Cooper (non S) Modifications specific to the MINI Cooper (R50).
parts needed to rebuild a Midland
Old May 31, 2008 | 06:42 AM
nickbmw's Avatar
nickbmw
As the title says, what are the needed parts to rebuild a Midland gearbox?
http://minifans.info/original/R50/Co...2002/01/mg-23/
This is the link to the Midland gearbox. What should be changed during a rebuild?
Also, could some tell which part is the synchro of the 2nd gear?
Old May 31, 2008 | 07:00 AM
chadtoolio's Avatar
chadtoolio
Realoem.com has better diagrams only due to the fact that the parts names are in there with the Part numbers.
What you need depends on what you've torn up. Bearings and seals for sure, all else just depends on the carnage.
Old May 31, 2008 | 07:05 AM
nickbmw's Avatar
nickbmw
Do i need to change all the bearing i can see in those diagrams?
My problem is that the second gear "hits" hard when i am shifting at high rpm!
Old May 31, 2008 | 05:02 PM
AliceCooperWA's Avatar
AliceCooperWA
If you are going to go through all of the trouble to get to it and then open it up, you might as well spend a little more money for the rest of the internals. If I were to open up my tranny, I would completely rebuild it. Although theoretically, you only need to replace what has gone bad.
Old May 31, 2008 | 05:06 PM
AliceCooperWA
Originally Posted by johnfromaus
the part numbers are:
23211036989
3110662419
23117518638
23117550058
23121036984
23200630777
23200662267
23201037013
23201037014
23201037068
23210632252
23211036995
31531030851
31607518253
31531035645
all up parts cost was around AUD$250 and shipping to melbourne was about $100, so $350 all up. I got a whole bunch of other bits and pieces while i did this, but this was the basic cost of gearbox bearings/seals. i found all the part numbers from the diagrams on www.realoem.com. VERY useful.
i replaced all bearings, seals and spacers/washers, you may not need to. get what you need. hope it helps.
I think this is everything...? search for the numbers on pelicanparts.com or realoem.com pelican parts has the parts, realoem has the diagrams etc.
Sincro part numbers here: http://www.realoem.com/bmw/showparts...84&hg=23&fg=15
Old May 31, 2008 | 10:56 PM
UKSUV's Avatar
UKSUV
Im so glad my synchros werent bad...luckily mine was an easy fix....stoopid shift fork! I would say you could buy mine cause im purchasing a 6-sp....but your pretty far away!
Old Jun 1, 2008 | 04:03 AM
chadtoolio's Avatar
chadtoolio
Update, that website has the diagrams with the P#s, you just have to click on the diagram and the page will reload with a bigger diagram and the numbers below....Nice site http://minifans.info/original/R50/Co...2002/01/mg-23/
Old Jun 1, 2008 | 07:45 AM
AliceCooperWA
How difficult do you think it would be to change the syncros? I am planning on changing everything that bears load...so pretty much everything. The closest I've gotten to getting into a transmission is looking at the diagrams on realoem.
Old Jun 1, 2008 | 07:47 AM
AliceCooperWA
Same diagrams as realoem, but it looks better with the black background and the pictures of minis...
Old Jun 2, 2008 | 04:11 PM
UKSUV's Avatar
UKSUV
Let me get my teardown pics from my buddy tonight if he is in town and I will post em up. Trust me...its easy...
Old Jun 2, 2008 | 09:13 PM
AliceCooperWA
Thats awesome. That makes me feel much better about knowing that my midlands will fail soon. At least I have another option. I never even considered rebuilding it myself, mainly because I have never even opened one up and places charge so much to work on them.
Any pictures would be great.
Old Jun 3, 2008 | 07:38 PM
putttn's Avatar
putttn
You guys must have some mechanical ability. I don't even know how to get the tranny out let alone open it up and fix it. But for the $8000 I've been hearing this might be the time I learn from people in this forum who have done so. Is it really that simple to replace/rebuild the Midlands?
Old Jun 3, 2008 | 10:21 PM
UKSUV's Avatar
UKSUV
Yes...it is. And I just bought a 6-speed and have dealings with a MCS/tranny right now. So, if you need to replace anything...this is the way to go....
