Cooper (non S) Modifications specific to the MINI Cooper (R56).
H13 Bulbs. (NON-HID)
Old Dec 26, 2007 | 07:10 PM
mini922's Avatar
mini922
Hi everyone.. did anyone had change their H13 bulb to 43k color bulbs? I find that the regular stock headlight is very dim... can anyone tell me some good brand? thank you ...
Old Dec 27, 2007 | 06:24 PM
Joey D's Avatar
Joey D
From my experiences with past vehicles Silverstar bulbs tend to be the best non-HID bulbs I have found.
Old Dec 28, 2007 | 09:04 AM
mini922's Avatar
mini922
Thank You very much for your information...
Old Dec 30, 2007 | 12:25 PM
lacning74's Avatar
lacning74
As recommended by Daniel Stern Lighting below, I got a pair of Philips VisionPlus H13 bulbs. Highly recommended and affordable mod ($40). Also, many people including me have been adjusting the headlights to aim higher. If you haven't already, check this thread.
> I want to replace my stock halogen lights on my 2007 Mini Cooper. The
> manual mentions type H13 60/55 W. I have read in newsgroups about
> people replacing their Mini Coopers with Sylvania Silverstars. What do
> you recommend?
Sylvania Silverstar is a scam.
Here's manufacturer data, from internal engineering databases, for output
and lifespan at 13.2v for H1 bulbs. The numbers here are a composite of
values applicable to the products of the big three makers (Osram-Sylvania,
Philips-Narva, Tungsram-GE). Each manufacturer's product in each category
is slightly different but not significantly so. I picked H1-type bulbs
for this comparison, and while the absolute numbers differ with different
bulb types (such as H13), the relative comparison patterns hold good for
whatever bulb type you consider. Lifespan is given as Tc, the hour figure
at which 63.2 percent of the bulbs have failed.
H1 (regular normal):
1550 lumens, 650 hours
Long Life (or "HalogenPlus+")
1460 lumens, 1200 hours
Plus-30 High Efficacy (Osram Super, Sylvania Xtravision, Narva Rangepower,
Candlepower Bright Light, Tungsram High Output, Philips Premium):
1700 lumens, 350 hours
Plus-50 Ultra High Efficacy (Philips VisionPlus, Osram Silverstar, Narva
Rangepower+50, Tungsram Megalicht, but not Sylvania Silverstar):
1750 lumens, 350 hours
Blue coated 'extra white' (Osram CoolBlue, Narva Rangepower Blue, Philips
BlueVision or CrystalVision, Tungsram Super Blue or EuroBlue, Sylvania
Silverstar or Silverstar Ultra, which is just a rebrand of the
Silverstar product, also PIAA, Hoen, Nokya, Polarg, etc):
1380 lumens, 250 hours
Now, looking over these results, which one would you rather:
(a) Buy and drive with?
(b) Sell?
The answer to (a) depends on how well you want to see versus how often to
change the bulb. If you want the best possible seeing, you pick the
Plus-50. If you don't care as long as it works and you don't want to
hassle with it, you pick the long life.
The answer to (b) is determined by how rich your company's shareholders
want you to be, and is obvious: You want to sell the bulb with the
shortest lifespan, highest promotability and highest price. That'd be the
blue unit, e.g. Sylvania Silverstar.
Go get a pair of Philips VisionPlus H13 bulbs, if that is what your MINI
takes:
http://aid-auto.stores.yahoo.net/phviplrebu90.html
Old Jan 11, 2008 | 09:43 AM
Charlie Croker's Avatar
Charlie Croker
Any step by step on replacing the bulbs? I'm sure I can figure it out on my own, but would like any heads up that I might need. Thanks in advance!
Old Feb 13, 2008 | 10:01 AM
Arnbut's Avatar
Arnbut
I have 4 Osram Silverstars (the plus 50 retina burners) on my motorcycle; they are really bright.
