R60 Suspension questions
Old Jun 27, 2020 | 08:32 AM
Wulfgar's Avatar
Wulfgar
Hello all, I have a 2013 Mini Cooper Countryman S All4. I recently had a rear coil spring break. I'm having trouble finding a replacement so I was thinking about putting aftermarket coils on and replacing my struts with B6 or b4 bilsteins. The problem is I want to lower my ride as little as possible with the potholes and awful back roads here in Nw Ohio. I've never done anything like this, so here's the questions.
Can I rebuild the rear strut assembly with OEM parts (minus the struts and coils)? And Can I only do the rears for now? And would anything else need to be replaced?
Old Jun 30, 2020 | 04:57 AM
jawilli6's Avatar
jawilli6
Wulfgar, Sorry, I can't answer your suspension question. But I have to know, were you at least having some serious fun when the coil spring broke (WOW!?!?!)?
Old Jun 30, 2020 | 05:50 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If it were me in your shoes, I would do the following:
Springs:
https://www.ecstuning.com/b-h-and-r-...et/28923-4~hr/
Shocks:
https://www.ecstuning.com/b-bilstein...kit/2748340kt/
Fitting kit:
https://www.ecstuning.com/b-assemble...06772749ktkt1/
Rear camber arms:
https://www.ecstuning.com/b-hotchkis...f-2/13800~hot/
And, while you're in there, sway bar links:
https://www.ecstuning.com/b-lemforde...359806351~lem/
https://www.ecstuning.com/b-lemforde...359806352~lem/
https://www.ecstuning.com/b-lemforde...509803515~lem/
https://www.ecstuning.com/b-lemforde...509803516~lem/
Anything not included with the above, can be reused from your car. Might look like a big investment, but if you do the work yourself, the suspension will be pretty good for at least another 5+ years.
You could save some money with Bilstein B4s, depending on how long you plan on keeping the car. Maybe find some OEM springs from Ebay, and knock the end links off the list. If you're planning on keeping the car for at least another 2-3 years, the list above will give you some good smiles, and maybe convince you to keep it going a little bit longer.
Old Jun 30, 2020 | 12:19 PM
Wulfgar's Avatar
Wulfgar
Jawilli6, I wish! Then again, I shudder to think what could have happened if I would have been lettin loose! Was driving along then BANG!
Njaremka, awesome! Would it be okay to buy it all and replace the rears only and ride on it for a couple weeks before doing the fronts? I'll probably go with the b6's if I can get them at a decent time but it's my daily driver so I can't be too long without it.
Thanks a ton for the feedback! I'm hoping to keep my MINI for as long as possible and would like to learn wrench on her myself as much as I can!
Old Jun 30, 2020 | 12:25 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If you are going aftermarket springs, you'll want to do front and rear at the same time. Doing only the rear will cause some unsafe driving dynamics, since the rear will be lower and stiffer than the fronts.
Really, its not a difficult task if you have any mechanical abilities. Assuming you have any skills, you and a buddy could bang it out on a long Saturday. Read up on the procedures, get yourself some of the special tools, and have at it.
Old Jun 30, 2020 | 06:59 PM
Wulfgar's Avatar
Wulfgar
Got the parts ordered! I'll update when finished. Can't wait to get this baby rollin again!
Old Jul 1, 2020 | 07:25 PM
dmath's Avatar
dmath
There are a couple of helpful videos on youtube and some threads here on NAM that are very useful.
Old Jul 26, 2020 | 11:41 AM
Wulfgar's Avatar
Wulfgar
That's a bummer....but rears are done!
Old Jul 26, 2020 | 12:12 PM
dmath's Avatar
dmath
That is a bummer. What's your plan for extracting it?
Old Jul 26, 2020 | 12:30 PM
Wulfgar's Avatar
Wulfgar
Well, either drill in the bolt and use an extractor or use pliers on the other side where there's threads showing and see if I can twist it through. Either way, I'll get a torch first to try to help loosen it. Penetrating lube didn't seem to help too much
Old Jul 26, 2020 | 01:56 PM
dmath's Avatar
dmath
I just did the suspension on my car and new sway bars on my son's WRX. Had limited success with the first penetrating oil I tried. Then I got Aerokroil and it worked MUCH better. Good luck!
Old Jul 29, 2020 | 07:38 PM
Wulfgar's Avatar
Wulfgar
So I ordered new bolts for the lower strut but they're taking FOREVER to even ship. If I were to find the right size, is there an alternative I could get at the hardware store, like a grade A or something of that nature?
Old Jul 29, 2020 | 07:51 PM
dmath's Avatar
dmath
It would have to be the world's best hardware store to have those bolts. I'll send a PM to follow up.
alconk
18
Jun 20, 2019 02:00 PM
mhopper49
12
Nov 11, 2015 10:59 AM
minsane
Suspension
Jan 27, 2011 02:40 PM
jmoser
Suspension
14
May 21, 2008 01:20 PM
dominicminicoopers
Suspension
24
Nov 2, 2005 04:12 PM
