Cooper (non S) Modifications specific to the MINI Cooper (R50).
MCS Intake manifold on a MC???
Old Dec 19, 2007 | 12:55 PM
kenros's Avatar
kenros
I want to know if the MCS intake manifold fits in the MC head, I know that the threads are not the same but I just need to know if all the bolts matches in the holes of both intake manifolds. Thanks for any help
Old Dec 20, 2007 | 11:10 AM
IanF's Avatar
IanF
Might be able to find out...
...but why?
Old Dec 20, 2007 | 11:27 AM
Beecher's Avatar
Beecher
umm, its the same head, why wouldnt the threads be the same? There are people who have put s heads on coopers on here before, so yeah, the intake would fit. i also must ask, why? unless your going turbo, then it makes some sense.
Beecher
Old Dec 21, 2007 | 04:31 AM
kenros's Avatar
kenros
Beecher
That's the idea, going TURBO!!!!!!!!!!!
Old Dec 21, 2007 | 09:25 AM
Beecher's Avatar
Beecher
well, yup, it fits, have fun with all that power
Old Dec 21, 2007 | 09:29 AM
justintime's Avatar
justintime
justin thinks it would be better to put a custom intake mani on for a turbo...
Old Dec 22, 2007 | 08:27 AM
kenros's Avatar
kenros
That's right but we are making some test first to determine what parts to use
Old Dec 22, 2007 | 08:35 AM
Drewmon's Avatar
Drewmon
+1
Old Dec 26, 2007 | 04:37 PM
kenros's Avatar
kenros
Well, I know that the MCS intake manifold is connected to the IC and that the MCS throttle body is connected to a plastic hose that goes to the supercharger. On the MC the throttle body is directly connected to the intake manifold, I want to install the MCS intake manifold and TB into my MC, does any one has done this before?? I know that I will need to make some flange to put the MCS intake manifold and TB together, I will appreciate your comments and if you have any closer pics of the MCS IM and how close it is to the head. thanks
Old Dec 26, 2007 | 04:41 PM
Dr Obnxs's Avatar
Dr Obnxs
I don't think you want to do it...
the runners on the MCS intake manifold were designed for packaging, not power. They are too short for the RPM range that the engine makes power. Sure you can do it if you want to, and it will be cheaper than going custom. Give Jan a call at RMW and ask about his intake design for his turbo only car. Ask him how he chose the length runner he's using and compare how long the runners are compared to the intake on the S. But the boost will cure many ills, so for a lower cost mod package it will work.
Matt
Old Dec 26, 2007 | 06:10 PM
kenros's Avatar
kenros
Matt
Does he have a website??
Old Dec 26, 2007 | 06:53 PM
Dr Obnxs's Avatar
Dr Obnxs
Yep...
he's a vendor here. Revolution Mini Works.. Check the vendor lists...
Matt
Old Dec 26, 2007 | 09:47 PM
justintime's Avatar
justintime
out of curiosity.. arnt the runners different lengths between the car? wouldnt you need to tune accordingly? The stock ecu wouldnt be able to cope right would it?
then again.. you would need a tune anyway with your turbo :p
Old Dec 26, 2007 | 11:34 PM
Dr Obnxs's Avatar
Dr Obnxs
Runner length should be determined by peak HP RPM
diameter by flow requirements. Think of the runners as pipe organ pipes. You want the pitch to match the engine pitch, to abuse concepts.
To get max out of the car, custom tune all the way!
Matt
Old Apr 14, 2008 | 07:47 AM
ItaMamuel's Avatar
ItaMamuel
Hi .. i have kind of a problem to.. i have sucessufly installed the cooper S throttle body on the cooper air intake pipe.. but the cooper air intake pipe is to narrow... so i tried de Cooper S.. but it doesn't fit(i dont remember why but i tried and i was not sucessful).
Is there anynone that sells a larger intake pipe (from throttle body to the head)???
I want to enlarge my cooper s throttle body but without having a larger pipe it wont make any difference!!
Best regards
Old Apr 14, 2008 | 09:25 AM
Dr Obnxs's Avatar
Dr Obnxs
It's a bit off topic...
but who cares! Anyway, the Cooper S TB is 58mm and the Cooper is 56mm I think. I'm not sure that you will see much difference, as I don't think the TB is the bottleneck on the car. I think M7 was selling an opened up TB for the cooper, but I may be wrong there.
What has lead you to do this? Just tinkering, or do you have data showing that you would anticipate a benefit?
Thanks,
Matt
Old Apr 14, 2008 | 09:35 AM
ItaMamuel's Avatar
ItaMamuel
Its 52mm vs 58mm... so if i had a larger air intake "pipe"(combined with the cooper S throttle body) i can have a better airflow...
You do not see MUCH difference maybe 1 or 2hp.. but when you have a cooper every litle thing makes a diference...
I dont have the possibility to have a 271 mustang
Yes M7 had one.. but a cooper S one(already tested) can help to add an extra hp or 2...
and the throttle body isnt directly attached to the head.. it has a plastic intake .. and that's what i one(a bigger intake pipe)....
MasterShaftner
Sep 1, 2017 07:23 PM
bobbiemartin
Jan 20, 2016 05:28 PM
HaveATank
Sep 4, 2015 08:04 AM
Inziladun
Sep 3, 2015 10:35 AM
Indimanic
Aug 19, 2015 11:08 AM