The Phillips Visionplus are a good product when you can find them.
http://www.suvlights.com/product_inf...products_id=99
Old Feb 15, 2008 | 08:55 AM
Laser-Red's Avatar
Laser-Red
Very Easy!
Check the owners manual page 104 for 2007 model.
Old Dec 15, 2009 | 12:28 AM
stevenfelix's Avatar
stevenfelix
this thread has been quiet for a while, but here's where you can order Phillips X-TREME POWER Halogen Bulbs.
www.bulbs.com
search h13 and they should come up... good price $18.49 ea (2 per pack).
Old Dec 15, 2009 | 12:01 PM
drewstermalloy's Avatar
drewstermalloy
Silverstars aren't bad, I've had them in for about 6 months now. $40 for the pack, and a little brighter and better looking than stock.
Old Dec 16, 2009 | 06:52 AM
slindo's Avatar
slindo
Another thing to remember when buying bulbs or lighting systems is that each kind of bulb - halogen, HID etc - tends to produce light at a certain color temperature. 2500 to 3500 for halogen, roughly, and maybe 3500 to 4200 for HID. To get light from a bulb of a higher color temperature than it normally produces means filtering the output - usually, by tinting the bulb. This reduces the output of usable light! So the high color temperature bulbs can always be counted on to put out LESS usable light than the lower CT ones. So decide what you are shopping for - trick looks, or better light - and, if its the latter, then go for non-blue, non-tinted bulbs.
Old Dec 22, 2009 | 03:41 PM
tmo8462's Avatar
tmo8462
Just picked up the Phillips Bright white H13's and they work great!
Old Jan 12, 2010 | 08:57 PM
rkiller691's Avatar
rkiller691
My last pair of Headlight bulbs were GP Thunder 8500K
now I have 6000K HID kit
(If u want the H13 GP thunder 8500K bulbs PM me)
remember this only fits mini coopers wit a halogn bulb
Old Jan 21, 2010 | 09:54 AM
stevenfelix
I picked up the Philips X-TREME POWER H13 Halogens and I must say that I'm not very impressed by them; maybe I was expecting too much. They run the same color as stock bulbs and don't seem to give me the quoted "80% more light." Looking into Nokya Cosmic White Stage 1s, it's 5000k crisp white, but idk how bright they'll be cos of the higher bulb temp. Does anyone have any recommendations before I run out and blow another $40 on crappy bulbs? I'm looking to get something bright and aggressive, but not rice blue, pref 5000k - 6000k halogen. Bulb spec is H13 60/55w halogen. Any words of wisdom are appreciated!
Old Jan 21, 2010 | 10:38 AM
rkiller691's Avatar
rkiller691
Well stevenfelix,
you can always jus buy yourself an HID kit....
I got mine installed.. And may I say... The look amazing.. Also bright..
If u would like.. I can PM you pics of my HID kit
Old Jan 21, 2010 | 12:36 PM
Paleo's Avatar
Paleo
stevenfelix - I really like the PIAA Extreme white bulbs. Have them for my High/Low, fogs and driving lights. Very crisp white illumination. They are a little pricey and may not last as long as others, but I have been very satisfied with the color temp and brightness so I will keep using them.
Old Apr 15, 2013 | 12:47 PM
SpeedRacer0212's Avatar
SpeedRacer0212
I know this is an old thread, but everyone keeps talking about the PIAA H13 Extremes, but no one mentions their wattage draw. Stock bulbs are 60w/55w. The PIAA Ext Whites are 65w/55w. Since they are a 5 watt increase did you have any issues with melting of the harness or melting inside the housing? I want to get these today, but I feel that they will do damage. Would like yo hear your take.
Oct 1, 2015 12:13 PM
Sep 30, 2015 11:39 AM
Sep 30, 2015 11:38 AM
Sep 30, 2015 11:25 AM
Sep 29, 2015 12:11 PM
