Question On My 78 Mini
Old Jan 2, 2007 | 09:36 AM
gabemin's Avatar
gabemin
Just Bought A 1978 Austim Leyland Mini...love The Car...but There Was So Many Modifications On This Mini I Dont What Is What........
I Have A Little Nobe To The Left Of The Steerring Wheel...that Say's Lock And You Can Pull It Out And Stuf..i Dont Know What That Is For One...2 When The Car Starts It Sgives Full Throttle All The Way And I Have To Turn It Off... 3rd Of All I Can Give Gas With A Turn To The Key...like When I Turn It On I Can Actualy Give More Throttle With Just Turning The Key More...is This Normal...oh Yea And Another Question...i Dont Know If I Put The Spark Plug Wires Int He Right Place And Order....
Old Jan 2, 2007 | 01:04 PM
Minimad's Avatar
Minimad
firing order 1-3-4-2 with #1 at the radiator end of the motor...
can't make sense out of the rest of your issues??? need pics or better explanation.
check to make sure your car is a 1978 in order to get correct advice from us see:
http://www.minimania.com/matrix/
for instructions on how to ID your car.
Old Jan 2, 2007 | 01:39 PM
MaxN's Avatar
MaxN
Reverse Gear
I think that the **** is the CHOKE.
It richens up the mixture (understatement) and allows you to start it when cold
Old Jan 2, 2007 | 01:50 PM
camelpilot's Avatar
camelpilot
hahahahahhha.... never seen a choke cable!!! ROFL, that is tooooo funny.
Old Jan 2, 2007 | 02:26 PM
Cassy's Avatar
Cassy
the **** is definitely the choke cable.
the rest of your post is a little hard to follow, could you be a bit more descriptive?
Old Jan 2, 2007 | 03:54 PM
shorn's Avatar
shorn
When starting from cold (engine is cold, not necessarily the air temp), this is how things SHOULD work, at least they do with mine. Pull the choke out all the way and turn it to lock it out. Turn the ignition key to start the car, but you shouldn't need to put your foot on the gas. Once its started (normally immediately), it should idle at 1500 rpm or so. As it warms up, you can release the choke, maybe in several steps, until the choke is off (**** is in). At that point the engine should be idling at about 750-800 rpm. Then she should go, by giving it gas with the pedal. That's how it SHOULD work; can't tell from your email how you're applying gas
Old Jan 3, 2007 | 04:34 AM
Capt_bj's Avatar
Capt_bj
You may want to invest in ....
You may want to invest in the Heritage CD that has the owners manual and factory tech manuals. I picked one up and it is a great supplement to th Haynes. (I assume that like me, your owner's manual went bye bye a long time ago....)
For example it mentions that 'full choke' should only be needed under the coldest/extreme conditions, and the first 1/3 of the choke pull engages 'fast idle'. There's a story of one guy who on breaking his throttle cable was able to drive home using the fast idle feature.... Fast idle is the same as presssing the gas down a little so as noted you probably don't need to press additional throttle when starting....
So far as starting 'immediately', in my experience if the car has been driven in the last 2 ~ 3 days, yes it normally starts fast...real fast But if has been a week or more, I need to crank a bit to get fuel all the way back up to the carb. My mechanical pump doesn't seem to keep the system pressurized more than a couple of days. When outside temps are over about 85 - all I need is a little pull for fast idle and it kicks right over.... below that, seldom more than 1/2. (1275, HIF6, K&N, LCB) {To those who now say 'too rich' my plug conditions don't indicate that. I simply think that when the block is warm to the touch...it isn't "cold" as is implied in the owner's manual. But true, I have not had it connect to a gas ****'.}
The CD is pretty readily available from any Mini parts supplier like MiniMania or Triple-C
http://www.minimania.com/web/Item/HM.../InvDetail.cfm
Old Jan 3, 2007 | 06:46 AM
gabemin's Avatar
gabemin
Okay I Got The Choke Thing Down...but When It Turns On...it Gives Full Throttle With Out Me Giving It Gas.......i Mean Full Throttle..like Its About To Blow Up....so I Have To Turn It Off Quick..................second When I Turn It On..."a Turn Of The Key Gives It Throttle" Like If I Keep Turning It , It Gives More Gas So I Go Back And Forthbut If I Leave It All The Way Turned It Gives Full Throttle And I Have To Turn It Off Quick.....3rd My Gas Pedal Isnt Hooked On...there's A Wire That Runs Through It And There's Nothing To Tighing The Gas Petal To The Wire So That I Can Give Gas ....
Thanks For All The Replies Guys....
Old Jan 3, 2007 | 08:42 AM
gabemin's Avatar
gabemin
I Bought My Car From Turky Burky....i Bought The Smashed One...he Had On Ebay....car Was Good..no Rust...minor Rust..engine Looks Good.......interior Is Great...tires New..just Body Thats All..and Its Almost Complete....im Molding The Bodykit I Bought From Heritage...
Old Jan 3, 2007 | 10:17 AM
shorn's Avatar
shorn
The gas pedal "wire" does not actually fasten to the pedal arm linkage. The other end of the cable should be attached to the carb, with a stout spring keeping the throttle closed/off/idle, and the pedal in its unpushed position. Get under the bonnet and trace the cable to the carb - it may be disconnected.
Alkaidovich
Jan 30, 2021 01:35 AM
andrewjg1994
Jan 29, 2021 07:45 PM
Terry J
Aug 11, 2015 09:39 AM
nomar116
Aug 10, 2015 11:24 PM
jrezzo
Aug 9, 2015 10:32 PM
