want rallye lights, but no bumper.
Old Aug 18, 2005 | 08:35 AM
STLMINI's Avatar
STLMINI
i keep seeing these minis with great rallye lights on the front and my poor mini doesn't have a bumper to attach them too. other than re-bumpering, does anyone have any suggestions on how to do it?
signed,
lightless-in-st.louie
Old Aug 18, 2005 | 08:41 AM
Tall Mini's Avatar
Tall Mini
MiniMania (and others) have grills with space for two rally lights built in. Great clean look IMHO
Old Aug 18, 2005 | 08:53 AM
mini doc's Avatar
mini doc
My lights attach through the grill to the underside of the bonnett. They don't touch the bumper!
Tim
Old Aug 18, 2005 | 11:32 AM
Minimad's Avatar
Minimad
Rallye lamp bars attach to the sheet metal under/in front of the grille not the bumper...check them out
Old Aug 18, 2005 | 11:57 AM
John Smith's Avatar
John Smith
That is a NICE Mini. The lights are incredible!!!
Old Aug 18, 2005 | 12:36 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
That's one way to stop your distributor getting wet every time you drive through a puddle.
Great looking brick! Can anyone tell me where I can get covers like your headlight covers (wire mesh) for MINI factory rally lights?
Old Aug 18, 2005 | 10:36 PM
Minimad's Avatar
Minimad
You need to search some of the UK sites. Those are 7" but I think I've seen them also in 6". Search for Driving/fog lamps & accessories. Even try eBay UK. My lamps are 50's-60's Lucas SLR/SFT700's but they made them in 6" called SLR/SFT 576's. I think I saw a Healey or Jag site that had 6" mesh on a stand that mounted under your lamp, but I don't recollect where....
Old Aug 18, 2005 | 10:40 PM
seeya's Avatar
seeya
wire mesh
You might try Moss Motors, they sell them for MGB's you may get lucky
Old Aug 19, 2005 | 06:43 AM
Rick-Anderson's Avatar
Rick-Anderson
http://www.minispares-online.co.uk/
Look under chrome. If you don't have a bumper I am assuming that it has been shaved off, along with the sheet metal lip. If this is the case, you will probably have to use grille mounted lights because most lights and light bars mount to the sheet metal under the bumper. A few options include buying the brackets that Huddersfield Spares has on the above website or using boot spotlights, which have a big mounting bolt that sticks out the back rather than a bracket on the bottom. This makes it easy to mount to the grille - just use a big fender washer on each side and push the bolt through the grille.
Old Aug 19, 2005 | 08:50 PM
Minimad's Avatar
Minimad
The lamp bar on my Mini only has 1 bracket (center) which attaches to the bumper mounting flange. This support could easily be modified to fit in another manner. The end brackets attach to the front grill surround on top of the curve below the turn lamps. (see photo). Additional support brackets can be run from the ends and center back under the grill to steady the bracket. The two other Minis with the same setup I saw @ MME had such additional brackets.
Old Aug 19, 2005 | 10:05 PM
Rick-Anderson
I just found the magazine ad I have been looking for. There is a company in England that makes the front light bars similar to those on the cars of the original Italian Job. Unfortunately, they don't have a Website but they are called T.T Lyle Metal Designs. Their phone number is 01328864902 If you have a copy of the January 2005 issue of Mini Magazine (or if somebody can scan and post it), the ad is on the bottom of page 138.
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
