R60 2012 Countyman S automatic oil cooler replacement
Old Jan 19, 2024 | 06:04 PM
7rhSon's Avatar
7rhSon
So it seems that my oil cooler on my transmission is at the beginning stage of leaking.. how easy is it to get to and replace. My mechanic wants to charge me $1450 to replace it.. I realize the part itself with a new gasket is about $450.. I believe its right on the top of the transmission... anyone have any better insight?
Old Jan 20, 2024 | 08:46 AM
Lex2008's Avatar
Lex2008
Its probably an o-ring. I changed mine after it started leaking on my N14 with Aisin automatic right under the cooler. Very very easy job.
Step 1, look for the exact location of the leak. If you cannot tell, add some UV dye to the coolant, drive around , then use a blue light and look for it. EASY!!! Cheap kits on Amazon
Old Jan 20, 2024 | 08:49 AM
Lex2008's Avatar
Lex2008
check for o-ring on parts explosion here:
https://www.realoem.com/bmw/enUS/sel...e=0&series=R60
Old Jan 21, 2024 | 08:18 AM
7rhSon's Avatar
7rhSon
I usually 90% of the time get my parts from FCP Euro
Old Jan 21, 2024 | 09:10 AM
Lex2008's Avatar
Lex2008
​​​​​​ I don't understand your point.
Old Jan 21, 2024 | 11:00 AM
7rhSon's Avatar
7rhSon
Have you heard of FCP Euro?
Old Jan 23, 2024 | 07:33 AM
Yes checking that o-ring
https://www.realoem.com/bmw/enUS/sho...diagId=24_1239
Also their are two hoses that run down and connect at the top, they have little hose clips that hold them on, check there also.
Old Jan 23, 2024 | 07:57 AM
Lex2008's Avatar
Lex2008
thats easy to change bruh...do it.
7rhSon
R60/R61 Stock Problems/Issues
Jan 19, 2024 05:40 PM
CAMarten
Apr 14, 2023 07:14 AM
Daftlad
Jan 24, 2023 07:22 AM
grips03
Oct 20, 2013 11:16 AM
MINIAC
May 30, 2008 05:05 AM
