MINI Cooper non-S and MINI One dyno sheets
Subscribe
Feb 1, 2008 | 01:21 AM
I thought I would start this topic to show how many people around the world have been on a dyno with their Coopers/Ones.
This is a Cooper with software, K&N Typhoon and exhaust.
It shows three lines for HP and Torque.
The green one shows the stock HP.
The other two show the HP with all his mods and a more finely tuned software is what created the black line.
HP : 122 at flywheel
Stock : 111hp
Drivetrain loss : 17%
Dyno :Cartec
This is a Cooper with aFe intake and custom exhaust.
He produced 119,7hp at the flywheel and 101hp at the wheels.
Drivetrain loss = 18%.
Dyno : Superflow
Reply 0
Feb 1, 2008 | 01:24 AM
This is a Mini One which had 88hp stock.
With Bluefin software, K&N Typhoon with custom heatshield and exhaust he now has 121,7hp at the flywheel and 103hp at the wheels.
His custom heatshield:
His dyno sheet:
Dyno : Superflow
Reply 0
Feb 1, 2008 | 01:26 AM
Another Cooper.
This guy also has an aFe intake and an exhaust.
He produced 119,6hp at the flywheel.
Dyno : Maha
Drivetrain loss : 21%
Reply 0
Feb 1, 2008 | 01:31 AM
Mini Cooper
Software
Supersprint headers
Supersprint midpipe
Supersprint exhaust
Pipercross Viper intake
HP : 128hp at the flywheel
Nm : 178
Drivetrain loss : 19%
Reply 0
Feb 1, 2008 | 01:32 AM
Mini Cooper
Supersprint headers
JCW exhaust
K&N Typhoon intake
Software
Hp : 122
Nm : 160
Reply 0
Feb 1, 2008 | 01:33 AM
Mini Cooper
MTH software
JCW intake
JCW exhaust
HP : 123 (flywheel)
Nm : 159
Drivetrain loss : 20%
Reply 0
Feb 1, 2008 | 01:37 AM
My own Mini Cooper.
Software
BMC CDA
Eisenmann exhaust
air diverter plate
HP : 123 (flywheel)
Dyno : Maha
Reply 0
Feb 1, 2008 | 01:51 AM
This guy pulled 102 and 103hp at the wheels.
This puts him at about 116 - 117hp at the flywheel.
Dyno : Mustang dyno
Member : justintime
Forum : motoringunderground
He didn't include a dyno sheet, so these are his words:
so I took the mini to the dyno and my first pull was 102hp and 108 tq.
then I pulled a 103 with 99 tq
then 100 with 98 tq
sad day on the mustang haha...
I was kinda hoping for 125 range but I guess the cooper wasnt true to the stock 115. whatever formula the guy used on his calculator said I gained about 8 hp from the intake and exhaust.
Reply 0
Feb 1, 2008 | 02:12 AM
If you also want to know about people's experiences on several dynos all over the world, check out these forums.
If you do some research on there, you will see that people have similar results with their Coopers/One's as the dyno sheets that I posted.
http://forum.mini2.be/index.php
http://www.newminiclub.nl/forum/
http://www.motoringunderground.com/forum/index.php
Reply 0
Feb 1, 2008 | 02:16 AM
Mini Cooper
Software
HP : 120,6 (flywheel)
Drivetrain loss : 23%
Reply 0
Feb 1, 2008 | 02:28 AM
Mini Cooper
Software
K&N Typhoon
Bastuck exhaust
HP : 120
Dyno : Maha
Reply 0
Feb 1, 2008 | 02:43 AM
Mini One/Cooper
Superchips Bluefin with Lohen LO3 map
Milltek Cat-back exhaust
Modified manifold & removable high-flow cat
Pipercross Viper kit
Iridium spark plugs
Lohen Performance Head
Camshaft
Exhaust valves
Lohen 58mm Throttle body
Replacement gaskets & head bolts
HP : 150 (flywheel)
Price of all the mods : $7000
Dyno : Superflow
Check out the mod list, this is what it takes to get to 150hp.
