center gauge pod installation
Old Feb 6, 2005 | 03:29 PM
STLMINI's Avatar
STLMINI
next question...
i've got a center speedo mounted in the center of my dash. i want to add the center gauge pod as it was originally in the Mk II...
do i need to remove the entire single speedo gauage pod to install the new three gauge pod?
here's a pic of what i'm currently running...
Old Feb 7, 2005 | 12:52 PM
8ball's Avatar
8ball
The Mk.II version you show in you pic requires that you do indeed remove the original Speedo "pod" and remount the speedometer in the new, larger pod.
The original Mk.I version had a stamped metal plate that the aux. guages mounted into and fit over the front of the speedo pod; the mounting plate assembly was then covered with a "surround" housing - more pieces (and more cost) than the Mk.II version, but easier to work with.
Old Feb 7, 2005 | 01:13 PM
STLMINI's Avatar
STLMINI
thanks again 8ball! i was going to try to take it off but wanted to make sure before i started 'ripping' stuff out that doesn't need to be taken out!
Old Feb 8, 2005 | 12:10 PM
CasaMini's Avatar
CasaMini
STLMINI,
If and when you replace your pod to the 3 gauge pod, I'd be interested in buying your old pod from you. That's the exact pod I need for my Mini.
You can email me at CasaMini@comcast.net or angelruiz@scsfrigette.com
Old Feb 8, 2005 | 02:54 PM
STLMINI's Avatar
STLMINI
will do. i will probably be a couple weeks before i get to it.
Old Feb 8, 2005 | 06:02 PM
CasaMini's Avatar
CasaMini
I Want Your Pod
Let me know if you need the water & oil gauges. Maybe we can work a deal.
CasaMini
Old Feb 22, 2005 | 03:43 PM
STLMINI's Avatar
STLMINI
casa, the pod is available. here's a picture. im not sure what it should go for. make a fair offer and it's yours.
mike
Old Feb 22, 2005 | 04:10 PM
CasaMini's Avatar
CasaMini
Pod
How about $20.00 plus another $5.00 to cover shipping?
If OK. send me your address and I'll get a money order right to you.
You can send your info to CasaMini@comcast.net
My info:
Angel L. Ruiz
2601 Meadow Creek
Bedford, TX. 76021
Old Feb 22, 2005 | 04:42 PM
STLMINI's Avatar
STLMINI
sold. replied via PM.
Old Feb 22, 2005 | 06:09 PM
CasaMini's Avatar
CasaMini
Pod
Got your message. I'll get the MO out to you by noon tomorrow.
Thanks,
CasaMini
Old Feb 23, 2005 | 01:09 PM
CasaMini's Avatar
CasaMini
Pod
I actually took care of it last night. The MO is in the mail.
Thanks,
CasaMini
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
