R60 Removal of Roof Rails
Old Aug 14, 2015 | 08:49 AM
penguinhomey's Avatar
penguinhomey
Does anybody know if the roof rails are detachable?
If so how do I do it?
Trying to have them re-painted
Thanks!
Old Aug 14, 2015 | 08:26 PM
MIminiclubman's Avatar
MIminiclubman
You have to pull the headliner to get to the 4 nuts that hold them on. There was a thread on this about a year ago that had the real-OEM parts drawing showing the rail with studs and nuts or the underside.
I have no clue how hard pulling the headliner is.
Old Aug 15, 2015 | 09:02 AM
bmwr606's Avatar
bmwr606
i had mine painted white to match my white roof
it was done while the all4 was in the mini dealer's body shop to get hail damage repaired (paintless method)
to get the dings out of the of the roof they needed to remove the headliner ... the quote stated 4 hours to R&R the headliner
since the headliner was coming out, the rail removal and painting was only $100 extra
i had previously been quoted $750-$1000 by the same body shop to paint the rails (time and materials)
Old Aug 15, 2015 | 09:08 AM
bmwr606's Avatar
bmwr606
headliner removal
remove
upper switch panel
cabin light
front sun visors
drivers side sun visor
3 passenger grip handles
A, B , C and D pillar trim
plug at center rear of headliner
Old Aug 15, 2015 | 11:06 AM
Angib's Avatar
Angib
Item 2 is called a 'compensating element' (no, I've no idea what that means, either).
Old Aug 15, 2015 | 05:00 PM
MIminiclubman
That is the sealing surface that compensates for slight variations between the roof and ridged hard rail.
Old Aug 15, 2015 | 09:35 PM
bmwr606's Avatar
bmwr606
otherwise called a gasket
Old Aug 19, 2015 | 01:14 PM
Post up some pics if you get it removed.
NYXF56JCW
Nov 17, 2024 05:06 AM
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
bobbiemartin
Jan 20, 2016 05:28 PM
1chaos52
Aug 24, 2015 01:28 PM
bseiden
Aug 15, 2015 10:16 AM
