Recommended gas rating for Austin Cooper
Old Nov 7, 2007 | 06:10 PM
richi0207's Avatar
richi0207
Does anyone recommend a certain octane rating gas for the classic minis? It's for a 1974 Austin Cooper with original 1275cc engine if that helps. Thanks alot. ^_^
Old Nov 7, 2007 | 09:47 PM
MINIxB's Avatar
MINIxB
I put regular unleaded in mine. You might have to use a lead additive in the gas on your engine. I haven't had any problems with mine without it though. You can buy the lead additive at parts stores. I've found it at advance auto parts.
Old Nov 7, 2007 | 10:18 PM
MiniManiac74's Avatar
MiniManiac74
93 Octane. Anything lower will make my engine cough when I shut it off. No lead.
Old Nov 8, 2007 | 04:21 AM
2phun's Avatar
2phun
The previous owner of my pickup used 98 octane plus a booster, but it was pretty heavily hopped up. I used the highest octane I could find with an octane boost and it ran fine.
Old Nov 8, 2007 | 04:49 AM
Capt_bj's Avatar
Capt_bj
High Octane
I tried mid grade in mine once....kick, spit, sputter, backfire
never tried that again
{1275 Metro, HIF-6 with K&N, LCB, PlayMini twin DTM}
heed the advice here about leaded gas.. from Haynes:
"Models built up to October 1988 (as delivered from the factory) cannot use unleaded petrol; the valve seats fitted as standard will suffer serious premature wear...."
You want to verify that the head has been modified or swapped.
Recommended fuel (per Haynes and cross checked to owner's manual on Heritage CD), other than the lead warning is 95 measured by the RON method for all engines...(different than what we use in US, but generally equates to US 'high test' or premium.) But this assumes a factory setup .... different carb needle and futzing with the timing a bit and the engine can be happy on less. You'll get less power but it can run smooth.....
Old Nov 8, 2007 | 09:29 AM
MINIxB's Avatar
MINIxB
So I should be running premium in mine?
Old Nov 8, 2007 | 03:32 PM
richi0207's Avatar
richi0207
Thanks alot guys. Lol didn't know either bumble?
Old Nov 8, 2007 | 04:20 PM
Capt_bj's Avatar
Capt_bj
That's what the bok says
The book simply says the octane rate it says...aka "hi test"
don't matter what engine
factory spec is what it is.... "hi test"
If ur engine runs good on less, it has been detuned to do so....but if u r happy, wat's a matter?
My 75 Cutlass, 350 and 4 barrel called for hi octane. As the gas companies backed off on what they made and I wanted less PING, I retarded the timing....it works up to a point....it got almost 12 mpg
mrjolliff
Oct 9, 2015 05:55 AM
theateist
Aug 22, 2015 06:58 AM
mcoopers81
Aug 19, 2015 01:42 PM
ludedude
Aug 10, 2015 07:16 PM
dchang0
Aug 10, 2015 03:37 PM
