Keep on eye on the Rod Change shift rubber mounts!
Old Sep 19, 2016 | 04:58 PM
MiniMoMir's Avatar
MiniMoMir
While driving recently, my shifter started flopping all over the place. As it turned out one of the Rod Change shift rubber mounts totally came apart, and the other was on its way. The only thing keeping the shifter in place was the exhaust system, which was holding it up. Here's what it was looking like:
Fortunately overnight shipping and a little bit of squeezing over and under got it back on the road again. Till the next time....
Old Sep 22, 2016 | 02:38 PM
Mini Mania's Avatar
Shift Rubber
Wow, thanks for sharing, great pix!
http://www.minimania.com/Search_Results/shift/Parts
Old Sep 25, 2016 | 02:13 PM
mk1leg's Avatar
mk1leg
get some polly ones
Old Sep 25, 2016 | 03:58 PM
MINIdave's Avatar
MINIdave
Do you have a link to the poly bobbins?
Old Sep 28, 2016 | 02:58 PM
mk1leg's Avatar
mk1leg
Sorry these are the only type
http://www.minispares.com/product/Cl...ck%20to%20shop
I thought they were poly
Old Sep 28, 2016 | 03:22 PM
Capt_bj's Avatar
Capt_bj
keep an eye on the metal around the mount points would seem to be the greater concern!!!!
Old Sep 28, 2016 | 05:11 PM
MINIdave's Avatar
MINIdave
It would probably transmit a bit of NVH, but you could use an appropriate length bolt and poly bushing to replace these......
Old Sep 29, 2016 | 02:55 PM
mk1leg's Avatar
mk1leg
yes thats not the original hole it been cut out wrong hole is too far back what year is your mini
CptSlow
Sep 27, 2016 07:36 AM
Oly
Aug 31, 2016 10:31 AM
SneedSpeed
Aug 31, 2016 07:13 AM
Jetmoe
R55 :: Clubman Talk (2008+)
Aug 30, 2016 05:44 PM
SneedSpeed
Aug 25, 2016 06:51 AM
