze's Avatar
laforze
I think you missed his point...modern cars don't "need" pre-cats.
Chippawaguy
Aug 18, 2015 11:17 AM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
