R60 Timing chain gears
Old May 8, 2019 | 12:54 PM
Jermajerm's Avatar
Jermajerm
Timing chain gears
Should we be replacing the cam gears when replacing the timing chain? Wanted to see if there is a consensus considering the kit without the gears is much cheaper
Edit: I'm in a 2013 sAll4 with 69K.
Old May 8, 2019 | 01:17 PM
MiniToBe's Avatar
MiniToBe
I've done it both ways but never the intake vanos. Key item is the actual tensioner. make sure it is 82mm vs 78mm.
Old May 9, 2019 | 02:57 AM
Scudder44's Avatar
Scudder44
The lower sprocket yes, the cam gear/vanos no. The lower sprocket apparently takes majority of wear and you may see this when it is in your hand :-)
weaver9000
Sep 14, 2015 05:48 PM
gbfan10
23
Dec 12, 2012 08:26 PM
5810
Nov 17, 2010 10:49 AM
turnkey
Jun 30, 2007 09:27 AM
