Cooper (non S) Modifications specific to the MINI Cooper (R50).
mod the stock intake
Old Oct 23, 2007 | 05:49 PM
blue_bomber's Avatar
blue_bomber
anyone ever modify the stock intake?
on other cars iv seen new and/or bigger pipping ran for both the inlet and to the manifold. not thinking there would be a HP gain, but maybe open up a nice sound.
any thoughts?
Old Oct 24, 2007 | 06:47 AM
Speedwing's Avatar
Speedwing
Just adding a K&N drop in filter to the stock air box / intake is a very noticable improvement in both response and sound.
Old Oct 24, 2007 | 07:47 AM
Dr. Pepper's Avatar
Dr. Pepper
I got an extra 2mpg from my drop-in foam filter. The sound stayed pretty much the same.
Old Oct 24, 2007 | 07:54 AM
lotsie's Avatar
lotsie
I found the same thing when I had a K&N filter in mine. Now that I have a WAY/DDM intake both throttle response ans the sound are MUCH better.
Mark
Old Oct 24, 2007 | 02:52 PM
blue_bomber
i already have a alta drop in. and honestly think all the CAI's out are a waist without running the air through an intercooler. not sure why noone has made a real one that sits low in the front air dam that will truly get all the cold air it can handle. guess i might tinker with it sometime soon and see if i can free anything up a bit.
Old Oct 25, 2007 | 10:42 AM
Dr. Pepper's Avatar
Dr. Pepper
Many moons ago a I read a thread on NAM about how the Honda guys modify their stock intakes for better performance and still keep it legal for autox. Something about turning the top portion upside down, exposing the filter to the open air. The poster had done it to his Mini and said it worked great and sounded great. Do a search, you might find it.
Old Oct 26, 2007 | 08:47 AM
Carve906's Avatar
Carve906
K&N or Alta?
I see a lot of posts here for the K&N drop in filter. I've been thinking about adding this to my cooper and have been trying to decide between the K&N and the Alta foam one.
Any opinions?
Old Oct 26, 2007 | 02:07 PM
blue_bomber
yea, the cotton vs foam has been discussed a few times...
on the first page of posts- https://www.northamericanmotoring.co...d.php?t=114999
its personal opinion in the end, eveyone has their own reason for their choice.
you can flip a coin? paper rock sissors? or just try one because they both work well.
i see your in englewood, are you new to the mini scene?
Old Oct 27, 2007 | 07:02 AM
Carve906's Avatar
Carve906
Well...New to FINALLY owning one! Waited a LONG time to get here
I plan on attending MOTD this year, and hopfully swinging by some local club events in the coming months.
Old Oct 27, 2007 | 09:57 AM
blue_bomber
there is a local dayton mini club that im also new to. if you want the details i can pm you with some info on meets.
Old Oct 27, 2007 | 07:17 PM
AutoXCooper.com's Avatar
AutoXCooper.com
I have the K&N typhoon and love it, buddy has the WMW link below and it rocks too. I'm going to build a box around my K&N this winter for next years season-o-cones.
http://www.waymotorworks.com/MINI/MI...3/Default.aspx
Old Oct 30, 2007 | 06:54 PM
115hp's Avatar
115hp
I remember reading about how someone punched a bunch of holes into the bottom of the airbox--like swiss cheese. And someone else made an opening for a hose in the back and ran it to the air vent near the windshield wiper. (Isn't that like the Soundkit?)
Old Oct 30, 2007 | 07:08 PM
101101's Avatar
101101
I can't see the point in an intercooler on a n/a setup - I doubt the incoming air would be hot enough to have any drop in temperature, then after adding in the extra weight of the piping / intercooler, even if you do see a couple deg. temp drop I doubt it would increase the power enough to offset the added power. Plus that's a lot of money for (very, very) little (potential) power.
Also, the point of a cold air intake is to take in cold air (hence the name). The best an intercooler could do is drop the intake air temp to the temp of the air around the car which with a properly designed CAI would not be that much different from what the CAI is pulling in.
Old Oct 30, 2007 | 07:28 PM
blue_bomber
intercooler? not for us, i was stating in reference to the "S" models. they can get air where ever theyed like because it will be cooled.
this is a hot air intake-
this would be a true cold air setup-
puts the filter low and in the front grille for air outside the engine bay.
Old Oct 30, 2007 | 07:47 PM
101101's Avatar
101101
Ah, I was a little confused with this being in the non-s forum.
Old Oct 31, 2007 | 07:41 AM
FL_blue_MINI's Avatar
FL_blue_MINI
I'm not sure i completely understand the idea of doing more then a drop-in on our cars. The air is pulled straight from the grill. I have an intake temperature about 5-8 degrees warmer then outside air.
Old Oct 31, 2007 | 11:29 AM
rjtrout2000's Avatar
rjtrout2000
Attachment 26299
I'm in agreement here. The only reason I can think of is the open air element might just simply flow more air than a drop-in performance filter. IDK, I am happy with my ITG filter. Best 60 dollars I have spent on my car. (minus the rear sway and springs of course)
Old Oct 31, 2007 | 02:40 PM
blue_bomber
i think there would be nearly nothing to gain except the great sound. pretty sure i read here on the forums that someone had conducted a simple test and saw the most improvments with just a drop in.
Old Nov 1, 2007 | 05:49 AM
ProfessorDave's Avatar
ProfessorDave
My worry about dropping the filter or intake down lower (as in the cold air setup pictured in blue bomber's post) is that it could increase the risk of hydrolock in heavy rain/deep puddles.
Old Nov 1, 2007 | 09:15 AM
R50 Paul's Avatar
R50 Paul
I usally swap between my Moss Intake and my stock box with a K&N. The Moss is for summer, and the K&N for winter. During the summer months, my Cooper is much less bogged down with the Moss intake and the a/c on.
Old Nov 1, 2007 | 11:29 AM
FL_blue_MINI
To make the stock box a little louder couldn't we just remove the resonator?
Part 15
has any one tried that?
Old Nov 1, 2007 | 11:34 AM
R50 Paul's Avatar
R50 Paul
I've been wanting to give that a try.....
Old Nov 1, 2007 | 02:17 PM
115hp's Avatar
115hp
Whoever has the MiniMania airbox/filter has had to remove the resonator. Supposedly, it can be quite difficult to remove.
Old Nov 1, 2007 | 03:31 PM
cristo's Avatar
cristo
Alliance Member
I have one. It did take some serious tugging to pull out the resonator.
Old Nov 1, 2007 | 04:00 PM
R50 Paul's Avatar
R50 Paul
How did you go about removing it? Is there a differance in sound/ performance??
