Cooper (non S) Modifications specific to the MINI Cooper (R50).
not windshield wiper fluid
Old Jan 13, 2008 | 07:08 PM
iinokturnolii's Avatar
iinokturnolii
i know i know i need to search. but i didnt know what to search for... and plus it says check out the manual. i dont have one.... anyways... whats that tank by the windshield under the hood where theres a picture "not windshield wiper" what fluid id that? it seems to be low in my car...
Old Jan 13, 2008 | 07:45 PM
UKSUV's Avatar
UKSUV
Coolant? What does the resevoir look like?
Old Jan 14, 2008 | 10:43 AM
Ancient Mariner's Avatar
Ancient Mariner
What year? Where is it located under the hood? Center? Right side? Left side? Need info, please.
Old Jan 14, 2008 | 11:03 AM
Dr. Pepper's Avatar
Dr. Pepper
It's probably the coolant resevoir.
mine has that symbol on it.
Old Jan 14, 2008 | 04:02 PM
iinokturnolii
oppps... its in the center. its a 2004 MC.
Old Jan 14, 2008 | 04:23 PM
xnotfunkylex's Avatar
xnotfunkylex
What color is the fluid in it? If it's coolant it should be a deep blue. And that 's what it sounds like to be. Coolant that is.
Old Jan 14, 2008 | 04:30 PM
xnotfunkylex
Just did a quick photo reference.
If it is the tank in the red circle then it is coolant just to clear that up. I can't remember wat the black one is though.
Old Jan 14, 2008 | 04:56 PM
hemiheaded18's Avatar
hemiheaded18
The balck one I believe is power steering fluid.
Old Jan 14, 2008 | 08:12 PM
iinokturnolii
i beleive its this one... but i will take picture tommorow... thanks guys for the info!
Old Jan 15, 2008 | 05:17 PM
iinokturnolii
the liquid inside is pink. its really low i need to top it off soon... THANKS!
Old Jan 16, 2008 | 08:16 AM
lotsie's Avatar
lotsie
The coolant level will drop in the tank if the outside temp. drops overnight, then return to normal after the engine has warmed up. Best to check the level when the engine is warm. If do need to top it up, get the same coolant, don't mix brands, best to get a gallon of it from a dealer, and mix with water as per the directions. It will likely last you many years.
Mark
Old Jan 21, 2008 | 09:42 AM
Louispup's Avatar
Louispup
Be careful with the cap. While filling the coolant a week or so ago, the cap dropped down and was a royal pain to extract. I was running late, it was really cold, and the neighbors heard obscenities. Finally I used chopsticks to grab the rim and that worked pretty good.
Old Jan 21, 2008 | 12:13 PM
xnotfunkylex
Mine doesn't have that sticker, and my cap has a hinge on it. Also, did they the type of coolant recently, because I use blue stuff from BMW?
Old Jan 22, 2008 | 11:26 PM
rjtrout2000's Avatar
rjtrout2000
I wouldn't fill that thing up unless you have seen some issues with your cooling while driving and idling. It;s just the overflow tank and the radiator should have more than enough capacity.
Old Jan 29, 2008 | 10:13 PM
iinokturnolii
thanks for the info everyone!!!
PsychoRallye
21
Feb 17, 2019 06:08 AM
bahman
Feb 14, 2016 10:29 AM
Scm68
Jan 27, 2016 12:33 PM
vulkandino
Oct 31, 2015 08:29 PM
Samhillrocks
Sep 29, 2015 12:55 PM