Reply 0
Feb 1, 2008 | 02:55 AM
Also, a Dutch group of Mini Cooper owners (8 cars) did a dyno day.
They collected all the data and put it in a pdf file.
Note how all the Cooper produce around 115hp at the flywheel stock.
The pdf file also includes all the modifications.
The highest was 121hp (flywheel) with software, intake, exhaust.
Drivetrain loss was around 22%.
This guy called "Beek Autoracing" is the number 1 tuner in Holland.
He builds racecars and works together with some of the best known European tuners.
Many people don't believe in MTH anymore because 99% of the people who bought MTH software, produced about 10hp less than was promised to them.
They sent several letters, e-mails and got no real answer from MTH.
Some of them got their money back, some didn't.
Link to the pdf file:
http://www.newminiclub.nl/data/mc_power.pdf
Reply 0
Feb 1, 2008 | 03:09 AM
Dyno warning:
http://www.dmhmotorsports.net/DynoWarnings!.html
Quote from dmhmotorsports:
...testing of any kind, be it on a dyno, a flowbench, or even a road test, the results are only as good as the testing method, and more importantly, the ethics of the tester. False or inflated claims, however, have a way a coming around to bite the ones who foster them on their unsuspecting customers...
Reply 0
Feb 1, 2008 | 03:38 AM
Mini Cooper
Promini Cold Intake
Exhaust
Engine damper
Nology hot wires
HP : 103hp at wheels
Reply 0
Feb 1, 2008 | 03:39 AM
Mini Cooper
Same mods as the one above.
Hp : 103,5 at the wheels
Reply 0
Feb 1, 2008 | 04:02 AM
Mini Cooper
Stock
HP : 111,1 (flywheel)
Reply 0
Feb 1, 2008 | 04:12 AM
Reply 0
Feb 1, 2008 | 04:14 AM
Reply 0
Feb 1, 2008 | 04:15 AM
Reply 0
Feb 1, 2008 | 04:37 AM
Mini One
Stock : 97 hp
Modded : 144 hp (flywheel)
Software
Intake (modified BMC CDA)
exhaust
cat.
polished heads
cams
gasoline cooling
iridium spark plugs
Again, not the number of mods that are required to get that amount of power.
This package does not come cheap.
A modded One is at the same level as a modded Cooper.
So a Cooper with the same mods, wil produce the same power as this One.
The reason why a One gains so much power, is because it's a detuned version of the Cooper.
Part of that detuning is the software that restricts the engine power.
So with a software upgrade a One can gain a lot of that restricted power back and on top of that the same amount of power that you gain with a Cooper.
Power (flywheel)
Torque
His modifications:
Software, carbon intake (modified), cat., cams, gasoline cooling, exhaust, polished cilinder heads.
Here are some pics of his setup:
Link to the article (in Dutch) : http://www.r53.nl/one_kelleners/index.php
Reply 0
Feb 1, 2008 | 05:29 AM
Mini Cooper
MTH software
Pipercross open Intake
HP : 116 (flywheel)
Reply 0
Feb 1, 2008 | 06:21 AM
Mini Cooper
BMP/ProMini intake
Kingsbourne 9mm spark plug wires
Milltek header + Milltek cat.
Magnaflow cat-back exhaust
Beru Ultra-X spark plugs
MTH software
Pilo Screamin’ Demon ignition coil
HP at wheels : 108 with 94 octane and 111 with 100 octane
Extra info : dyno runs were done with the hood open (= higher numbers) !
94 octane dyno run
100 octane dyno run
Reply 0
Feb 1, 2008 | 09:47 AM
Awesome collection of dyno sheets. It's seems that the the euro specific brnads have a bit more impact than the american.
Reply 0
Feb 1, 2008 | 10:55 AM
You can almost predict where yours might be from the variation of samples here.
I tried to emulate the original JCW tuning kit which MINI stated was 126 HP on my '06.
So with
JCW Intake
JCW Head
JCW Exhaust
JCW Software
I'd be happy to be around ~125. If I win a free pull from the local MINI club it would be nice to hook it up.
Anyone know if the midlands vs getrag make a difference on drivetrain loss?
Reply 0
