R60 Battery group size H5 or H6?
Old Nov 17, 2019 | 07:42 AM
Marquette MINI's Avatar
Marquette MINI
The battery on my 2014 Countryman S is on its way out. When I enter my make/model in the filters on Autozone, Advance Auto, etc., it returns batteries listed as Group Size H5 and Group Size H6. I assume both sizes will work, but does anyone know which size is the best fit? They both say "Exact Fitfor your 2014 Mini Cooper Countryman S ALL4" but obviously only one size can be an "exact" fit, while the other would be "close enough" fit.
Old Nov 17, 2019 | 10:14 AM
MVPeters's Avatar
MVPeters
Most likely H6. It should be a snug fit, the H5 will work but is slightly shorter.
Just measure the length - I found some of the catalogs are not quite correct.
Old Nov 17, 2019 | 04:28 PM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
Ensure that the battery is programmable (coded) to your Countryman.
Old Nov 17, 2019 | 05:01 PM
Marquette MINI
Thanks. I picked up the H6 size from Advance Auto. I had my core with me and lined them both up at the counter and they seemed pretty close in size. No problems getting it installed.
Old Nov 17, 2019 | 05:38 PM
Marquette MINI
I have the diagnostic tool coming from Amazon tomorrow to do exactly this.
Old Nov 18, 2019 | 09:49 AM
2014 MC's Avatar
2014 MC
What tool did you go with? Let us know how it works out when you get it done. I recently replace my battery with an AGM and had a friend do the programming. What a general pain in the *** really...
Old Nov 18, 2019 | 06:24 PM
Marquette MINI
I got this one:
AUTOPHIX BMW Diagnostic Scanner Tool ,Enhanced BMW 7910 Multi-System OBD2 Scanner Auto Fault Code Reader with Battery Registration for All BMW After 1998 AUTOPHIX BMW Diagnostic Scanner Tool ,Enhanced BMW 7910 Multi-System OBD2 Scanner Auto Fault Code Reader with Battery Registration for All BMW After 1998
I went through the menus and was able to register the battery. Not entirely intuitive, but it seemed to work and the tool confirmed that the new battery was registered. I also scanned my BMW 335i, which had a whole mess of codes come up, a few of which the reader was unable to erase (i.e. it said it successfully erased them, but when I rescanned, they showed up again). Going to need to dig into those to figure out what they mean.
Old Nov 19, 2019 | 09:40 AM
2014 MC's Avatar
2014 MC
There sure seem to be a ton of various options when it comes to scanners and such just looking at Amazon... That is great it worked for the Mini and register the battery. This is my first European car and I'm not really a fan so far based on having Asian vehicles for the most part.
cristo
Dec 22, 2019 10:55 PM
bccan
Jun 5, 2018 05:46 PM
superducky
R55 :: Clubman Talk (2008+)
Nov 30, 2016 06:23 AM
dedalus5550
Dec 16, 2012 02:37 PM
Nubwagon
Apr 30, 2008 04:44 PM