Old Jun 4, 2008 | 05:09 AM
putttn's Avatar
putttn
Are you saying it's better to go w/6speed or rebuild the Midlands?
Old Jun 4, 2008 | 07:37 AM
nickbmw's Avatar
nickbmw
The 6 speed is heavier and needs lots of other parts.
In my opinion, the best choice is the Getrag 5 speed, but it's not easy to find, and not going to be cheap!
Old Jun 4, 2008 | 01:50 PM
UKSUV's Avatar
UKSUV
Yes...you will need a few expensive parts to retro a 6-speed...but in my mind its worth every penny...
Old Jun 9, 2008 | 04:43 PM
UKSUV's Avatar
UKSUV
Well...I lost the 5th gear synchro yesterday. It pops out of gear on throttle pushes. Oh well....the 6-speed be on the way!
Old Jun 9, 2008 | 07:50 PM
AliceCooperWA
Wouldn't you have to replace the same expensive parts for swapping to a getrag 5spd and 6 spd. I think both swaps involve swapping out the same parts.
Old Jun 10, 2008 | 01:33 PM
UKSUV's Avatar
UKSUV
I have the PDF from TSW. You basically need tranny/mount/clutch slave cylinder and axle shafts. For the most part.
Old Aug 8, 2008 | 01:21 PM
Bajanmini's Avatar
Bajanmini
I am about to do a clutch and poly bush job on my R50 and see that gearbox internals are available from Mini Mania let alone a rebuilt gearbox.As it's off what's your opinion of rebuilding it at 45k,according to UKSUV it's easy,parts dont look that expensive.
Old Aug 8, 2008 | 04:33 PM
AliceCooperWA
I only know of 1 person who swapped for the Mini Mania rebuilt midlands. He had it shipped to the states from overseas, then it blew out after a couple of months. I don't think he is on here anymore, but his username was ranzo. Search for his thread from a while back. The uprated Midlands stuff was only available from minimaniaUK, but I can't seem to find it anymore. I believe the uprated internals are from a peugeot. I guess if you are going to rebuild the internals, you might as well get something stronger than oem. It would probably be more cost effective to just get the internals and rebuild it yourself since you would have to pay for shipping a rebuilt tranny from the UK. You might want to search on MINI2 since there are many more on there in the UK. There are likely a lot more people over there running that transmission.
good luck!
Old Aug 8, 2008 | 04:38 PM
AliceCooperWA
As for rebuilding it while you have everything apart, thats a tough one. I want to say you should go ahead and do it since the tranny will be accessible, but at the same time, there are many that have gone over 100k miles without breaking their midlands. You could inadvertantly create problems by digging in there and replacing everything. I would say just wait until it breaks. If it aint broke, don't fix it IMO. BTW, I'm on my second midlands and I have 60k on the current one. It is still running fine (knock on wood!).
Old Aug 11, 2008 | 08:38 AM
Bajanmini's Avatar
Bajanmini
Thanks for the reply,both the internal parts and the rebuilt gearbox are advertized on Mini Mania,before it was only available out of the UK website,i'm on my second box as well,the first went under warranty at a year and this one has lasted 4 yrs,i tend to agree if it aint broke dont fix it,gonna keep my fingers crossed.At least we've got an option.
Old Aug 11, 2008 | 04:15 PM
AliceCooperWA
Hopefully my tranny holds up long enough for someone else to rebuild with those uprated internals! I'd hate to be the first...
Old Aug 11, 2008 | 09:15 PM
UKSUV's Avatar
UKSUV
As far as I know...the "uprated" gearbox is only a stronger welded shaft input or something. TSW has went through 2 or 3 of these "uprated" gearboxes. The Midlands is just garbage. If your gonna spend the money...why not go for a 6-speed anyways?!? I dont get it. I got my tranny for 1100. Flywheel and clutch...400. Misc parts..100 and 1/2 shafts roughly 400 used (1500 if you pay dealer cost. 800 if you have a buddy...LOL). Grand total for me?...2K.... ) Not bad since you will pay more for a Midlands. Or if you dont do a 6-speed....why not throw in a Getrag 5-speed instead of the Midlands if you are die hard 5-speed do-gooders.
