R60 External Lighting Warning Indicator
Old Jun 17, 2022 | 11:35 AM
USNAE2's Avatar
USNAE2
Veteran: Navy
Wife's '13 Countryman S has this indicator on her dash ay start, then goes away. I checked ALL lights and all operate as expected...except for auto as it wasn't dark enough but not sure if that would change things. Any ideas??
Old Jun 17, 2022 | 01:57 PM
mikey_t's Avatar
mikey_t
It usually means there is a bulb connection that isn't working quite right. My left rear tail light did that. Gave it a hard knock and the warning light disappeared. Replaced the bulb and cleaned the contacts and it never came back.
You can also get that warning light that disappears if you have installed LED light bulbs. Despite what the ads say, they still seem to trigger the warning light while the light flickers a bit before it settles into working mode.
Old Jun 17, 2022 | 02:53 PM
USNAE2's Avatar
USNAE2
Veteran: Navy
OK, I know it's not an LED issue since I haven't put any of those in but, I wouldn't doubt a connection issue. That does seem reasonable and easy enough to reseat some connectors. Thanx!
Old Jun 17, 2022 | 03:54 PM
2014 MC's Avatar
2014 MC
Scan your vehicle, it will tell you which circuit is the issue. They got little bulbs within other bulbs in the front.
Old Jun 20, 2022 | 04:37 AM
Capt_bj's Avatar
Capt_bj
often missed in checking is the light on the rear tag . . .
Old Jun 21, 2022 | 12:58 PM
USNAE2's Avatar
USNAE2
Veteran: Navy
Will the License plate light really cause this?
Old Jun 21, 2022 | 01:09 PM
2014 MC's Avatar
2014 MC
Any bulb will bring this warning up. There are side marker ones front and rear sides as well as some in the front fog lamps.
Rescued
Sep 4, 2021 06:22 AM
poor mini
R55 :: Clubman Talk (2008+)
Feb 10, 2015 10:14 PM
OldRick
Jun 3, 2008 02:34 PM
BRG08
May 26, 2008 06:29 PM
gforce23
Jun 4, 2007 02:07 PM
