Cooper (non S) Modifications specific to the MINI Cooper (R50).
Cat Back HP Loss?
Old May 26, 2008 | 10:57 AM
Fritzoc's Avatar
Fritzoc
Cat Back HP Loss?
I just installed a K&N drop-in and a Megan Racing cat back.
Car feels noticeably slower in 2nd and 3rd gear. I did put on 16" wheels with 205/50/16 tires as well. I realize these may make the car accelerate more slowly vs the stock 15s. Car seems slower still after the cat-back install.
Could the cat-back actually have stolen HP from the car? I did have it professionally installed at a reputable shop.
Old May 26, 2008 | 11:24 AM
nickbmw's Avatar
nickbmw
What cat back did u use? I have 205-50-16 as well, and that 's a good reason to feel the car became slower.
Old May 26, 2008 | 11:25 AM
Fritzoc's Avatar
Fritzoc
Megan Racing cat-back
Old May 26, 2008 | 12:04 PM
UKSUV's Avatar
UKSUV
There should be no reason why it would decrease power. It will only INCREASE your TQ unless they were using a 3" or larger diameter pipe on the Cooper.
Old May 26, 2008 | 05:46 PM
hemiheaded18's Avatar
hemiheaded18
Heavy wheels? Otherwise, I have no idea. My Borla woke my car up a bit when coupled with the DDM.
seigmann's Avatar
seigmann
Make sure and check for exhaust leaks
Old May 26, 2008 | 05:50 PM
MINIFVR's Avatar
MINIFVR
the power may not be felt immediately down low in the rpms. most of the gains should be top end. do you mainly drive down low?
Old May 26, 2008 | 06:02 PM
hemiheaded18
Good point. My car feels more free through the revs with the Borla it's mainly felt at about 4k and up. It'll cleanly pull to redline where as before it sort of lagged up there.
Old May 26, 2008 | 08:07 PM
AutoXCooper.com's Avatar
AutoXCooper.com
The Catback is not stealing power. Please check for leaks and visit, http://www.1010tires.com/tiresizecalculator.asp and run the numbers to see how you may have changed the way the MINI drives without knowing it.
I made the change to larger tires for comfort and did it knowing that I would give up some "power" off the line. But it's worth it since I have smaller R-comps for AutoX.
Old May 26, 2008 | 08:19 PM
R50 Paul's Avatar
R50 Paul
It's the wheels, the 15" with the 175/65-15 Conti's really make the Cooper pop off the line.
Old May 27, 2008 | 05:08 AM
Fritzoc's Avatar
Fritzoc
I did feel the "loss" of power when I switched to the different wheels/tires. Seems like a noticeable loss of torque after the cat back install. I also thought about an exhaust leak. How do I check for that?
Thanks for all the thoughts.
Old May 27, 2008 | 05:57 AM
hemiheaded18
You'll be able to hear it. It'll sound like air leaking (almost like a hiss or pop sound) from one of the joints in the system.To put it one way, instead of making noise at the back through the muffler, it'll be making noise before that.
Old May 27, 2008 | 07:40 AM
erickvonzipper's Avatar
erickvonzipper
You should also be able to feel it. Get the car in the air enough to be able to slide under and move your hand around the joints in the system. Don't touch anything (hot!), and make sure the car is securely in the air - jackstands, not just the car's jack or even a hydraulic floor jack by itself.
Btw, I will never trust the car's jack again. A friend was working on a MINI, sitting at the wheel well, with part of his legs just under the car. The car was on the car's jack, and it bent, coming down on his leg. He is recovering. My apologies that I don't have all the details.
Zip
Old Jun 7, 2008 | 07:37 AM
nickbmw's Avatar
nickbmw
Maybe our friend is right. The Megan Racing cat back for the Cooper has 2.25 inch piping, and that is definetally too much for a stock Cooper, when stock piping is 48mm!! And Megan is 57mm! I would say it loses power for sure!
Old Jun 7, 2008 | 08:34 PM
AutoXCooper.com
This is the 1st and only report of power issues known to AXC or Megan Racing with 100's of systems on the road. There are other R50 systems with 57mm pipes without reports of less power.
The issue is not the Megan Cat Back.
Old Jun 8, 2008 | 03:20 AM
nickbmw's Avatar
nickbmw
Ι don't know what is the issue is for sure, but definetally a 57mm pipe for a Cooper is totally wrong. I don't know where this choice was based on, but the best exhaust brands out there don't go further than 50mm.
Old Jun 8, 2008 | 05:24 AM
Fastlane's Avatar
Fastlane
I installed a Megan a few months ago and definitely did not experience any power loss. Not really sure I gained any power, though. The sound is what I was looking for and I certainly got that.
Fritzoc: I know it sounds dumb for me to ask since I'm sure you took this into account....are you running your A/C now that is hotter outside when you may not have been before? There's nothing that kills power on an MC quicker than hitting that A/C button. My car is a hoot to drive...till the Air Conditioning is switched on...then it's just a dog. You really pay for comfort in this car. I usually decide to roll down the windows and sweat....you get to hear your Megan better that way anyway.
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
