My new Mini
Old Aug 27, 2007 | 09:43 AM
  #101
MINIxB's Avatar
MINIxB
Originally Posted by Agro
Did you try applying more force?
Do you know why it's not closing? 1st guess would be an alignment issue. Check to see if the nuts that hold the bonnet onto the hinges are nice and tight.
I push down on it but the latch that holds it down in the middle won't lock on it. It might be the screws.
Old Aug 27, 2007 | 09:50 AM
  #102
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
If the latch isn't catching when the bar goes in the hole, it could be either alignment, or you might have a problem with the lever/spring that keeps it closed. 1st, check that all the screws/nuts are tight. Then, with the bonnet up, try moving the locking lever back and forth. See if it's moving freely. If not, try some oil/grease/WD40/silicon spray lubricant on it.
Old Aug 27, 2007 | 10:07 AM
  #103
MiniManiac74's Avatar
MiniManiac74
It is probably the spring under the bonnet. I had the same problem. I just opened it up, and tightened the spring. There is a screw right there. Just tighten it up and you should be fine.
Old Aug 27, 2007 | 10:08 AM
  #104
ImagoX's Avatar
ImagoX
Originally Posted by MINIxB
Ok, I need some help. My bonnet won't close!
Try what Agro said and ALSO look on the underside of the bonnet lip and along the fronf of the engine bay for rubber anti-vibration nubbins... I tried fitting a few rubber feet between the bonnet lid and the front engine bay strut and just 1/4" of ruber kept the bonnet from latching properly. I ended up cutting them thinner with a razor blade- enough to stop the bonnet vibration but not so much as to make the bonnet latch pop.
If you simply cannnot make it latch, even after adjusting the bonnet and catch, there's always bonnet straps (which are very traditional) and/or locking pins (which aren't).
Old Aug 27, 2007 | 12:04 PM
  #105
Latka's Avatar
Latka
If it won't latch it's probably either the spring or the overall alignment. I'd try *less* force. No sense in banging up a good bonnet! You can slacken the bolts that hold it to the hinges (4) on the back side and wiggle things around to get the alignment better. Sounds like it's the pin / spring though.
Old Sep 4, 2007 | 07:41 PM
  #106
dimini's Avatar
dimini
Hey MiniXB,
I found you some used wheel options last weekend at the All Brit show up at the KCI airport... Good prices, too. There are (or were, at least) 3 different used sets available through the same seller. I have his number, prices, etc. If you are intersted, PM me and I'll give you the details and tele number. (MWS 10"x6" on nearly new Yoko tires; GB 10"x5"; and Dunlop 10"x5" wheels)
Old Sep 5, 2007 | 07:08 AM
  #107
MINIxB's Avatar
MINIxB
Thanks D.
Old Sep 5, 2007 | 08:11 AM
  #108
ImagoX's Avatar
ImagoX
Dimini - you didn't see anyone with 12" ones there, did you?
Old Sep 5, 2007 | 08:14 AM
  #109
dimini's Avatar
dimini
Sorry, just itsy-bitsies.
Old Sep 5, 2007 | 08:31 AM
  #110
MINIxB's Avatar
MINIxB
10's are better I had this one guy at a car show laugh at my wheels and said "that'd be cool to see those going down the highway" LOL
Old Sep 5, 2007 | 09:13 AM
  #111
ImagoX's Avatar
ImagoX
10's are better
(Sigh)... I know already...
I like the look better than the 12's, but I can only fit 12's or larger duue to my disc brakes (swapping them for Cooper S smaller discs is an option, but is expensive). 13's would necessitate swapping the arches and modding the wheel wells - I need to go 12X5 or MAYBE 12X5.5 tops to avoid having to do bodywork.
Old Sep 5, 2007 | 09:24 AM
  #112
MINIxB's Avatar
MINIxB
The 13's look sooo sexy though. ARGH!!
Old Sep 5, 2007 | 09:50 AM
  #113
ImagoX's Avatar
ImagoX
True, but only with certain arches - Sportack and Group 5's are drop-dead sexy with the wider, "dished" rims. You definietly need to mod the wheel wells and body to accomodate them, plus you lose some of the classic "go kart" twitch steering with wider rims. the trade-off gives you increased traction due to the larger contact patches and (I hear) a more comfy highway ride...
Always a trade-off when you modify the car's steering geometry...
Old Sep 11, 2007 | 08:01 AM
  #114
MINIxB's Avatar
MINIxB
More pictures!!
^^ New carpet
Old Sep 11, 2007 | 08:30 AM
  #115
ImagoX's Avatar
ImagoX
What is that in the center of your switch panel?
Old Sep 11, 2007 | 10:31 PM
  #116
MINIxB's Avatar
MINIxB
The big circle thing?? That's my starter lock. If that's turned on the car won't start.
Old Sep 12, 2007 | 07:24 AM
  #117
ImagoX's Avatar
ImagoX
Ah... it's a battery disconnect I assume? Does it have an actual key, or just a simple "shaft with tab" thingie on it?
Old Sep 12, 2007 | 08:04 AM
  #118
Big Norm's Avatar
Big Norm
such a nice mini........i tried so hard to get my mom to buy it since it was an automatic and about 25 miles from us......but she procrastinates.........looks nice .....now she wants me to build them a Moke....lol......anyways, good luck with her
Old Sep 16, 2007 | 02:43 PM
  #119
MINIxB's Avatar
MINIxB
The brakes are getting fixed tomorrow. Woo hoo!!
Old Sep 17, 2007 | 07:49 AM
  #120
ImagoX's Avatar
ImagoX
Brakes are good.
Old Sep 17, 2007 | 07:54 AM
  #121
MINIxB's Avatar
MINIxB
Brakes are good.
Yeah...especially when you want to take it to a show next weekend. LOL
Old Sep 17, 2007 | 07:58 AM
  #122
MiniManiac74
Mine just had another new steering rack installed, new shocks and new seats. You will get to see it in November
Old Sep 17, 2007 | 08:50 AM
  #123
MINIxB's Avatar
MINIxB
Sweet!! You selling your seats?? j/w
Old Sep 17, 2007 | 09:22 AM
  #124
MiniManiac74
I haven't decided. I have to see how much I like the new ones first.
Old Sep 17, 2007 | 03:32 PM
  #125
dimini's Avatar
dimini
Hey MINIxB,
Did you check out the wheels from the recent allbrit show?
