R60 A0B6 Code (CAS: Selector-lever interlock)
Old Jul 10, 2024 | 02:01 PM
2014 MC's Avatar
2014 MC
Exclamation A0B6 Code (CAS: Selector-lever interlock)
Hello everyone,
The subject code came up with a yellow warning lamp and the brake light lamp being on in the center speedometer area. Also there is a DSC8 code set. Anyone have suggestion what could be the cause? Seems like it has to do with the automatic shifter area? Could it be a cable adjustment or something broken in the shifter (interlock)? I suppose the brake warning light and DSC issue are related to this A0B6 code issue.
Appreciate everyone's experience and help with this.
Old Jul 11, 2024 | 08:39 AM
2014 MC's Avatar
2014 MC
Would this be the correct part that is causing the A0B6 code and affecting the DSC8? Is this a common part failure? Looks like it is used on many models and years... Is it possible to repair this shifter?
https://www.realoem.com/bmw/enUS/par...&q=25167644233
Old Jul 12, 2024 | 08:35 AM
2014 MC's Avatar
2014 MC
Has anyone replaced the automatic shifter in their vehicle? Any good video or issues to be aware of (I can't find anything)? Looking to source a used one (p/n: 25167644233) and see if that solves the code... Seems like interior work, under hood work, and under vehicle work to get this done...
Old Jul 17, 2024 | 09:34 AM
2014 MC's Avatar
2014 MC
@ECS Tuning Do you sell many of these to fix the A0B6 code? Do you have any helpful video information/source on the process to replace this shifter (2014 R60 Base)?
https://www.ecstuning.com/b-genuine-...c/25167644233/
Old Jul 17, 2024 | 11:20 AM
Hello,
Just saw this.
https://www.northamericanmotoring.co...ift-sol-a.html
https://www.northamericanmotoring.co...at-owners.html
https://www.ecstuning.com/Search/Sit...h/25167577589/
Shows that for replacement. ^^
https://www.realoem.com/bmw/enUS/sho...48#25167644233
https://www.realoem.com/bmw/enUS/sho...diagId=51_8308
Thats all i have.
Old Jul 17, 2024 | 02:49 PM
2014 MC's Avatar
2014 MC
Thank you. Do you or anyone know where I can get/find:
  • REP24 10 018
  • REP25 16 056
Old Jul 18, 2024 | 10:57 AM
Here you go:
https://workshop-manuals.com/mini/co..._on/code_a0b6/
Old Jul 29, 2024 | 08:44 AM
2014 MC's Avatar
2014 MC
Update: I bought a used shifter mechanism from Ebay to install, but the code has magically disappeared when my daughter brought over the vehicle for me to replace it this weekend??? That just left the DSC8 and brake light which turned out to be a brake sensor wire that was torn and hanging. I just connected the two wires and reset the code on the center pod (which was a pain and took some tries). Now all codes are gone (for now).
crazy4trains
R55 :: Clubman Talk (2008+)
Aug 9, 2024 08:47 AM
redwhiteR562007
Apr 7, 2021 08:28 PM
Andrew Park
Feb 13, 2019 08:43 PM
mona5255
Jan 29, 2014 08:04 AM
fignewton
Tires, Wheels, & Brakes
Jun 17, 2009 06:46 AM
